Topic: Noisy result when compressing raw to mp3 with lame (Read 6922 times) previous topic - next topic
Hello everyone,
I've been trying to compress a raw file with lame encoder to mp3. The resulting file plays out some of the original sound but covered in a lot of noise.
I also imported the file into audacity using import raw, and exported as an mp3 through lame and got a clean result - no noise.
The raw and mp3 files can be found here.
While importing to audacity i use the following settings :
32 bit float
Big-endian
1 Channel (Mono)
Start Offset 0 bytes
Amount to import 100%
Sample rate 44100 Hz
The command for lame command line is
lame -m m -r --bitwidth 32 123.raw --big-endian 123.mp3
If this topic has already been discussed, i apologize for the incorrect post and please direct me to it.
Best regards,
Gabriel
uhm, I think MP3 is limited to 16bit samples and it seems you are trying to compress 32bit audio data
no surprise to me that you get an MP3 of noise
try with bitwidth of 16 and you should be fine
Maggi
update:
I just listened to your 32bit raw file and it sounds horrible on my speakers, maybe because of those fairly loud high frequency portions.
However, even after exporting it to 16bit WAV and the compressing to mp3, it still sounds awefull, but both files sound similar to the raw file and are not as heavily compressed and distorted as your mp3 file
to sum it up, I don't know what's going wrong
Sorry
Maggi
update:
Sorry
I'm using lame encoder on linux could that be a problem.
Should i use a diffrent encoder?
Regards,
Gabriel
I think LAME treats input as 32-bit int, not 32-bit float. Convert your raw file from float type to integer and try to encode.
That's exactly what i tried after the last post and it worked. The ideea came to me from another post on this forum.
Thank you guys, you're life savers.
Regards,
Gabriel
I'm having the same problem with just noise as result - how do I convert the raw file from float to int?
Solved.
I added -x as an lame option and the noise was turned into sound.
