MAREO settings to organize FLAC & MP3 files using EAC
Reply #29 – 2006-10-10 10:46:18
Yes, presumably only if the VA checkbox is checked as well. NB: with regard to the space either side, EAC (wrongly?) seems to deal with either a space or no space. If a space is present it is trimmed. I suppose it's not so wrong as it has the checkbox double check - so it is expecting a VA format. so, should i be strict, and support " / " as the delimiter? Well, no. EAC will parse the track names and split them into their component parts before you get to them. It seems to me that your only option would be to do as REACT is doing, or similar. You need to use the original filename (%o) to make your decision. In order for that to happen you need to insist that users set their EAC naming scheme to begin with %D (CD Artist). You need to analyse the original filename (%o), and if the first seven characters of %o are "Various" then you do the VA stuff. I have created a test config for REACT , that will output all available information to a log file but encode nothing. I would suggest that you do the same for MAREO, so no encoding takes place, but all params for each track are output to a text file, so that you can see exactly what information is being received, and what you have to play with. Edit: In actual fact, looking at the REACT source, it will actually raise a warning if the naming scheme (or VA naming scheme if one exists) does not begin with %D or contains a "\".If StringLeft($c, 2) <> "%D" Or StringInStr($c, "\") > 0 Then MsgBox(0+48+8192, $g_appTitle, "EAC active naming scheme must start with '%D' and not contain '\'" & @crlf & _ "Please, press Ctrl-F2 to configure EAC for use with REACT") EndIf $c is the relevant naming scheme, taken from the registry value. I'm not suggesting that MAREO needs to do this, but it raises the issue, if your users want VA recognition then they need to adhere to some guidlines. Also, I've just taken a look at the MAREO website and I see that you don't actually pass %o at the moment.
