Hi, im a musician who makes a lot of songs and am trying to work on my website. i am wondering if FLAC > TXT from the metadata is possible ? Ive tried in foobar "foo_texttools" but its very complicated to use! and does not allow all of this info to be created, so i would prefer something else. Foobar plugin or external program or script or anything
heres an idea of what i am trying to do.
Example of the Metadata in my files (im trying to be organised)
I've not the functionality but mp3tag can export various reports and stuff so it might be able to do what you want
metaflac and some scripting and you should be in business.
foobar2000 with either foo_texttools or foo_utils plug-in
or
mp3tag with it's built-in export function and a custom .mte script
Both apps are capable and are very similar regarding the level of scripting complexity and required effort.
(I prefer foo_utils)
I don't see anything in the example that cannot be recreated, what problem(s) are you having?
This is the perfect solution, thankyou! works a treat
Happy to help
or mp3tag with it's built-in export function and a custom .mte script
Thankyou, the coding was just very complicated so im going to use mp3tag now, cheers
