Topic: Workflow for CDs missing from MusicBrainz (Read 17620 times) previous topic - next topic
When I rip a CD that's not in musicbrainz, what's the best workflow? Right now I add it to musicbrainz, but then CueRipper doesn't seem to see it. I understand that there's some caching layer in between musicbrainz and cuetools? Is there a way to get it to refresh? Or do I just need to type everything in? I'd rather not do that twice if possible.
Re: Workflow for CDs missing from MusicBrainz
Any new information added to MusicBrainz after 10/2023 has not been updated to the CUETools DataBase.
The issue was reported but not fixed.
At present, CUERipper can only retrieve MusicBrainz metadata from the CUETools DataBase.
Alternative search/retrieval methods have been requested.
korth
They should implement AccurateRip Meta also.
@spoon
Andre Wiethoff has offered to assist with the coding to implement AccurateRip Meta but unfortunately I lack the necessary skill-set.
korth
Thank you for the response, it seems like my best option is to type it in.
If you like MusicBrainz as a source, it makes sense to use their tagger.
https://picard.musicbrainz.org/
@spoon
It will be updated to accept submissions from users, other than that it is already coded.
Sorry, I was referring to the code for the Pull Request.
korth
seems never finished with code. late response
