Topic: Wrong offset detection? (Read 2734 times) previous topic - next topic
I get different offset results with my ASUS DRW-1814BL.
1. Nero DiscSpeed creates test disc and says that offset is 0.
2. EAC creates test disc and says that offset is 0.
3. EAC with AccurateRip.dll. Accuraterip says that offset is +6.
Which offset is right?
Offset determined by Accuraterip I can't correct manualy - the box is inactive. How to change offset after Accuraterip work?
This is the combined read/write sample offset correction value.
This is the read sample offset correction value.
Both, unless you talk to this guy.  Based on the information you've given, your write samples offset is -6.
Start EAC without accuraterip.dll or upgrade to the most recent version.
