Topic: change the order of the lines on the cue sheet (Read 820 times) previous topic - next topic
hello everyone.
I've just started using cuetools and I find it really interesting. My question is about the .cue files generated when I create an image file + cue sheet from separate tracks.
Is there a way to change the order of the lines in the cue sheet before starting the operation? and if so, is there a way to make it the default?
Example (this is a part of the automatically generated cue):
REM COMMENT “CUETools generated CUE sheet”
PERFORMER “Black Wings”
TITLE “Whispers Of Time”
REM DATE 2024
REM DISCNUMBER 1
REM TOTALDISCS 1
REM GENRE “Metal”
FILE “Black Wings - Whispers Of Time.flac” WAVE
TRACK 01 AUDIO
TITLE “Opening the Gates”
Instead, I would like the order of the lines to always be like this:
REM GENRE “Metal”
REM DATE 2024
REM COMMENT “CUETools generated dummy CUE sheet”
REM DISCNUMBER 1
REM TOTALDISCS 1
TRACK 01 AUDIO
Thanks in advance
Re: change the order of the lines on the cue sheet
There is a setting to remove
REM COMMENT “CUETools generated dummy CUE sheet”[1]
but there isn't a setting to change the order of the lines.
Change WriteDummyCUESheetComment=1 to WriteDummyCUESheetComment=0 in the settings.txt file while CUETools is closed
korth
thanks for the explanation
