Topic: How to add a pin in directshow transform filter? (Read 5152 times) previous topic - next topic
Hi all, I am currently trying to build a new directshow transform filter.
I need this filter to take in 2 input pins. How should I go about doing this?
I have try to modify the code from the SDK but failed, this is my attempt, any help would be greatly appreciated, Thanks.
Amended from Null in place from directx SDK.:
//setup data
const AMOVIESETUP_PIN
psudPins[] = { { L"InputA"            // strName
              , FALSE              // bRendered
              , FALSE              // bOutput
              , FALSE              // bZero
              , TRUE              // bMany
              , &CLSID_NULL        // clsConnectsToFilter
              , L"Output"          // strConnectsToPin
              , 1                  // nTypes
              , &sudPinTypes }      // lpTypes
//My mod Start
         , { L"InputB"          // strName
              , FALSE                // bOutput
              , FALSE              // bZero
              , TRUE              // bMany
              , 1                  // nTypes
              , &sudPinTypes }
//My mod End
, { L"OutputA"          // strName
              , TRUE                // bOutput
              , FALSE              // bZero
              , FALSE              // bMany
              , L"Input"            // strConnectsToPin
              , 1                  // nTypes
              , &sudPinTypes }
                           };  // lpTypes
//the following code is also amended under GetPin
CBasePin *CNullInPlace::GetPin(int n)
    // Create the single input pin and the single output pin
    // If anything fails, fail the whole lot and clean up.
    if (m_pInput == NULL || m_pOutput == NULL)
        HRESULT hr = S_OK;
        m_pInput = new CNullInPlaceInputPin1(NAME("Null input pin1"),
                                          this,              // Owner filter
                                          &hr,              // Result code
                                          L"InputA");        // Pin name
        // a failed return code should delete the object
    //    if (FAILED(hr) || m_pInput == NULL)
  //        delete m_pInput;
  //        m_pInput = NULL;
  //          return NULL;
//My Mod Start
m_pInput = new CNullInPlaceInputPin2(NAME("Null input pin2"),
                                          &hr,              // Result code
                                          L"InputB");        // Pin name
            delete m_pInput;
            m_pInput = NULL;
            return NULL;
//My Mod End
        m_pOutput = new CNullInPlaceOutputPin(NAME("Null output pin"),
                                            &hr,            // Result code
                                            L"OutputA");      // Pin name
        // failed return codes cause both objects to be deleted
        if (FAILED(hr) || m_pOutput == NULL)
            delete m_pInput;
            m_pInput = NULL;
            delete m_pOutput;
            m_pOutput = NULL;
            return NULL;
I have done the above modification but it does not seems to work. In graph edit, I see only one input pin and one output pin, Being Input B and Output A.
My guess is that m_pInput is being assigned 2 times thus the first pin: InputA is being overwritten.
I did other modificiation also which include:
// Class definitions of input pin, output pin and filter
class CNullInPlaceInputPin1 : public CTransInPlaceInputPin
    public:
        CNullInPlaceInputPin1( TCHAR *pObjectName
                            , CTransInPlaceFilter *pTransInPlaceFilter
                            , HRESULT * phr
                            , LPCWSTR pName
                              : CTransInPlaceInputPin( pObjectName
                                                    , pTransInPlaceFilter
                                                    , phr
                                                    , pName
        HRESULT CheckMediaType(const CMediaType* pmt);
//My Mod start
class CNullInPlaceInputPin2 : public CTransInPlaceInputPin
    public:
        CNullInPlaceInputPin2( TCHAR *pObjectName
                            , HRESULT * phr
                            , LPCWSTR pName
                                                    , phr
                                                    , pName
      // HRESULT CheckMediaType(const CMediaType* pmt);
//My Mod End
class CNullInPlaceOutputPin : public CTransInPlaceOutputPin
    public:
        CNullInPlaceOutputPin( TCHAR *pObjectName
                            , HRESULT * phr
                            , LPCWSTR pName
                              : CTransInPlaceOutputPin( pObjectName
                                                      , phr
                                                      , pName
btw, what is class CNullInPlaceOutputPin  and m_pInput. Do we need to add in a new class and pointer if we need an additional pins.
And what did I do wrong and what is need to add in an extra input pin…
Thanks for all the attention.
