Topic: How to setup a simple web server (Read 12444 times) previous topic - next topic
Reply #50
ok its off, please try now.
But how do i configure it so i dont have to turn it off?
Reply #51
Testing new server! The script goes here
Don't know about Zonealarm - its been a long time since i used it
Reply #52
yesssssssssssssssss
So its zonealarm causing all the problems in my life
How about now, I think I have allowed port 80 with zonealarm
Thanks a lot
[edit - would i need to allow both incomming and outgoing for port 80?]
Reply #53
You're still up
yes both Incoming (you wouldn't see HA if incoming was off, or any other webpages) & outgoing (webserver) have to on
Maybe you should append your sig with your www now, so that I don't have to hop back to page 2 to find the link?
PS - Found out that my ISP blocks port 25 incoming & outgoing, so no e-mail for me
should check with yours - jen@<domain_name>.dyndns.org sounds good, no?
Edit - wish zonealarm was causing the problems with my VISA  - I'd uninstall it right away!
Edit: Removed information for respect of privacy
Reply #54
What!  its still working  (w00t)
OK i will add it to my www.  Thanks for the tip
Reply #55
"Testing new server! The script goes here"
So now maybe some clue about what is going to be on there after all this - do i still get to be an admin?
Reply #56
All will be revealed soon
Reply #57
Well with a URL you can do a reverse DNS lookup to get the IP
213.242.68.206  | so-11-0.hsa2.Stockholm1.Level3.net             | Stockholm, Sweden    | +01:00 | 135 |
213.242.69.10  | ge0-0-0-0.r1.sto1.se.eunetip.net               | ...                  |        | 137 |
213.192.191.129 | so3-0-0-0.br1.hel1.fi.eunetip.net              | ...                  |        | 185 |
213.192.191.41  | ae0-0.br2.esp1.fi.eunetip.net                  | ...                  |        | 180 |         213.192.191.78  | ge0-1-0-0.r1.alto.esp.fi.eunetip.net           | ...                  |        | 168 |        62.142.101.201  | -                                              | ...                  |        | 179 |
62.142.11.51    | www.nic.fi                                     | ...                  |        | 144 |
Seems like your traceroute runs out about in Stockholm
but your webpage is located in Espoo, Finland - which corresponds to the last 2 entries esp.fi.eunetip.net
The    will be picking you up after they get Jen
Reply #58
But from Espoo to my current location is about 185km.
Reply #59
The    just found your telephone wire - they will be there soon after they follow it through 185Kms of sewers.
I guess they pulled the posts on Jen's location - I thought it was fun doing traceroutes on IPs
Reply #60
My dirty secret which will screw up the efforts of the  : The isp hosting my web page isn't the same which provides my dial-up internet connection. I hope that the g-men aren't too deep in the sewers. You should check this more carefully.
12/19/03 20:28:17 Fast traceroute hydrogenaudio.org
Trace hydrogenaudio.org (64.246.62.80) ...
1   No Response      *      *      *
2 212.63.11.193   138ms  293ms  125ms  TTL:  0  (rnal-08-FE-0-0-14.soon.fi ok)
3 212.246.46.36   176ms  186ms  657ms  TTL:  0  (rnal-10-GE-4-0-0-50.soon.fi ok)
4 139.97.7.29     160ms  124ms  121ms  TTL:  0  (No rDNS)
5 139.97.2.133    135ms  135ms  297ms  TTL:  0  (No rDNS)
6 139.97.2.150    132ms  116ms  193ms  TTL:  0  (No rDNS)
7 193.229.1.249   119ms  126ms  131ms  TTL:  0  (msfc-pa2-ge-3-1.hel.kolumbus.net ok)
8 193.229.255.35  128ms  118ms  132ms  TTL:  0  (m10-pa-ge0-1.hel.kolumbus.net ok)
9 193.229.1.61    137ms  130ms  128ms  TTL:  0  (kista10-so-1-0-0.sto.kolumbus.net ok)
10 62.248.254.38   134ms  140ms  137ms  TTL:  0  (kista11-ge0-1-0.sto.kolumbus.net ok)
11 213.242.67.17   158ms  158ms  150ms  TTL:  0  (ge-4-2-103.hsa1.Stockholm1.Level3.net ok)
12 213.242.68.142  150ms  160ms  265ms  TTL:  0  (so-8-0.hsa2.Stockholm1.Level3.net ok)
As you can see I only reveal information on me so this shouldn't bother the  .
