Topic: foo_flowin, Floating window for Default UI (Read 27943 times) previous topic - next topic
Re: foo_flowin, Floating window for Default UI
Reply #100
there is a white line between the splitters .
Is it possible to hide those lines between the panels ?
Reply #102
^ DUI always has visible splitters. Turning on "Dark Mode" (in DUI) should make them dark, though still visible, unless setting the background color (in DUI) to the same color as the splitters to hide them.
Reply #103
Thanks you I will try it
