Topic: 0.9.3 CPU Usage (Read 10699 times) previous topic - next topic
0.9.3 CPU Usage
Sometimes when a song changes (ex would be after playback queue played entirely or playlist on shuffle), my computer starts lagging for 15-30 seconds... the next song is on hold during that time and I wonder what might be the problem. Didn't do this under 0.9.2.
I think most of my components are up to date, I should check that out.
Anybody has the same problem?
If you need more info, ask me.
0.9.3 CPU Usage
I got that too.. using the same plugin (latest), same setting as 0.9.2
loading folder(s) not in Media Library is also slower in 0.9.3
now, I'm back on 0.9.2
0.9.3 CPU Usage
I had a weird component (which didn't work anyway for no apparent reason) it was the gap killer version 0.1 : foo_dsp_skip_silence.dll
And it seems to be ok now (might not be it though). I'll continue my "tests".
0.9.3 CPU Usage
U think Skip_Silence might cause this weird problem? Will test that, too, as it realy didn't work as i expect it to.
0.9.3 CPU Usage
No after using foobar for another couple hours I still have the same problem.  Skip silence is not the problem.
0.9.3 CPU Usage
Umm.. i realy dont know what the problem might be.. i used skip silence with 0.93b1 and b2, worked good. then i had another computer for some time (that sucked even more then mine does) and b3 came out, everything ok. The i added dsp_continuator, still worked fine. Final came out, guess what, worked fine ^^..
Ok, then i got my computer back, added continutor and upgraded to the final of 0.93. And now i got this high CPU usages. BUT as it starts when the crossfading of continuator normaly begins i think it might be continuators fault. Actualy i wont remove this plugin, somehow i cant explain why this happens. Perhaps it's some wrong settings? Cant believe that this plugin makes trouble. Perhaps someone of you could check this? Guess you guys use continuator too, otherwise we should post our version info and check out what plugins we all use...
0.9.3 CPU Usage
For some reason foobar 9.3 uses about 12 - 17 percent cpu usage on my comp when changing tracks, while foobar 9.2 with the same settings and plugins used 0 percent cpu and i noticed that the lastest version of foobar use more memory.
0.9.3 CPU Usage
Well since it's annoying I got back to 0.9.2  I liked the changes though.
0.9.3 CPU Usage
Seen that in the betas before, suffered from that just now, found this topic.
Yes, foobar does kill my windows, I even have problems killing fb2k. It is if it doesn't find a track in the playlist at startup, then it eats the full cpu... I wasn't even able to copy the console contents, here is a screenshot:
0.9.3 CPU Usage
I also, have this "CPU usage problem", never had it before, not even in 0.9.3 beta 4, It was working pefectly I don't know what it causing this problem.
Everything was working fine, and now foobar2000, eats more cpu than my game does, I play stacraft, and It loads full cpu, the game I mean, no matter what computer you have, but when I use foobar, now it lags a bit, I don't know why.
The CPU usage is causing this, my game needs almost 90% CPU usage, and Foobar is eating more than 40%, if anyone finds a solution please reort. I need to solve this, I <3 foobar
0.9.3 CPU Usage
quoting Death (Peter as far as I know) on foobar IRC channel:
disable the third party plugins
0.9.3 CPU Usage
I have this problem too, I'll seek for fb2k 0.9.2 again
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
0.9.3 CPU Usage
Big joke? but, perhaps i/we should try and find out if a plugin causes this problem and if yes, what plugin does.
0.9.3 CPU Usage
He's must be wrong. It's in the core. I only left the ui_standard, then ui_columns (deleted all other plugins), the problem appeared with both. Maybe there's something wrong with the foobar2000.cfg file (I don't know, as unfortunately its not plain text): After deleting it foobar starts up without a problem.
EDIT: I see I'm describing a different problem: constantly 100% cpu at startup, when fb2k doesn't find a track and when having "resume playback after restart" turned on.
0.9.3 CPU Usage
Yap, you describe something different  But I guess this is pretty annoying,  too. So it should be fixed
Any more information about the "Track-Change-CPU-Usage" problem?
0.9.3 CPU Usage
No issues here:
CPU: Intel® Pentium® 4 CPU 2.60GHz [x86 Family 15 Model 2 Stepping 9]
Operating System: Microsoft Windows XP [version: 5.1.2600 Service Pack 2]
Installed RAM: 511 MBytes
Free disk space on foobar2000 partition: 661 MBytes
foobar2000 path: D:\Program Files\foobar2000\
Core version: foobar2000 v0.9.3
Build time: 22:58:57 on 04 August 2006
Active components (26):
foo_albumlist.dll v3.2.0 [04 August 2006] - Album List
foo_burninate.dll v2.0.1 [20 June 2006] - Audio CD Writer
foo_cdda.dll v2.1.1 [04 August 2006] - CD Audio Decoder
foo_channel_mixer.dll v0.9.4 [12 April 2006] - Channel Mixer
foo_common.dll v0.1 [11 March 2006] - Common services
foo_converter.dll v1.0.1 [04 August 2006] - Converter
foo_dsp_std.dll v1.0 [04 August 2006] - Standard DSP array
foo_freedb2.dll v0.5.2 [12 July 2006] - freedb tagger
foo_input_std.dll v1.1.0 [04 August 2006] - FLAC decoder
foo_input_std.dll v1.0 [04 August 2006] - Standard Input Array
foo_masstag.dll v1.6 [04 August 2006] - Masstagger
foo_msnalt.dll v2.4 [10 April 2006] - MSN Now Playing (alt)
foo_playcount.dll v1.2 [17 July 2006] - Playback Statistics
foo_playlist_bind.dll v2.2 [06 April 2006] - Playlist Bind
foo_rgscan.dll v2.0.2 [04 August 2006] - ReplayGain Scanner
foo_sic.dll v1.0 beta 9 [16 July 2006] - foosic music database
foo_ui_columns.dll v0.1.3 beta 1v5 [29 April 2006] - Columns UI
foo_ui_std.dll v0.9acc [04 August 2006] - Default User Interface
foo_uie_albumlist.dll v0.2.1 beta 4 [28 April 2006] - Album list panel
foo_uie_console.dll v0.2 [28 April 2006] - Console panel
foo_uie_quicksearch.dll v2.8f [20 June 2006] - Quick Search Toolbar
foo_uie_tabs.dll v0.2.0 [01 July 2006] - Tabbed panel modifyed
foo_uie_trackinfo.dll v0.8 [03 May 2006] - Track info panel
foo_unpack.dll v1.0 [04 August 2006] - ZIP/GZIP reader
foo_unpack.dll v1.1 [04 August 2006] - RAR reader
foo_version.dll v0.3 [18 July 2006] - Components versions viewer
0.9.3 CPU Usage
CPU: AMD Athlon™ XP 1800+ [x86 Family 6 Model 8 Stepping 1]
Installed RAM: 512 MBytes
Free disk space on foobar2000 partition: 27639 MBytes
foobar2000 path: D:\Foobar\
Active components (18):
foo_converter.dll v1.0.1 [11 July 2006] - Converter
foo_dbsearch.dll v1.4 beta 4 [12 June 2006] - Database Search
foo_dsp_continuator.dll v0.4.0 [11 April 2006] - Continuator
foo_fullscreen.dll v0.3.1 [02 April 2006] - Fullscreen
foo_lyricsdb.dll v0.0.7 beta 4 [19 July 2006] - foo_lyricsdb
foo_prettypop.dll v1.2.3 [17 June 2006] - Pretty Popup
foo_uie_albumart.dll v0.2.3 [23 July 2006] - Album Art Panel
foo_uie_lyrics_panel.dll v0.34.1 [08 June 2006] - Lyrics panel
foo_uie_tabs.dll v0.2.1 [07 July 2006] - Tabbed panel modifyed
foo_uie_trackinfo_mod.dll v0.8 [01 August 2006] - Track info panel mod
My version info, having issues.
0.9.3 CPU Usage
I've also had this same problem which causes a disruption in my gaming.
I've also tried a clean install (Profile removed, no third party plugins) to no avail
0.9.3 CPU Usage
Switched back to 0.9.2 and the problem is gone.. I miss the new Media Library check already >.<
Does anyone have some beta versions of 0.9.3? AFAIK it worked fine, 2nd beta was the last i used on this computer.
0.9.3 CPU Usage
You can upload your foobar2000 installation directory + configuration files for us to look into (note that configuration files may include sensitive data such as foosic passwords and playback statistics; we'll remove your uploads after we've downloaded them). It would also help to know what kind of files you are playing when the problem occurs.
0.9.3 CPU Usage
i uploaded mine, hope you can find something.
0.9.3 CPU Usage
To start with, you fail at having read the offender list. Other than that, I could not reproduce your problem on my machine when running your configuration, but I suspect what you are experiencing is related to foosic fingerprint calculation (but again that could not be tested as your foosic configuration was left out).
[edit]
Also, your setup is crashable when seeking near the end of track, apparently continuator is to blame.
Perhaps you should check whether your problem is even reproduceable without any DLLs that don't come with the installer?
0.9.3 CPU Usage
i will never remove a component i like because you dont like it, i so got used to this plugin. As i dont publish or host it for some people i see no problem. Sorry for that, but perhaps it causes the problem, so i didnt remove it.
Foosic is not the problem. I switched back to 0.9.2, added foosic there and had 0.9.3 running, too, but without foosic ofcourse. Still the same problem.
Also continuator didnt cause this crash, i already thought it might cause it. I used the beta versions without continuator, everything worked fine. As this problem appeared after upgrading to the final version and adding continuator i removed continuator again. Now the cpu load appears directly when tracks change, not when crossfading starts.
I install a fresh foobar now and check if it works. Shall i upload this fresh install if this bug occurs again?
0.9.3 CPU Usage
The offender list is there for you to check against known problem sources before asking questions or writing bug reports. By having ignored it, you are only showing disrespect to people who spent their free time on writing the software you are using.
Arguing on what caused the crash that I triggered - which may or may not be related to the CPU usage problem - makes you look even weirder (how come I could trigger it every time until I removed continuator?).
0.9.3 CPU Usage
Note that I've already got a more useful report of the CPU usage problem from another user (without third party components) and I'm looking into details, so further reports - even with clean install - will have limited use to me.
