Hi I'm ussing EAC v1.0 beta 3 & Flac v1.2.1
I tried evrything but I can't embande the Cover (AlbumArt) inside Flac file with EAC.
My settings in JPG you can see http://tinyurl.com/p4w5ns3 (http://tinyurl.com/p4w5ns3)
My command line is
-1 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
What am I doing wrong?
tnx
Please confirm that you have a method that, before encoding, saves the image referred to as %coverfile% to the location where your option tells EAC to look. Otherwise, if there is no image, of course EAC cannot embed it.
Quoting a PM here because I have no intention of taking sole responsibility to provide private answers to questions that were asked in a public thread:
What do you mean how I tell EAC where to look?
Here:
(http://i.imgur.com/JBiqBAQ.png)
There has to be a metadata lookup to provide that image that is to be written with that file name. Otherwise, you have to provide the image yourself, again with the given name. That file name will be substituted for %coverfile% in your command line. Therefore, if the image does not exist, it cannot be written to the FLAC.
My settings in JPG you can see ...
Look at the file "03_Compression Options 04.jpg". You need to check "Add cover image to ID3V2 tag".
This is fairly misleading because of the absence of ID3 tags in FLAC and should be "Add cover image to tag".
Greetings, ...
