Topic: foo_dynamic_range_1.1.1 and v2.0 (Read 1038 times) previous topic - next topic
First post here - hope this is the right spot.
I just installed foobar2000 2.0 and tried to install the foo_dynamic_range_1.1.1 component and I'm getting the following message:
"Could not load component "foo_dynamic_range_1.1.1.zip": This component was built for a different processor architecture."
Perhaps this component was never officially supported, but I've found it very useful.  Anyone know which versions would still work with it?
Any thoughts or info would be much appreciated.
Re: foo_dynamic_range_1.1.1 and v2.0
Component does work with 32-bit version of foobar2000 v2.
thanks!  I'll give that a try - I'm guessing its best not to try running both versions on the same machine?
So, for what its worth, I uninstalled the 64-bit version and installed v2.0, 32-bit and all seems to work fine.  Thanks for the help.
Are there any advantages to the 64-bit version?
