[span style=\'font-size:8pt;line-height:100%\']@GHammer[/span]
I've tried running MAREO with fb2k 0.9 Final with no luck too.
Experienced the same thing; MAREO runs, but nothing happened and I actually had to kill the process to stop it.
I haven't tried with fb2k 0.8.3, but maybe next time.
could you please post the full log?[{POST_SNAPBACK}][/a]
Here's the log for the first run.
mareo.ini is configured to run LAME, OggEnc 2.81 (Lancer), VorbisGain, FLAC, and WavPack using Wapet, in that order.
MAREO - Multiple Applications Runner for EAC and Others - GPL Licensed
3 beta - Copyright 2003-2006 by Kwanbis - [a href=\"http://www.webearce.com.ar/]http://www.webearce.com.ar/[/url]
Developed with Borland Delphi (info @ [url=http://borland.com/delphi/)]http://borland.com/delphi/)[/url]
*** Received Command Line ***
"C:\encoders\mareo\mareo.exe" mareo_normal.ini "D:\eac_wavs\0tmp1!542.wav" "D:\eac_wavs\0tmp1!542.mp3" "Craig David" "The Story Goes..." "All The Way" "01" 2005 "R&B"
*** Parsed Parameters ***
IniFileName (%1) = mareo_normal.ini
@source@ (%2) = D:\eac_wavs\0tmp1!542.wav
@dest@ (%3) = D:\eac_wavs\0tmp1!542.mp3
@artist@ (%4) = Craig David
@album@ (%5) = The Story Goes...
@title@ (%6) = All The Way
@track@ (%7) = 01
@year@ (%8) = 2005
@genre@ (%9) = R&B
*** INI Parameters ***
LogToScreen = TRUE
LogToFile = TRUE
RenameFirstFile = TRUE
DeleteWavFile = TRUE
*** PROCESSING ENCODER ORDER # 1 ***
ENCODER Extension = mp3
TEMPORAL Full Name = D:\eac_wavs\0tmp1!542.mp3
TEMPORAL Path Only = D:\eac_wavs
TEMPORAL Name Only = 0tmp1!542
FINAL Full Name = D:\My Music\MP3\Craig David - The Story Goes..\01 - All The Way.mp3
FINAL Path Only = D:\My Music\MP3\Craig David - The Story Goes..
FINAL Name Only = 01 - All The Way
Run Only If Last = FALSE
EXECUTING: C:\encoders\lame.exe -V2 --vbr-new -Y --ignore-tag-errors --ta "Craig David" --tl "The Story Goes..." --tt "All The Way" --tn "01" --ty "2005" --tg "R&B" "D:\eac_wavs\0tmp1!542.wav" "D:\eac_wavs\0tmp1!542.mp3" ... EXECUTION SUCCESS!!
DIRECTORY "D:\My Music\MP3\Craig David - The Story Goes.." does NOT exists, creating ... SUCCESS!!
RENAMING: D:\eac_wavs\0tmp1!542.mp3 => D:\My Music\MP3\Craig David - The Story Goes.\01 - All The Way.mp3 ... SUCCESS!!
*** PROCESSING ENCODER ORDER # 2 ***
ENCODER Extension = ogg
TEMPORAL Full Name = D:\eac_wavs\0tmp1!542.ogg
FINAL Full Name = D:\My Music\Vorbis\Craig David - The Story Goes..\01 - All The Way.ogg
FINAL Path Only = D:\My Music\Vorbis\Craig David - The Story Goes..
EXECUTING: C:\encoders\oggenc2.exe -q 4 "D:\eac_wavs\0tmp1!542.wav" -o "D:\eac_wavs\0tmp1!542.ogg" -a "Craig David" -l "The Story Goes..." -t "All The Way" -N "01" -d "2005" -G "R&B" ... EXECUTION SUCCESS!!
DIRECTORY "D:\My Music\Vorbis\Craig David - The Story Goes.." does NOT exists, creating ... SUCCESS!!
RENAMING: D:\eac_wavs\0tmp1!542.ogg => D:\My Music\Vorbis\Craig David - The Story Goes.\01 - All The Way.ogg ... SUCCESS!!
*** PROCESSING ENCODER ORDER # 3 ***
ENCODER Extension = NONE
TEMPORAL Full Name = D:\eac_wavs\0tmp1!542.NONE
FINAL Full Name = NONE
FINAL Path Only = NONE
FINAL Name Only = NONE
EXECUTING: C:\encoders\vorbisgain.exe "D:\My Music\Vorbis\Craig David - The Story Goes...\01 - All The Way.ogg" ... EXECUTION **ERROR**
"Final Full Name" is NONE, NO need to rename.
*** PROCESSING ENCODER ORDER # 4 ***
ENCODER Extension = flac
TEMPORAL Full Name = D:\eac_wavs\0tmp1!542.flac
FINAL Full Name = D:\My Music\FLAC\Craig David - The Story Goes..\01 - All The Way.flac
FINAL Path Only = D:\My Music\FLAC\Craig David - The Story Goes..
EXECUTING: C:\encoders\flac.exe -5 "D:\eac_wavs\0tmp1!542.wav" -o "D:\eac_wavs\0tmp1!542.flac" -T artist="Craig David" -T album="The Story Goes..." -T title="All The Way" -T tracknumber="01" -T date="2005" -T genre="R&B" ... EXECUTION SUCCESS!!
DIRECTORY "D:\My Music\FLAC\Craig David - The Story Goes.." does NOT exists, creating ... SUCCESS!!
RENAMING: D:\eac_wavs\0tmp1!542.flac => D:\My Music\FLAC\Craig David - The Story Goes.\01 - All The Way.flac ... SUCCESS!!
*** PROCESSING ENCODER ORDER # 5 ***
ENCODER Extension = wv
TEMPORAL Full Name = D:\eac_wavs\0tmp1!542.wv
FINAL Full Name = D:\My Music\WavPack\Craig David - The Story Goes..\01 - All The Way.wv
FINAL Path Only = D:\My Music\WavPack\Craig David - The Story Goes..
EXECUTING: C:\encoders\wapet.exe "D:\eac_wavs\0tmp1!542.wv" -t "Artist=Craig David" -t "Album=The Story Goes..." -t "Title=All The Way" -t "Track=01" -t "Year=2005" -t "Genre=R&B" "C:\encoders\wavpack.exe" -hm "D:\eac_wavs\0tmp1!542.wav" "D:\eac_wavs\0tmp1!542.wv" ... EXECUTION SUCCESS!!
DIRECTORY "D:\My Music\WavPack\Craig David - The Story Goes.." does NOT exists, creating ... SUCCESS!!
RENAMING: D:\eac_wavs\0tmp1!542.wv => D:\My Music\WavPack\Craig David - The Story Goes.\01 - All The Way.wv ... SUCCESS!!
DeleteWaveFile is TRUE.
DELETING: D:\eac_wavs\0tmp1!542.wav ... SUCCESS!!
*** DONE ***
1 errors ocurred. Press any key to end.
To sum it up, the directory created were :
[span style=\'font-size:8pt;line-height:100%\']- D:\My Music\MP3\Craig David - The Story Goes\
- D:\My Music\Vorbis\Craig David - The Story Goes\
- D:\My Music\WavPack\Craig David - The Story Goes\
- D:\My Music\FLAC\Craig David - The Story Goes\
[/span]There is no three periods at the end of the album name (i.e [span style=\'font-size:8pt;line-height:100%\']D:\My Music\MP3\Craig David - The Story Goes\[/span] instead of [span style=\'font-size:8pt;line-height:100%\']D:\My Music\MP3\Craig David - The Story Goes...\[/span]).
Note that the encoded files are placed correctly inside each respective directories.
The single error is because VorbisGain couldn't find the file.
Here's the second run with the previous encoded files still in their respective directories.
I'm using the same mareo.ini.
3 beta - Copyright 2003-2006 by Kwanbis - [url=http://www.webearce.com.ar/]http://www.webearce.com.ar/[/url]
"C:\encoders\mareo\mareo.exe" mareo_normal.ini "D:\eac_wavs\0tmp!58)5.wav" "D:\eac_wavs\0tmp!58)5.mp3" "Craig David" "The Story Goes..." "All The Way" "01" 2005 "R&B"
@source@ (%2) = D:\eac_wavs\0tmp!58)5.wav
@dest@ (%3) = D:\eac_wavs\0tmp!58)5.mp3
@track@ (%7) = 01
@year@ (%8) = 2005
@genre@ (%9) = R&B
LogToScreen = TRUE
LogToFile = TRUE
TEMPORAL Full Name = D:\eac_wavs\0tmp!58)5.mp3
TEMPORAL Name Only = 0tmp!58)5
EXECUTING: C:\encoders\lame.exe -V2 --vbr-new -Y --ignore-tag-errors --ta "Craig David" --tl "The Story Goes..." --tt "All The Way" --tn "01" --ty "2005" --tg "R&B" "D:\eac_wavs\0tmp!58)5.wav" "D:\eac_wavs\0tmp!58)5.mp3" ... EXECUTION SUCCESS!!
DIRECTORY "D:\My Music\MP3\Craig David - The Story Goes.." allready exists.
RENAMING: D:\eac_wavs\0tmp!58)5.mp3 => D:\My Music\MP3\Craig David - The Story Goes.\01 - All The Way.mp3 ... **ERROR**
TEMPORAL Full Name = D:\eac_wavs\0tmp!58)5.ogg
EXECUTING: C:\encoders\oggenc2.exe -q 4 "D:\eac_wavs\0tmp!58)5.wav" -o "D:\eac_wavs\0tmp!58)5.ogg" -a "Craig David" -l "The Story Goes..." -t "All The Way" -N "01" -d "2005" -G "R&B" ... EXECUTION SUCCESS!!
DIRECTORY "D:\My Music\Vorbis\Craig David - The Story Goes.." allready exists.
RENAMING: D:\eac_wavs\0tmp!58)5.ogg => D:\My Music\Vorbis\Craig David - The Story Goes.\01 - All The Way.ogg ... **ERROR**
TEMPORAL Full Name = D:\eac_wavs\0tmp!58)5.NONE
TEMPORAL Full Name = D:\eac_wavs\0tmp!58)5.flac
EXECUTING: C:\encoders\flac.exe -5 "D:\eac_wavs\0tmp!58)5.wav" -o "D:\eac_wavs\0tmp!58)5.flac" -T artist="Craig David" -T album="The Story Goes..." -T title="All The Way" -T tracknumber="01" -T date="2005" -T genre="R&B" ... EXECUTION SUCCESS!!
DIRECTORY "D:\My Music\FLAC\Craig David - The Story Goes.." allready exists.
RENAMING: D:\eac_wavs\0tmp!58)5.flac => D:\My Music\FLAC\Craig David - The Story Goes.\01 - All The Way.flac ... **ERROR**
TEMPORAL Full Name = D:\eac_wavs\0tmp!58)5.wv
EXECUTING: C:\encoders\wapet.exe "D:\eac_wavs\0tmp!58)5.wv" -t "Artist=Craig David" -t "Album=The Story Goes..." -t "Title=All The Way" -t "Track=01" -t "Year=2005" -t "Genre=R&B" "C:\encoders\wavpack.exe" -hm "D:\eac_wavs\0tmp!58)5.wav" "D:\eac_wavs\0tmp!58)5.wv" ... EXECUTION SUCCESS!!
DIRECTORY "D:\My Music\WavPack\Craig David - The Story Goes.." allready exists.
RENAMING: D:\eac_wavs\0tmp!58)5.wv => D:\My Music\WavPack\Craig David - The Story Goes.\01 - All The Way.wv ... **ERROR**
DELETING: D:\eac_wavs\0tmp!58)5.wav ... SUCCESS!!
*** DONE ***
5 errors ocurred. Press any key to end.
The errors, except VorbisGain's error which is the same as the first run, seemed to be caused by a faulty MAREO behaviour in handling directory names with periods at the end.
If you need more details, just ask.
I'll be more than willing to reply back. =)
