Topic: foo_uie_albumart + embedded tags (Read 192650 times) previous topic - next topic
Working like a charm with my id3v2 and FLAC tags. Now support for APE tags and we're all set!
is there a way of maybe "generating" album art such as tags to speed up the process? or is there maybe an easier way of adding album-art to all my albums besides googling -> saving -> adding to each individual folder? i've got about 2,000 albums and frankly i'm not up to the task.
also, i've found two album covers that seem to be cut off for one reason or the other.
i'm guessing this is somehow a mistake as the person that uploaded these albums never attached faulty album covers in the past.
Does this component let you choose external images before embedded art?  I ask because all my embedded art is 200x200 pixel specifically for my MP3 player, but on my computer I store all the higher-res images for use with the other albumart component.
from what I remember it doesn't
I lost the source :X I might be able to add it later, it's pretty easy to modify the original plugin.
Reply #32
no feedback for me?
is it because i registered for the sole purpose of getting a question answered or because no one has a clue?
Great!  Any chance to see more than one cover?
Also, when I choose Previous source foobar crashes with "Unhandled exceptions: dynamic_assert failure" alert...
Thinking Outside The Box
Reply #34
Download: http://cdtag.com/download/foo_uie_albumart.zip
Requirements: UI Columns http://yuo.be/columns.php
The original plugin can be found here: http://cherans.bol.ucla.edu/fooplugins.html
You don't need it but I wanted to credit the developers of this plugin.
Instructions:
Fire up foobar.  It will ask if you want to use Columns UI, say yes.
Go to File, Preferences, Columns UI.  Right click on one either Horizontal or Vertical splitter, Insert Panel, Panels, Album Art.
Now if you select a file with an ID3v2 tag with a picture embedded (doesn't need to be MP3) or a FLAC file with an embedded picture it will be displayed in the album art panel.  If no art is found then it defaults to searching for album art the standard way.
Oh yeah, and I apologize if it crashes your foobar.
Any chance support for APEv2 embedded art could be added?  I use a single wavpack file per album with an embedded cue sheet, and I'm tired of no album art.  I'm a developer and I could probably hack it in there if I had the source...either way I'd REALLY like to get this functionality added!  Thanks!
Reply #35
Any progress?.. Great mod and I hope that the development will continue
Reply #36
how can i embedded picture ?
how do i trolled ha?
great work btw, i've been waiting for something like this for a long time.
Reply #37
I'm having problems getting this to work
I have the latest ColumnsUI and the following plugins in my components folder:
foo_albumlist.dll
foo_cdda.dll
foo_converter.dll
foo_dsp_std.dll
foo_input_monkey.dll
foo_input_std.dll
foo_masstag.dll
foo_rgscan.dll
foo_uie_albumart.dll
foo_ui_columns.dll
foo_ui_std.dll
foo_unpack.dll
I embedded images into a mp3 and a flac file using Mp3tag but the panel doesn't show embedded images, only the ones in the folder. If i remove the folder ones, it doesn't display anything at all.
I opened the mp3 with WMP and it does display the embedded one so.. am i doing something wrong?
Reply #38
I run into this problem periodically and the only thing that ever fixes it is to rescan the Media Library. You may have to remove the Music Folder, close fb2k, re-open and add the Music Folder path again and Scan. Use Scan All if you have more than one path, as I do.
Surf's Up!
"Columnated Ruins Domino"
Reply #39
Well, I rescanned my library but it doesn't really help. Here is the console output i'm getting:
[19:40:47] searching album art, preprocessed pattern: "D:\folder.jpg"
[19:40:47]  0 match(es) found
[19:40:47] searching album art, preprocessed pattern: "D:\folder.png"
[19:40:47] searching album art, preprocessed pattern: "D:\folder.gif"
[19:40:47] searching album art, preprocessed pattern: "components\default.*"
I don't see any lines where it tried looking at the embedded images =/
Reply #40
What you are seeing there is the plugin looking for external albumart. I just used MP3tag to embed album art in my mp3 files and they showed with no problems. So, the next question is which version of foo_uie_albumart are you using? The embedded version is  0.2.5.2
Surf's Up!
Reply #41
Oh...
I'm really dumb, aren't i? Yeah seems like i got an older version of it. Just re-downloaded it and it's working.
Thanks for your help
Reply #42
You are welcome!
Hey, I know it gets confusing sometimes with different versions floating around.
I am glad that it is working for you.
Surf's Up!
Reply #43
Hey!
I just found this and great, it works - so I started going through my collection and "moving" the JPEGs into the FLACs - which is fantastic, because I have some directories which contain singles from multiple albums, and mixing the JPEGs in with them was a pain.
BUT then I find the bug concerning "special" characters. It displays nothing if the path contains one, not even the default fall-back image as configured in the options dialog.
That's a pretty dumb bug, should be easily fixed yes?
* begs *
Reply #44
Any progress?..
Reply #45
Is it just me or it crashes foobar 0.9.5b1?
Reply #46
crystal-clear, works fine for me.
Reply #47
Really? But it crash on mine... I'm on vista if it makes any difference
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 616E656Ch
Access violation, operation: read, address: 616E656Ch
Call path:
entry=>user_interface::shutdown
Stack (0012926Ch):
0012924Ch:  00000000 00000000 00000000 00000000
0012925Ch:  00000000 00000000 00000000 00000000
0012926Ch:  013E8356 00020AF6 00000128 00010001
0012927Ch:  00000000 00129308 00000128 001292B8
0012928Ch:  00000000 77681A10 00020AF6 00000128
0012929Ch:  00010001 00000000 00000128 DCBAABCD
001292ACh:  00000000 00129308 00000128 00129330
001292BCh:  77681AE8 013E8310 00020AF6 00000128
001292CCh:  00010001 00000000 41C88973 00000000
001292DCh:  00020AF6 002116E0 00000024 00000001
001292ECh:  00000000 00000000 00000030 FFFFFFFF
001292FCh:  FFFFFFFF 77681A91 00000000 00000000
0012930Ch:  00000001 00000000 00000000 001292D4
0012931Ch:  00128E8C 0012937C 776C76CC 36B2014B
0012932Ch:  00000000 0012938C 77681C03 00000000
0012933Ch:  013E8310 00020AF6 00000128 00010001
0012934Ch:  00000000 00FFBD4C 00000001 41C889CF
0012935Ch:  00000128 00FFBC18 002116E0 001293A4
0012936Ch:  77681E2C 00000000 00129358 00128E8C
0012937Ch:  001293C4 776C76CC 36B2065B FFFFFFFE
Registers:
EAX: 029B1118, EBX: 00000000, ECX: 029B0810, EDX: 616E656C
ESI: 029B0810, EDI: 00020AF6, EBP: 00000128, ESP: 0012926C
Unable to identify crash location
Loaded modules:
foobar2000                      loaded at 00400000h - 0050A000h
ntdll                            loaded at 774E0000h - 775FE000h
kernel32                        loaded at 75F70000h - 76048000h
COMCTL32                        loaded at 74B30000h - 74CC4000h
msvcrt                          loaded at 75DA0000h - 75E4A000h
ADVAPI32                        loaded at 77290000h - 7734F000h
RPCRT4                          loaded at 76E10000h - 76ED3000h
GDI32                            loaded at 76FF0000h - 7703B000h
USER32                          loaded at 77660000h - 776FE000h
SHLWAPI                          loaded at 77480000h - 774D5000h
SHELL32                          loaded at 761E0000h - 76CAE000h
ole32                            loaded at 77040000h - 77184000h
shared                          loaded at 10000000h - 1002D000h
COMDLG32                        loaded at 77190000h - 77204000h
IMM32                            loaded at 77630000h - 7764E000h
MSCTF                            loaded at 75EA0000h - 75F67000h
LPK                              loaded at 77700000h - 77709000h
USP10                            loaded at 77210000h - 7728D000h
uxtheme                          loaded at 74E30000h - 74E6F000h
eplgHooks                        loaded at 22200000h - 22206000h
foo_abx                          loaded at 00280000h - 002B3000h
foo_albumlist                    loaded at 00D20000h - 00D75000h
foo_cdda                        loaded at 01200000h - 01233000h
foo_converter                    loaded at 01360000h - 013D2000h
foo_dsp_std                      loaded at 01240000h - 01287000h
foo_fileops                      loaded at 01590000h - 015D6000h
OLEAUT32                        loaded at 76CB0000h - 76D3C000h
foo_input_std                    loaded at 01890000h - 019B5000h
foo_rgscan                      loaded at 015E0000h - 01626000h
foo_uie_albumart                loaded at 013E0000h - 0141A000h
gdiplus                          loaded at 745E0000h - 7478A000h
foo_uie_lyrics_panel            loaded at 019C0000h - 01A28000h
foo_uie_playlists_dropdown      loaded at 01B80000h - 01BB9000h
foo_ui_columns                  loaded at 01DC0000h - 01E86000h
foo_ui_panels                    loaded at 01F90000h - 02079000h
foo_ui_std                      loaded at 02080000h - 02134000h
MSIMG32                          loaded at 751D0000h - 751D5000h
foo_unpack                      loaded at 01D00000h - 01D2E000h
imagehlp                        loaded at 77600000h - 77629000h
dbghelp                          loaded at 6E8C0000h - 6E99C000h
Stack dump analysis:
Address: 013E8356h, location: "foo_uie_albumart", loaded at 013E0000h - 0141A000h
Address: 77681A10h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetMessageW" (+0000006Eh)
Address: 77681AE8h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetMessageW" (+00000146h)
Address: 013E8310h, location: "foo_uie_albumart", loaded at 013E0000h - 0141A000h
Address: 77681A91h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetMessageW" (+000000EFh)
Address: 776C76CCh, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "AlignRects" (+00001926h)
Address: 77681C03h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetMessageW" (+00000261h)
Address: 77681E2Ch, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "DefWindowProcW" (+0000009Ch)
Address: 77683656h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "OffsetRect" (+0000004Dh)
Address: 77540E6Eh, location: "ntdll", loaded at 774E0000h - 775FE000h
Symbol: "KiUserCallbackDispatcher" (+0000002Eh)
Address: 77540E20h, location: "ntdll", loaded at 774E0000h - 775FE000h
Symbol: "KiUserApcDispatcher" (+00000048h)
Address: 77681BB8h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetMessageW" (+00000216h)
Address: 77682335h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "DefWindowProcW" (+000005A5h)
Address: 776818F3h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetCursorPos" (+0000528Fh)
Address: 77682FA9h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "PtInRect" (+00000056h)
Address: 776CAB20h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "AlignRects" (+00004D7Ah)
Address: 77681DFBh, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 77681D87h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetMessageW" (+000003E5h)
Address: 77681DE4h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "DefWindowProcW" (+00000054h)
Address: 01DE14E9h, location: "foo_ui_columns", loaded at 01DC0000h - 01E86000h
Address: 776824AFh, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "SetWindowLongW" (+00000065h)
Address: 77682539h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77682545h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetWindowLongW" (+00000037h)
Address: 01E45249h, location: "foo_ui_columns", loaded at 01DC0000h - 01E86000h
Symbol: "foobar2000_get_interface" (+0001DA79h)
Address: 01E267D7h, location: "foo_ui_columns", loaded at 01DC0000h - 01E86000h
Address: 77681B41h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetMessageW" (+0000019Fh)
Address: 77681AFFh, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetMessageW" (+0000015Dh)
Address: 01E26660h, location: "foo_ui_columns", loaded at 01DC0000h - 01E86000h
Address: 74B7586Ah, location: "COMCTL32", loaded at 74B30000h - 74CC4000h
Symbol: "ImageList_GetIcon" (+000000DFh)
Address: 01E25288h, location: "foo_ui_columns", loaded at 01DC0000h - 01E86000h
Address: 01DE092Fh, location: "foo_ui_columns", loaded at 01DC0000h - 01E86000h
Address: 776828FAh, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "IsWindow" (+00000000h)
Address: 77682937h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "IsWindow" (+0000003Dh)
Address: 77681D60h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetMessageW" (+000003BEh)
Address: 74E31F61h, location: "uxtheme", loaded at 74E30000h - 74E6F000h
Address: 7766B2E6h, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "MoveWindow" (+0000000Ch)
Address: 74B6BB36h, location: "COMCTL32", loaded at 74B30000h - 74CC4000h
Symbol: "ImageList_Draw" (+00000DD4h)
Address: 7768250Eh, location: "USER32", loaded at 77660000h - 776FE000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 74B6C203h, location: "COMCTL32", loaded at 74B30000h - 74CC4000h
Symbol: "ImageList_Draw" (+000014A1h)
Address: 74B75972h, location: "COMCTL32", loaded at 74B30000h - 74CC4000h
Symbol: "ImageList_GetIcon" (+000001E7h)
Version info:
foobar2000 v0.9.5 beta 1
UNICODE
Windows 6.0
Additional info:
Album List 4.0  (foo_albumlist)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]  (foo_ui_panels)
CD Audio Decoder 2.1.2  (foo_cdda)
Standard DSP Array 1.0  (foo_dsp_std)
Playlists Dropdown 0.6 alpha 4  (foo_uie_playlists_dropdown)
ZIP/GZIP reader 1.0  (foo_unpack)
Album Art Panel 0.2.5.2  (foo_uie_albumart)
RAR reader 1.1  (foo_unpack)
File Operations 2.0  (foo_fileops)
Columns UI 0.2  (foo_ui_columns)
Default User Interface 0.9.5  (foo_ui_std)
Lyrics panel 0.34.1  (foo_uie_lyrics_panel)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Converter 1.0.1  (foo_converter)
foobar2000 core 0.9.5 beta 1  (Core)
ABX Comparator 1.3.1  (foo_abx)
And also, I've tried 3 different version of foo_uie_albumart, and they all crash foobar
Reply #48
I have a crash too:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0531834Ch
Access violation, operation: read, address: 0000005Ch
Call path:
Code bytes (0531834Ch):
0531830Ch:  CC CC CC CC 53 8B 5C 24 14 55 8B 6C 24 10 81 FD
0531831Ch:  81 00 00 00 56 57 8B 7C 24 14 75 0E 8B 33 56 6A
0531832Ch:  EB 57 FF 15 78 41 33 05 EB 0B 6A EB 57 FF 15 B8
0531833Ch:  41 33 05 8B F0 85 F6 53 74 17 8B 4C 24 20 8B 06
0531834Ch:  8B 50 5C 51 55 57 8B CE FF D2 5F 5E 5D 5B C2 10
0531835Ch:  00 8B 44 24 20 50 55 57 FF 15 70 41 33 05 5F 5E
0531836Ch:  5D 5B C2 10 00 CC CC CC CC CC CC CC CC CC CC CC
0531837Ch:  CC CC CC CC 83 7E 4C 00 7E 3A 80 7E 2C 00 74 08
Stack (0012CADCh):
0012CABCh:  00000000 B77220E8 B7721D64 7FFDE6CC
0012CACCh:  B7721E24 80535230 804D8FD8 FFFFFFFF
0012CADCh:  00000000 0012CB54 05318310 0012CB18
0012CAECh:  00000000 7E368734 013609D6 00000002
0012CAFCh:  00000000 00000000 05318310 DCBAABCD
0012CB0Ch:  00000000 0012CB54 05318310 0012CB80
0012CB1Ch:  7E368816 05318310 013609D6 00000002
0012CB2Ch:  00000000 00000000 00000000 013609D6
0012CB3Ch:  0012FE01 00000014 00000001 00000000
0012CB4Ch:  00000000 00000010 00000000 0012CBC4
0012CB5Ch:  00000001 00000000 00000000 0012CB34
0012CB6Ch:  0012C700 0012CBC4 7E390457 7E368830
0012CB7Ch:  00000000 0012CBD4 7E36B4C0 00000000
0012CB8Ch:  05318310 013609D6 00000002 00000000
0012CB9Ch:  00000000 007B06A4 00000001 FFFFFFFF
0012CBACh:  05E84548 0012FE01 00040000 00000000
0012CBBCh:  0012CBA8 0012C700 0012CC4C 7E390457
0012CBCCh:  7E36B4D0 FFFFFFFF 0012CBFC 7E36B50C
0012CBDCh:  007B0690 00000002 00000000 00000000
0012CBECh:  05318310 00000000 00000000 00000000
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00000000, EDX: 00000000
ESI: 05362358, EDI: 013609D6, EBP: 00000002, ESP: 0012CADC
Crash location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Loaded modules:
ntdll loaded at 7C900000h - 7C9AF000h
kernel32 loaded at 7C800000h - 7C8F5000h
COMCTL32 loaded at 773C0000h - 774C3000h
msvcrt   loaded at 77C00000h - 77C58000h
ADVAPI32 loaded at 77DC0000h - 77E6B000h
RPCRT4   loaded at 77E70000h - 77F02000h
Secur32   loaded at 77FE0000h - 77FF1000h
GDI32 loaded at 77F10000h - 77F57000h
USER32   loaded at 7E360000h - 7E3F0000h
SHLWAPI   loaded at 77F60000h - 77FD6000h
SHELL32   loaded at 7C9C0000h - 7D1D6000h
ole32 loaded at 774D0000h - 7760D000h
COMDLG32 loaded at 76390000h - 763D9000h
guard32   loaded at 003D0000h - 003ED000h
fltLib   loaded at 4DD60000h - 4DD68000h
winsta   loaded at 76340000h - 76350000h
NETAPI32 loaded at 67270000h - 672C4000h
ws2_32   loaded at 71A90000h - 71AA7000h
WS2HELP   loaded at 71A80000h - 71A88000h
uxtheme   loaded at 5B250000h - 5B288000h
nview loaded at 00A80000h - 00BEF000h
PSAPI loaded at 76BE0000h - 76BEB000h
OLEAUT32 loaded at 77110000h - 7719B000h
WINMM loaded at 76B30000h - 76B5D000h
VERSION   loaded at 77BF0000h - 77BF8000h
NTMARTA   loaded at 77680000h - 776A1000h
WLDAP32   loaded at 76F50000h - 76F7D000h
SAMLIB   loaded at 71BD0000h - 71BE3000h
NVWRSCS   loaded at 00D30000h - 00D76000h
MSCTF loaded at 746F0000h - 7473B000h
foo_abx   loaded at 00DD0000h - 00E03000h
foo_ac3   loaded at 00E30000h - 00E5F000h
foo_adpcm loaded at 00E80000h - 00ED2000h
foo_albumlist loaded at 00F00000h - 00F55000h
foo_audioscrobbler   loaded at 00F80000h - 00FB8000h
foo_autoplaylist loaded at 00FE0000h - 01012000h
foo_bitcompare   loaded at 01040000h - 01066000h
foo_browser   loaded at 01090000h - 010C9000h
foo_cdda loaded at 010F0000h - 01123000h
foo_channel_mixer loaded at 01150000h - 0118B000h
foo_converter loaded at 011A0000h - 01212000h
foo_cuesheet_creator loaded at 01240000h - 0126D000h
foo_cwb_hooks loaded at 01290000h - 012DD000h
foo_dbsearch loaded at 01300000h - 0135C000h
foo_discogs   loaded at 01380000h - 013F2000h
gdiplus   loaded at 4EBE0000h - 4ED83000h
foo_dsp_centercut loaded at 01420000h - 01445000h
foo_dsp_continuator   loaded at 01470000h - 0149F000h
foo_dsp_crossfader   loaded at 014B0000h - 0150D000h
libmmd   loaded at 01520000h - 017D1000h
MSVCR80   loaded at 78130000h - 781CB000h
foo_dsp_delta loaded at 01800000h - 0181E000h
foo_dsp_silence   loaded at 01840000h - 01869000h
foo_dsp_skip_silence loaded at 01890000h - 0189A000h
foo_dsp_soundtouch   loaded at 018B0000h - 018BF000h
MSVCP80   loaded at 7C420000h - 7C4A7000h
foo_dsp_std   loaded at 018D0000h - 01917000h
foo_dsp_vlevel   loaded at 01940000h - 01964000h
foo_fileops   loaded at 01990000h - 019D6000h
foo_freedb2   loaded at 01A00000h - 01A41000h
foo_input_alac   loaded at 01A70000h - 01A8D000h
foo_input_awma   loaded at 01AB0000h - 01AC9000h
WMVCore   loaded at 15110000h - 1536A000h
WMASF loaded at 11C70000h - 11CA9000h
foo_input_dts loaded at 01AE0000h - 01B45000h
foo_input_matroska   loaded at 01B70000h - 01BF6000h
foo_input_monkey loaded at 01C20000h - 01C69000h
foo_input_mslive loaded at 01C90000h - 01CAE000h
foo_input_shorten loaded at 01CC0000h - 01CEE000h
foo_input_std loaded at 01D10000h - 01E35000h
foo_input_tta loaded at 01E60000h - 01E8D000h
foo_lnk   loaded at 01EB0000h - 01EC9000h
foo_lyricsdb loaded at 01EF0000h - 01F0E000h
WININET   loaded at 771A0000h - 77246000h
CRYPT32   loaded at 77A70000h - 77B05000h
MSASN1   loaded at 77B10000h - 77B22000h
foo_managedWrapper   loaded at 01F20000h - 01FC2000h
mscoree   loaded at 79000000h - 79045000h
msvcm80   loaded at 7C4C0000h - 7C53D000h
mscorwks loaded at 79E70000h - 7A3D6000h
mscorlib.ni   loaded at 790C0000h - 79B90000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh   loaded at 0FFD0000h - 0FFF8000h
System.ni loaded at 7A440000h - 7AC06000h
System.Drawing.ni loaded at 7ADE0000h - 7AF6C000h
System.Windows.Forms.ni   loaded at 7AFD0000h - 7BC54000h
xpsp2res loaded at 20000000h - 20502000h
dotnet_title loaded at 11000000h - 11014000h
foo_masstag   loaded at 04980000h - 049CF000h
foo_masstag_addons   loaded at 04AF0000h - 04AFE000h
foo_midi loaded at 04B10000h - 04BBA000h
foo_packet_decoder_ac3   loaded at 04BE0000h - 04C07000h
foo_packet_decoder_wavpack   loaded at 04C30000h - 04C55000h
foo_playback_custom   loaded at 04C80000h - 04CC5000h
WINSPOOL loaded at 72FC0000h - 72FE6000h
foo_playlist_bind loaded at 04D10000h - 04D35000h
foo_playlist_manager loaded at 04D50000h - 04D96000h
foo_playlist_tree loaded at 04DC0000h - 04E35000h
libmzsch360_000   loaded at 10400000h - 105D0000h
WSOCK32   loaded at 71AB0000h - 71ABA000h
libmzgc360_000   loaded at 04E60000h - 04F04000h
foo_pqview   loaded at 04F50000h - 04F6C000h
foo_prettypop loaded at 04F90000h - 04FDD000h
foo_random   loaded at 05090000h - 050CF000h
foo_removeplayed loaded at 050D0000h - 050E8000h
foo_rgscan   loaded at 05100000h - 05146000h
foo_run   loaded at 05170000h - 0519B000h
foo_scheduler loaded at 051C0000h - 0522F000h
POWRPROF loaded at 74AA0000h - 74AA8000h
foo_scrobblecharts   loaded at 05250000h - 05283000h
foo_tradersfriend loaded at 052B0000h - 052ED000h
foo_uie_albumart loaded at 05310000h - 0534A000h
foo_uie_albumlist loaded at 05370000h - 053B3000h
foo_uie_lyrics   loaded at 053E0000h - 05441000h
foo_uie_lyrics_panel loaded at 05470000h - 054D9000h
foo_uie_powerpanels   loaded at 05500000h - 05523000h
foo_uie_pvt   loaded at 05550000h - 05582000h
foo_uie_queuemanager loaded at 055B0000h - 055E9000h
foo_uie_quicksearch   loaded at 05690000h - 056D6000h
foo_uie_vis_channel_spectrum loaded at 05700000h - 05728000h
MSIMG32   loaded at 76360000h - 76365000h
foo_uie_vis_egoh loaded at 05750000h - 0576D000h
foo_uie_vis_projectm loaded at 05780000h - 057CC000h
OPENGL32 loaded at 5F210000h - 5F2DC000h
GLU32 loaded at 61AE0000h - 61B01000h
DDRAW loaded at 73720000h - 73769000h
DCIMAN32 loaded at 73B80000h - 73B86000h
foo_ui_columns   loaded at 05C90000h - 05D56000h
foo_ui_panels loaded at 05D80000h - 05E69000h
IMM32 loaded at 76370000h - 7638D000h
foo_ui_std   loaded at 05E90000h - 05F44000h
foo_unpack   loaded at 05F70000h - 05F9E000h
foo_utils loaded at 05FC0000h - 05FF9000h
foo_utils_matroska   loaded at 06020000h - 0603A000h
foo_verifier loaded at 06060000h - 06090000h
foo_version   loaded at 060B0000h - 060D5000h
dbghelp   loaded at 59C50000h - 59CF1000h
nvwddi   loaded at 06BC0000h - 06BD5000h
ctagent   loaded at 06BE0000h - 06BE6000h
mswsock   loaded at 71A30000h - 71A70000h
DNSAPI   loaded at 76F10000h - 76F37000h
rasadhlp loaded at 76FB0000h - 76FB6000h
System.Xml.ni loaded at 637A0000h - 63D02000h
imagehlp loaded at 76C80000h - 76CA8000h
Address: 05318310h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 7E368734h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E368816h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E390457h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 7E368830h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+00000169h)
Address: 7E36B4C0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E36B4D0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E36B50Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E36B473h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E36DAF6h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DestroyWindow" (+0000000Ch)
Address: 05D90AAAh, location: "foo_ui_panels", loaded at 05D80000h - 05E69000h
Address: 01DA0812h, location: "foo_input_std", loaded at 01D10000h - 01E35000h
Address: 004E6BA8h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0046946Bh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004B2795h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0042E08Fh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004AD9C7h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004E6B00h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004ACE5Bh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004B707Eh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0049D420h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004AD925h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004AC5A3h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 7C9037BFh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlConvertUlongToLargeInteger" (+0000007Ah)
Address: 7C903804h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlConvertUlongToLargeInteger" (+000000BFh)
Address: 7C90378Bh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlConvertUlongToLargeInteger" (+00000046h)
Address: 004B70BCh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 7C937B48h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlUnwind" (+00000108h)
Address: 004E7528h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0532BC10h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0533CB40h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 05332AC8h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 7C90D625h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "ZwContinue" (+0000000Ch)
Address: 7C937B75h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlUnwind" (+00000135h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000117h)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C910023h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlNtStatusToDosErrorNoTeb" (+0000049Ah)
Address: 004AC554h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 7C91001Bh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlNtStatusToDosErrorNoTeb" (+00000492h)
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C91003Bh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlNtStatusToDosErrorNoTeb" (+000004B2h)
Address: 0532BBC1h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 7C910945h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAcquirePebLock" (+00000028h)
Address: 7C91094Eh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAcquirePebLock" (+00000031h)
Address: 7C914190h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlDosPathNameToNtPathName_U" (+00000093h)
Address: 7C901005h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlEnterCriticalSection" (+00000000h)
Address: 7C910970h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReleasePebLock" (+0000000Fh)
Address: 7C97E4C0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Address: 7C913E6Fh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlDetermineDosPathNameType_U" (+000004D0h)
Address: 7C913E62h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlDetermineDosPathNameType_U" (+000004C3h)
Address: 004AD35Ah, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004AD396h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004AD3DFh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004AD419h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004AD7ACh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004E7550h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004AD991h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 7C9037D8h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlConvertUlongToLargeInteger" (+00000093h)
Address: 004B7557h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 7C937860h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "LdrAddRefDll" (+00000247h)
Address: 7C911B09h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlLogStackBackTrace" (+00000025h)
Address: 7C90EAFAh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "KiUserExceptionDispatcher" (+0000000Eh)
Address: 7C812A5Bh, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RaiseException" (+00000052h)
Address: 7C90EAD0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "KiUserCallbackDispatcher" (+00000000h)
Address: 0049B7A5h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0040C54Bh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0040447Fh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004A0D05h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 00486294h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004D2764h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004D2718h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004D2E40h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 7C809382h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetTickCount" (+000000E6h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 0049B786h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004ED448h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004CAA48h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004B4380h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004219F1h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 05320226h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0532119Bh, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 05332B21h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0531FD36h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 053211BAh, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0531716Dh, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0531FF2Dh, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0531FF3Fh, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 05332AF0h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0531563Ah, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 05335EFCh, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 7C90EE00h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+000000FFh)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 05335BBBh, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 053210B0h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 05335ED0h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 05321000h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0531500Eh, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 053336A3h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 05315DF4h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 05336740h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0049B77Ch, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 05333908h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0531AE06h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 05D39DE0h, location: "foo_ui_columns", loaded at 05C90000h - 05D56000h
Address: 05324BAFh, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 004EDF78h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 05336780h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0533615Ch, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 053368D0h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 05333A35h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Address: 0531A664h, location: "foo_uie_albumart", loaded at 05310000h - 0534A000h
Version info:
UNICODE
Windows 5.1
Additional info:
Audioscrobbler 1.3.2  (foo_audioscrobbler)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
foo_lyricsdb 0.0.7 beta 4  (foo_lyricsdb)
Center Cut 1.0.1  (foo_dsp_centercut)
Skip silence 0.1  (foo_dsp_skip_silence)
ALAC Decoder 1.0  (foo_input_alac)
Continuator 0.4.1  (foo_dsp_continuator)
Egoh Spectrum analyser (uie) 1.1.2  (foo_uie_vis_egoh)
Scheduler 3.53  (foo_scheduler)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
OKI-ADPCM decoder 0.14  (foo_adpcm)
Remove played Files 1.3.0  (foo_removeplayed)
mslive streaming support 0.1.6.3  (foo_input_mslive)
cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]  (foo_cwb_hooks)
SoundTouch DSP 0.1  (foo_dsp_soundtouch)
RAC decoder 1.0  (foo_adpcm)
DTS decoder 0.1.7  (foo_input_dts)
Cuesheet Creator 0.4.5  (foo_cuesheet_creator)
Pretty Popup 1.2.3  (foo_prettypop)
ATSC A/52 (AC3) Packet Decoder 0.9  (foo_packet_decoder_ac3)
Seek Panel 0.1  (foo_uie_powerpanels)
Channel Spectrum panel 0.07  (foo_uie_vis_channel_spectrum)
Lyric Show Panels 0.3.1.1b8 DEV [Sep  7 2007 - 13:57:42]  (foo_uie_lyrics)
Matroska Plugin 0.9.1.2  (foo_input_matroska)
Volume Panel 0.1  (foo_uie_powerpanels)
freedb Tagger 0.5.2.1  (foo_freedb2)
Channel Mixer 0.9.6.2  (foo_channel_mixer)
Masstagger Addons 0.3.2  (foo_masstag_addons)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
BRR decoder and converter 0.7  (foo_adpcm)
GCN DSP decoder 1.2  (foo_adpcm)
Acro WMA decoder 0.1.5  (foo_input_awma)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Masstagger 1.6  (foo_masstag)
kode's ADPCM decoders 1.2  (foo_adpcm)
Shell link resolver 1.1  (foo_lnk)
Live show tagger 0.6.1  (foo_tradersfriend)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
NGPV Preview 0.0.2 A  (foo_uie_pvt)
MIDI synthesizer host 1.7  (foo_midi)
Discogs Tagger 0.92  (foo_discogs)
foo_managedWrapper 0.3  (foo_managedWrapper)
Shorten decoder 0.4.2a  (foo_input_shorten)
Run services 0.3.2  (foo_run)
Database search 1.3.1 beta 11  (foo_dbsearch)
VLevel 20060324.0  (foo_dsp_vlevel)
Playlist Manager 1.0  (foo_playlist_manager)
File Integrity Verifier 1.0.1  (foo_verifier)
Matroska Utility Plugin 1.0.2  (foo_utils_matroska)
Playback Statistics Custom 1.4.2  (foo_playback_custom)
Post-track silence 0.0.2  (foo_dsp_silence)
Randomized playlist entry 1.2.3  (foo_random)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
AC3 decoder 0.9  (foo_ac3)
XA ADPCM decoder 1.2  (foo_adpcm)
Binary comparator 1.0  (foo_bitcompare)
Interplay ACM decoder 1.0  (foo_adpcm)
Playlist Bind 2.2  (foo_playlist_bind)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]  (foo_cwb_hooks)
Components versions viewer 0.1  (foo_version)
projectM visualization (Panel) 0.4 (SSE2)  (foo_uie_vis_projectm)
Playlist tools 0.5.7  (foo_utils)
WavPack Packet Decoder 0.9.0  (foo_packet_decoder_wavpack)
TTA Audio Decoder (unofficial) 2.4.1  (foo_input_tta)
Playlist Tree Panel 3.0.BETA_3 [Apr  3 2007 - 11:39:32]  (foo_playlist_tree)
Gapless Crossfader 0.3.2.2 (Intel SSE)  (foo_dsp_crossfader)
Lyrics panel 0.35  (foo_uie_lyrics_panel)
ADX decoder 1.6  (foo_adpcm)
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Converted code to codebox.[/size]
Reply #49
It seems that foo_uie_albumart crushes like that because of some configuration incompatibility. I've got rid of this kind of crush after some switching between default UI and Columns UI while adding/removing foo_uie_albumart to/from components folder. BUT after I made foobar started with foo_uie_albumart on board it crushed on track switching with error 123 (no pretty dump this time). According to specs it is: 123 The file name, directory name, or volume label syntax is incorrect.  ERROR_INVALID_NAME . More tweaking revealed that on Vista it caused by source strings like -$replace(%path%,%filename_ext%,)cover.jpg or -$replace(%path%,%filename_ext%,)folder.jpg. Source strings like $replace(%path%,%filename_ext%,)scans\*.jpg or --components\default.* or $replace(%path%,%filename_ext%,)%album%*.jpg work just fine.
