I did two rips of a new CD (flac + test & copy image & create cue) e image) and in both cases I got: test reading & sync error + copy reading & copy error) But in the fist rip the .cue doesnt show any error.
Rip 1:
Exact Audio Copy V1.5 from 20. February 2020
EAC extraction logfile from 24. August 2021, 22:11
Lagwagon / Double Plaidinum
Used drive : ASUS DRW-24B5ST Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 6
Overread into Lead-In and Lead-Out : No
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Used output format : User Defined Encoder
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : -5 -V -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr1%" -T "ARTIST=%artist%" -T "TITLE=%title%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %source% -o %dest%
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 1:49.40 | 0 | 8214
2 | 1:49.40 | 2:14.29 | 8215 | 18293
3 | 4:03.69 | 2:23.16 | 18294 | 29034
4 | 6:27.10 | 2:20.08 | 29035 | 39542
5 | 8:47.18 | 2:03.15 | 39543 | 48782
6 | 10:50.33 | 2:54.68 | 48783 | 61900
7 | 13:45.26 | 1:18.74 | 61901 | 67824
8 | 15:04.25 | 2:03.44 | 67825 | 77093
9 | 17:07.69 | 2:30.07 | 77094 | 88350
10 | 19:38.01 | 2:45.62 | 88351 | 100787
11 | 22:23.63 | 2:45.22 | 100788 | 113184
12 | 25:09.10 | 2:29.72 | 113185 | 124431
13 | 27:39.07 | 2:46.48 | 124432 | 136929
14 | 30:25.55 | 1:54.54 | 136930 | 145533
15 | 32:20.34 | 1:35.09 | 145534 | 152667
16 | 33:55.43 | 2:32.67 | 152668 | 164134
17 | 36:28.35 | 2:42.41 | 164135 | 176325
18 | 39:11.01 | 2:46.60 | 176326 | 188835
19 | 41:57.61 | 2:28.30 | 188836 | 199965
20 | 44:26.16 | 2:12.45 | 199966 | 209910
21 | 46:38.61 | 2:25.60 | 209911 | 220845
22 | 49:04.46 | 1:48.17 | 220846 | 228962
23 | 50:52.63 | 2:26.74 | 228963 | 239986
24 | 53:19.62 | 2:35.38 | 239987 | 251649
Range status and errors
Selected range
Filename E:\Bruno\Mi Música\Mis Rips\Lagwagon - Double Plaidinum.wav
Peak level 98.8 %
Extraction speed 2.7 X
Range quality 99.6 %
Test CRC A1FB461C
Copy CRC A1FB461C
Copy OK
No errors occurred
AccurateRip summary
Track 1 accurately ripped (confidence 2) [DCACC0B9] (AR v2)
Track 2 accurately ripped (confidence 2) [806326EE] (AR v2)
Track 3 accurately ripped (confidence 2) [B8CC3CEB] (AR v2)
Track 4 accurately ripped (confidence 2) [F09A446A] (AR v2)
Track 5 accurately ripped (confidence 2) [9E67981A] (AR v2)
Track 6 accurately ripped (confidence 2) [FA8CBB05] (AR v2)
Track 7 accurately ripped (confidence 2) [6CF1F0A9] (AR v2)
Track 8 accurately ripped (confidence 2) [0909EC7D] (AR v2)
Track 9 accurately ripped (confidence 2) [1980831C] (AR v2)
Track 10 accurately ripped (confidence 2) [D8101ECE] (AR v2)
Track 11 accurately ripped (confidence 2) [D1CAC2B2] (AR v2)
Track 12 accurately ripped (confidence 2) [445D670F] (AR v2)
Track 13 accurately ripped (confidence 2) [A751497F] (AR v2)
Track 14 accurately ripped (confidence 2) [E0129AD9] (AR v2)
Track 15 accurately ripped (confidence 2) [6648BBD4] (AR v2)
Track 16 accurately ripped (confidence 2) [7174B17C] (AR v2)
Track 17 accurately ripped (confidence 2) [EB7B7FCA] (AR v2)
Track 18 accurately ripped (confidence 2) [C781F23C] (AR v2)
Track 19 accurately ripped (confidence 2) [EDEDFEE5] (AR v2)
Track 20 accurately ripped (confidence 2) [F5B917CE] (AR v2)
Track 21 accurately ripped (confidence 2) [A5A5A121] (AR v2)
Track 22 accurately ripped (confidence 2) [13AA14F9] (AR v2)
Track 23 accurately ripped (confidence 2) [4759F520] (AR v2)
Track 24 accurately ripped (confidence 2) [C7324FF7] (AR v2)
All tracks accurately ripped
End of status report
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: 3YTmjp8JosWmc.pq1hVBDEZ.iBE-] found
Submit result: 3YTmjp8JosWmc.pq1hVBDEZ.iBE- has been confirmed
Track | CTDB Status
1 | (37/38) Accurately ripped
2 | (37/38) Accurately ripped
3 | (37/38) Accurately ripped
4 | (37/38) Accurately ripped
5 | (37/38) Accurately ripped
6 | (37/38) Accurately ripped
7 | (37/38) Accurately ripped
8 | (37/38) Accurately ripped
9 | (37/38) Accurately ripped
10 | (37/38) Accurately ripped
11 | (37/38) Accurately ripped
12 | (37/38) Accurately ripped
13 | (37/38) Accurately ripped
14 | (37/38) Accurately ripped
15 | (37/38) Accurately ripped
16 | (37/38) Accurately ripped
17 | (37/38) Accurately ripped
18 | (37/38) Accurately ripped
19 | (37/38) Accurately ripped
20 | (37/38) Accurately ripped
21 | (37/38) Accurately ripped
22 | (37/38) Accurately ripped
23 | (37/38) Accurately ripped
24 | (35/38) Accurately ripped
==== Log checksum B46D78A67656330AADF33C02EB24757174DEE0A6158E958A3A47BCBC255753E5 ====
Rip2:
EAC extraction logfile from 25. August 2021, 3:27
Read mode : Secure
Quality : High
Add ID3 tag : No
Selected range
Suspicious position 0:47:01
Suspicious position 0:47:04
Suspicious position 0:47:12 - 0:47:13
Suspicious position 0:47:16
Suspicious position 0:47:20
Suspicious position 0:47:22
Suspicious position 0:47:24 - 0:47:25
Suspicious position 0:47:27
Suspicious position 0:47:30
Suspicious position 0:47:40
Suspicious position 0:47:42
Suspicious position 0:47:46 - 0:47:48
Suspicious position 0:47:50 - 0:47:58
Suspicious position 0:48:01
Suspicious position 0:48:04 - 0:48:07
Suspicious position 0:48:09 - 0:48:10
Suspicious position 0:48:13 - 0:48:22
Suspicious position 0:48:24 - 0:48:35
Suspicious position 0:48:37 - 0:48:50
Suspicious position 0:48:52 - 0:48:55
Suspicious position 0:48:57 - 0:49:04
Suspicious position 0:49:06 - 0:49:10
Suspicious position 0:49:12 - 0:49:28
Suspicious position 0:49:30 - 0:49:32
Peak level 99.7 %
Extraction speed 0.2 X
Range quality 96.9 %
Test CRC 3F67D520
Copy CRC 4141CF35
Copy finished
There were errors
AccurateRip summary
Track 21 cannot be verified as accurate (confidence 11) [FC7EFACF], AccurateRip returned [FC7BA185] (AR v2)
Track 22 cannot be verified as accurate (confidence 11) [04DCCF6F], AccurateRip returned [5035C55D] (AR v2)
22 pista(s) extraidas con precisión
2 pista(s) no puede ser verificada como precisa
Some tracks could not be verified as accurate
Submit result: insufficient quality
Track | CTDB Status
1 | (38/39) Accurately ripped
2 | (38/39) Accurately ripped
3 | (38/39) Accurately ripped
4 | (38/39) Accurately ripped
5 | (38/39) Accurately ripped
6 | (38/39) Accurately ripped
7 | (38/39) Accurately ripped
8 | (38/39) Accurately ripped
9 | (38/39) Accurately ripped
10 | (38/39) Accurately ripped
11 | (38/39) Accurately ripped
12 | (38/39) Accurately ripped
13 | (38/39) Accurately ripped
14 | (38/39) Accurately ripped
15 | (38/39) Accurately ripped
16 | (38/39) Accurately ripped
17 | (38/39) Accurately ripped
18 | (38/39) Accurately ripped
19 | (38/39) Accurately ripped
20 | (38/39) Accurately ripped
21 | ( 0/39) No match
22 | ( 0/39) No match
23 | (38/39) Accurately ripped
24 | (36/39) Accurately ripped
==== Log checksum 7A9A1398C1DFE44936EF09E230D1FE14FAB11F9B9708981D7470687C2B462139 ====
MOD edit: Move logs to 'code' boxes.
