Topic: Preview mobile 1.4 - Song titles dissapear and get cryptic (Read 816 times) previous topic - next topic
Ever since I use the preview for 1.4 whenever I change a track, the song info is shown for not even 1 second and then suddenly changes to something like ef990fa2560ec2d79e0855e186bdde20.wav. I'm streaming from a media server with foobar2000 with the upnp plugin running.
Re: Preview mobile 1.4 - Song titles dissapear and get cryptic
I get the same thing trying to stream OptimFROG files with your exact use case. Monkey's Audio, FLAC, and TAK all stream fine.
Mobile: iPhone 7 iOS 15.7.6, foobar2000 beta 1.4 (28)
Desktop: x86 foobar2000 v2.1 preview 2023-08-11, foo_upnp Version 0.99.49
Appears this person is having a similar issue with his library: https://hydrogenaud.io/index.php/topic,124346.msg1030455.html#msg1030455
Thanks for your reply. So I am not the only one.
Just tried UniversalMediaServer as a streaming source and the same thing happens. Song info dissapears.
Fixed just now, thanks for reporting.
Thanks! Finally shows the correct info again. 👍
Bad news. When I use the seekbar while a track is playing, the song info disappears again and that cryptic file name shows up. I hope this can be fixed too
I can attest. I get the same result when trying to use the seekbar with the same use case as I've previously mentioned, otherwise, the title now appears perfectly fine.
Noted, will fix shortly, thanks for reporting.
Just updated. Works as it should now. Thanks!
