Topic: [feature suggestion] Additional custom tabs in the properties dialog (Read 889 times) previous topic - next topic
I have no idea how feasible this is with the present foobar2000 architecture, but something I would find very useful is the possibility to group standard fields by category and show each category in separate tabs in the properties window. Since I started using foobar, the list of my standard fields has become pretty long and the suggested feature would greatly improve readability and editing of the tags.
I'm late
Re: [feature suggestion] Additional custom tabs in the properties dialog
Might not be exactly what you want, but you can customize File/Preferences/Advanced/Display/Properties dialog/Standard fields. Adding "; = ;" between or at the end of your usual tags essentially creates a separator (empty line) in your Properties window. All the tags you define there will show up exactly in order and according to your formatting as well, while all unknown tags will be at the bottom enclosed as <TAGS>.
Might not be exactly what you want...
It is actually very close! I didn't know about this trick, thanks a lot.
I'm late
Daeron, is there a way to insert more than one empty row? I trusted I could just repeat that syntax as many times as needed, but only the first one works, the following are ignored.
I'm late
Sorry for the stupid question, I didn't realize that "; = ;" is not a special expression, but the standard syntax for renaming custom fields, therefore I's trying to rename twice the same custom field. I solved the issue by adding a new custom field for each separator (e.g. "; =separator1; =separator2;")
Rephrasing my initial feature suggestion: rather than additional custom tabs, I would settle for the option to add separator lines with a blue title, in a similar fashion as in the details tab.
I'm late
