Topic: Album Art Size Syntax (Read 918 times) previous topic - next topic
Hey guys... I just need some help with syntax for making a custom column for "album art size" (to show the dimensions of the displayed art, 1200x1200, etc).  I looked through some of the syntax reference pages but couldn't find anything, so any help is appreciated.  Thanks.
Re: Album Art Size Syntax
You won't find it because it doesn't exist.
I do have a component for it but it works for embedded front covers only. Note the requirements here...
https://marc2k3.github.io/component/cover-utils/
This is the part you need to pay attention to:
https://marc2k3.github.io/component/cover-utils/#scan-for-info
That's great... embedded front covers is exactly what I'm working with.  Basically, I was finding I didn't have an efficient way to browse through and locate what older low res covers I wanted to replace with better ones, so I wanted to easily identify the image dimensions as I look through my library... so I will try this out, and thanks for this.
*edit*  Just tried it out.  Easy to set up and works perfectly for my needs.  Thanks again.
