Topic: looking for Plugin (Read 1028 times) previous topic - next topic
looking for Plugin
hi there,
I'm working with foobar2000 since 2 month, at last i had found and installed the UPNP Playback Addon. This is a very nice Addon, but now, i wanna playback my Music on all  uPNP Devices and on my PC at the same time. Is there a Plugin that can do this ?
Thanks for all your help
greetings
z.
looking for Plugin
What you are looking for is called Playback Stream Capture.
If you have a smarter device with upnp support, you can simply connect to your current server and the option should be right there on the same topmost level where you would normally choose Playlists, Media Library, etc. For 'dumb' devices that still support HTTP, you can enable 'File/Options/Preferences/Tools/Upnp/Server/Internet access' in foobar. Then you can point those devices to the URL specified at the bottom of that page. You might need to port forward manually from within your router, though.
