Topic: Additional bit for 2nd channel's warm-up samples (Read 671 times) previous topic - next topic
Hi!
(FLAC newby here)
I'm working on my own FLAC decoder, and ran into something I can't quite understand. I'm trying to understand the following section (src/libFLAC/stream_decoder.c#L2057) of libFLAC:
case FLAC__CHANNEL_ASSIGNMENT_MID_SIDE:
                FLAC__ASSERT(decoder->private_->frame.header.channels == 2);
                if(channel == 1)
                    bps++;
I'm wondering why the warm-up samples for the 2nd channel are stored with an additional bit per sample compared to the 1st channel? I don't find any mention of this in the format spec - am I missing something?
Re: Additional bit for 2nd channel's warm-up samples
See here: https://github.com/ietf-wg-cellar/flac-specification/blob/master/flac.md#interchannel-decorrelation
The side channel needs one extra bit of bit depth as the subtraction can produce sample values twice as large as the maximum possible in any given bit depth. The mid channel in mid-side stereo does not need one extra bit, as it is shifted left one bit. The left shift of the mid channel does not lead to non-lossless behavior, because an uneven sample in the mid subframe must always be accompanied by a corresponding uneven sample in the side subframe, which means the lost least significant bit can be restored by taking it from the sample in the side subframe.
Simply put: if you have 8-bit audio, and the left sample is +127 and the right sample -128, the diff channel becomes 127 - -128 = 255. So, you need 9 bits to code for that number.
Ah, I see. Thanks a lot for the quick response :)
If you find something else that isn't quite clear in the FLAC specification, please let me know, either through this topic or at github. An IETF working group intends to improve the FLAC spec (in wording, not by changing the FLAC format or anything), and they'd like as much input as they can get.
For example, perhaps you can look at these examples to see whether they are clear? https://github.com/ietf-wg-cellar/flac-specification/blob/27e4418776177df638125cccb585b473edebb091/rfc_backmatter.md There's no example yet about a side channel needing an extra bit, but it might still be a good read?
I'll have a look, and keep it mind going forward.
