Topic: Container for multiple lossy tracks in one file? (Read 718 times) previous topic - next topic
Is there a container format that can be used for storing multiple lossy tracks in one file? I am trying to organize my library.
For lossless, a single FLAC file can hold multiple FLAC-encoded tracks, and a single M4A file can hold multiple ALAC-encoded tracks.
Are there any container formats that support doing something like this? Hopefully without transcoding the original lossy tracks.
Re: Container for multiple lossy tracks in one file?
Do you mean sequentially or concurrently? Ogg Vorbis and Opus files can be concatenated, this is called Ogg chaining.
Matroska audio (.mka)
Are you looking for a GUI muxer or are you OK with CLI? For CLI, use ffmpeg.
Example:
ffmpeg -i "audio.flac" -i "audio.aac" -map 0:a -map 1:a -c copy "test.mka"
For GUI use MKVToolNix.
MPEG-4 Part 14 (MP4) (.mp4) also supports this.
Again, I would use ffmpeg for CLI and YAMB with MP4Box for GUI. Alternative for GUI is also DVBPortal MP4Muxer.
ffmpeg -i "audio.mp3" -i "audio.aac" -map 0:a -map 1:a -c copy "test.mp4"
lame -V 0
Yes, but you are missing chapter markers in mka, and without them, foobar (or VLC) will play only 1st song. I've tried to do that with MKVToolBox, but failed to find the automatic way to create chapters for the album, for example.
mkvmerge can automatically create chapters when merging files.
When running this batch file in directory with *.mp3 files, they will be merged into one mka with chapters.
chcp 65001
cd /d "%~dp0"
@echo off &setlocal enabledelayedexpansion
set "line="
for %%a in (*.mp3) do set line=!line! +"%%~a"
"C:\Program Files\MKVToolNix\mkvmerge.exe" --generate-chapters when-appending -o "output.mka" %line:~2%
Files names should not contain symbol ^.
Works as a charm - now, to find a way to read song titles and put them into chapter names... :)
