Topic: Opustags.exe? (Read 3820 times) previous topic - next topic
Opustags.exe?
Hello
Where I can find, how can I compile or can someone make opustags.exe?
https://github.com/fmang/opustags
The goal is to import tags from file, same way than "metaflac.exe --import-tags-from=Tags.txt" and "vorbiscomment.exe -a -c Tags.txt".
Long time ago, there was discussion about this same thing.
Do you remember what happened, @skamp or @Brazil2?
I have never compiled anything, so I probably need lots of help or a good and simple guide.
Or are there other similar Windows command line -tools I can use?
MOD edit: fix github link
Re: Opustags.exe?
According to the README, it requires a POSIX-compliant system so it won't work on Windows.
Re: Opustags.exe?
I think it means that only compiling needs POSIX -system.
If so, I can use virtual machine.
Output should still be Windows compatible opustags.exe.
I still haven't found the solution to my first post, so any help or tips are welcome.
I read this forum sometimes and tell you if problem is solved.
Once again, the goal is to import tags to .opus -files from tags.txt -file, same way than ogg and flac does.
And with Windows command line.
Re: Opustags.exe?
You can build it using MSYS2 in the MSYS (Cygwin) environment, but you'll also have to build libogg from source.
Which I found out by building it myself. I think everything you need is included, but I haven't checked to see if it works.
Re: Opustags.exe?
Thanks @Octocontrabass
Now my problem is solved :)
For archiving purposes, this is what I have done.
If somebody knows better ways, you can tell it.
Especially, my importing tags from file -method might be "quick and dirty".
Flac to opus:
opusenc.exe --bitrate 256 --music --discard-comments --discard-pictures input.flac output.opus
opusenc.exe
Delete one tag from opus:
opustags.exe --in-place --delete ARTIST=Abc audio.opus
opustags.exe
Delete all tags from opus:
opustags.exe --in-place --delete-all audio.opus
Add one tag to opus:
opustags.exe --in-place --add ARTIST=Abc audio.opus
Edit one tag at opus:
opustags.exe --in-place --set ARTIST=Abc audio.opus
Add tags from file to opus:
type tags.txt | opustags.exe --in-place --set-all --raw audio.opus
type
Re: Opustags.exe?
You can build it using MSYS2 in the MSYS (Cygwin) environment, but you'll also have to build libogg from source. Which I found out by building it myself. I think everything you need is included, but I haven't checked to see if it works.
I tried to compile it myself, but failed - I simply haven't been using MSYS2/Cygwin/... a lot lately. The release posted above is 1.6 which is lacking some vital bug fixes and cover picture support.
=> Can anyone please post a Windows binary of the latest opustags.exe, ie. 1.8 or more recent?
Re: Opustags.exe?
The current version of opustags relies on at least two POSIX functions - getline() and mkstemps() - that haven't been implemented in Mingw-w64 yet, so I can't build a native Windows version under MSYS2.
I haven't yet tried building a Cygwin version under MSYS2...
Re: Opustags.exe?
The current version of opustags relies on at least two POSIX functions - getline() and mkstemps() - that haven't been implemented in Mingw-w64 yet, so I can't build a native Windows version under MSYS2. I haven't yet tried building a Cygwin version under MSYS2...
Right, I suspeced as much seeing how compilation failed. I guess a native Cygwin version could very well be possible (that's what I did with WebP because the MinGW version lacks some features), but I don't know when I'll have time to give it a try - so anyone, please be my guest :-)
In the meantime, I've added a bug ticket - even though no dev has to love or support Windows, it's an important platform nevertheless and not bing able to tag Opus files with the command line is a pity. https://github.com/fmang/opustags/issues/61
Re: Opustags.exe?
And here's the Cygwin version. Like last time, it required building libogg from source.
Re: Opustags.exe?
Great, thanks a lot! I I'll stumble upon any regressions I'll report back, but I'm keeping my fingers crossed.
