HydrogenAudio
Hosted Forums => foobar2000 => General - (fb2k) => Topic started by: Fullbar on 2021-10-21 17:16:20
Title: Resume last playback position on multiple files
Post by: Fullbar on 2021-10-21 17:16:20
Playing a long audio file, once exiting the file and starting foobar2000 up later it automatically plays back the last opened file from where i exited it.
When opening another file and exiting that file though, playing the previously played track starts it from the start instead of where I last left off
Is there an easy method of letting each file remember where I last played it, so that each file has a resume point on exit
Not like a manual bookmark, but an automatic book mark, like saving the last played position on exit
Title: Re: Resume last playback position on multiple files
Post by: dwmartin0906 on 2021-10-22 05:20:39
I don't know if this does what you want, or even works anymore, but you could take a look at foo_uie_bookmarks.  I tried it out a few years ago and it seemed to work OK, but I didn't really have a use for it.  The forum link is https://hydrogenaud.io/index.php?topic=46612.0.
Post by: darkflame23 on 2021-10-22 08:36:22
Just to say I've often wished for this feature in FB2k too. I'll check out the bookmarks component.
Post by: anamorphic on 2021-10-22 11:44:35
Skip Track (https://www.foobar2000.org/components/view/foo_skip) component is a newer alternative. Saves bookmark positions to database (not writing to tags) and updates automatically. Can also add a %bookmark% column to playlist.
