Topic: Columns UI appearance (Read 3298537 times) previous topic - next topic
Reply #1750
mine...
Big fonts because it sits on my HTPC which is hooked up to my 55" TV.
Reply #1752
Hey Falstaff,
Great config. How do you do the expandable albums? Is it only CUI, or did you use other components like PSS?
Thanks for sharing.
PS: The deviant art link doesn't seem to work.
Reply #1754
Hey Falstaff,
Thanks for sharing.
Thank you. It's a CUI config tha use PSS as splitters and ELPLaylist for the playlist viewer, WSH Panel Mod for all the other panels except foo_quicksearch toolbar ans Shpeck for the Spectrum Channel vis!
>>> link is bad, here is the good one : http://br3tt.deviantart.com/art/Slate-1-0-279317532
Reply #1755
Thanks for the info.
I've just started putting a little more effort into customizing Foobar2K, and while I feel a bit overwhelmed by all there is to learn, it's great to see what it becomes when people put some effort into it . Still a while before I get there though!!!
Reply #1757
mine...
Very cool and nice for a big screen!
Can you please tell me what to do (download, install, configure) to get this exact same setting?
Many thanks in advance!
Reply #1758
mine...
It's actually a simple setup. You need:
foo ui columns (obviously)
foo uie albumlist (top left panel)
foo uie vis peakmeter spectrum
foo playcount
foo wave seekbar
foo uie wsh panel mod (only used for volume bar)
Reply #1759
Just start this
Reply #1760
Reply #1761
^ @nosgah - I have a feeling your layout is "DUI" (Default User Interface). This forum is named "Columns UI appearance" !!!
Reply #1762
that is most definitely columns UI. loads of reasons why it's easy to tell.
the playlist has left aligned/right aligned text in the group header. no playlists support this except NGplaylist
the playback buttons/seekbar/volume/visualisation are different to default UI and are instantly recognisable if you know columns UI.
there is a searchbox there (3rd party toolbars are not supported in default UI)
the status bar says it is an autoplaylist with a padlock icon (only columns UI does this)
i think i'll stop now.
Reply #1763
!!Colors!!, he got color in his columns
Reply #1764
Maybe you are right marc, I'm no expert on spotting these things.
But, the thing that made me say this is the "Facets" tab; I thought Facets could only be used as a pop-up window in CUI !?
The other thing is the sub-groupings; his playlist is rendering sub-groupings. Is that possible in Columns UI? If it is possible then can you explain how it's done. Thanks.
Reply #1765
Since I just posted this in another thread, I figured I'd toss it up here as well.
This is a quick layout I drafted upon upgrading to a new PC.
Layout was inspired in part from Winamp, as I used to use Winamp pretty heavily. Then threw in a few things for a foobar-esque flavor.
Basic layout took about 5 minutes to make, but I've been working on the scripting in various parts of the UI to fine-tune and polish it on and off for about a month or so.
I wish I could figure out how to use WSH panel mod to make some of the UI transparent, but I couldn't get it to work, so I gave up, and this is pretty much just vanilla CUI.
Color scheme, I couldn't change the grey of the status bars and everything (or I could, but then Windows looked all funny) so I settled on making a lighter color scheme to complement it. I'm still working on finalizing text colors.
Item details pane shows my attempt at working around the fact that it doesn't support $tab().
I'm quite impressed with the flexibility of both foobar and CUI.
This is what my foobar (DUI) looked like on my XP system. (OH GOD RUN!)
Yeah, I spent zero effort on it. XD
Reply #1766
With NGPlaylist
Reply #1767
wow!.. mind you sharing? ng code?
more or less, minus is best
Reply #1769
Original from: http://browse.deviantart.com/customization...r2000/#/d4fdfap
I modified/simplified the skin to my liking, removed most/all of the unnecessary code.
(Components: foo_ui_columns, foo_uie_panel_splitter, foo_uie_quicksearch, foo_uie_wsh_panel_mod, foo_wave_seekbar)
Reply #1770
@ quietus, mind sharing? thanks anyway
Reply #1771
@ Quietus, could you please share your setup for your wave-seekbar. unsure how to get the light grey & dark grey shading. thanks
Reply #1772
Here is a link to my settings, do a clean foobar2000 portable install and drop the files in that directory: http://www.mediafire.com/?3wyqez1fz2h1gey
@MDMA: Not sure where I got the script from, I do know I removed the ReplayGain part of it to reflect the original audio: http://pastebin.com/fG4YPqFS . Just tick the coloring boxes and choose.
Credit goes to the original theme developer at http://browse.deviantart.com/customization...r2000/#/d4fdfap
Reply #1773
The link to the original theme is botched, it has been shortened with ellipsis.
Stay sane, exile.
Reply #1774
Hi, guys. I'm posting a shot of my config.
I've just got a kinda newb question. Can I change the colour and backgrounf of the tabbed panels (Tab stack & Playlist tabs)? It'd be cool to be able, but I can't seem to find a way. I've seen other configs, who use tabs for navigation and the weren't the default ones, but I can't seem to do it. And if it's not possible is there any other way to get tabbed navigation and playlists? WSH panel? Thanks for the help
Dude.. you have got to put this up on deviant art or somewhere for us to grab.
