Topic: foo_run (Read 634056 times) previous topic - next topic
Re: foo_run
Reply #750
I can't start the program auCDtect Task Manager with parametrs "$if(%__referenced_file%,$directory_path(%path%)\%__referenced_file%,%path%)" - as a result, only one track is transferred to the program, despite the fact that I select everything in the playlist (trackwise)
Re: foo_run
Reply #752
It would be great to have a proper batch mode in this. I cannot run parallel processes on thousands of files because it will slow down Foobar2000 tremendously. There should be an option to run them one after the other.
Re: foo_run
Reply #753
Hell, I can't even get it to load the one track via commandline...  even if just specifying %path% it just starts with an empty list
Re: foo_run
Reply #754
Path would need to wrapped in quotes if it has whitespace in the path.
So "%path%" might fix your issue.
Re: foo_run
Reply #755
foo_run_xgrp solves the problem.
Re: foo_run Bug?
Reply #756
using fbk v1.6.16 and v.2.2preview parallel with foo_run 0.4.5 i discovered it does not behave exacly the same. i exported the foo_run.configuration.xml and imported it into v.2.2.
i want to open several files from different folders in mp3 tag (label "mp3tag open files")
while in fbk 1.6 it opens all selected files, in v.2.2 it only opens the files from the first selected folder.
this is unwanted. is there a change i have to make in the configuration of foo_run?
this ist my settings:
<root>
    <service minimized="false" num_exec="50">
        <label>mp3tag open files</label>
        <path>"D:\Programme\Mp3tag\Mp3tag.exe" /fn:"%path%"</path>
    </service>
    <service minimized="false" num_exec="1">
        <label>mp3tag open folder</label>
        <path>"D:\Programme\Mp3tag\Mp3tag.exe" "$replace(%_path%,%_filename_ext%,)"</path>
    </service>
        <label>Google Filename</label>
        <path>http://www.google.com/search?q=$replace(%filename%, ,+)&amp;ie=utf-8</path>
    </service>
        <label>Google Artist +  Album</label>
        <path>http://www.google.com/search?q=$replace(%artist%+%album%, ,+)&amp;ie=utf-8</path>
    </service>
        <label>Google Artist + Title</label>
        <path>http://www.google.com/search?q=$replace(%artist%+%title%, ,+)&amp;ie=utf-8</path>
    </service>
        <label>Google Artist</label>
        <path>http://www.google.com/search?q=$replace(%artist%, ,+)&amp;ie=utf-8</path>
    </service>
        <label>Discogs Artist + Title</label>
        <path>https://www.discogs.com/search/?q=$replace(%artist%+%title%, ,+)&amp;ie=utf-8</path>
    </service>
        <label>Discogs Filename</label>
        <path>https://www.discogs.com/search/?q=$replace(%filename%, ,+)&amp;ie=utf-8</path>
    </service>
        <label>Set Write Protection</label>
        <path>attrib.exe +r "%path%"</path>
    </service>
        <label>Remove Write Protection</label>
        <path>attrib.exe -r "%path%"</path>
    </service>
        <label>OpenAs...</label>
        <path>rundll32.exe shell32.dll,OpenAs_RunDLL %_path%</path>
    </service>
        <label>$if(%link%,Follow %link%,No link available)</label>
        <path>"%link%"</path>
    </service>
        <label>Discogs Album</label>
        <path>https://www.discogs.com/search/?q=$replace(%album%, ,+)&amp;ie=utf-8</path>
    </service>
</root>
i want to add, after playing with foo_run a little and testing foo_run_xgrp and having both installed at the moment, foo_run partially behaves more than before.
its a bit irritating. sometimes it loads all files, then not.
also when uninstalling foo_run, the configuration remains
