Help! iTunesEncode Failing
2005-01-09 01:15:34
Everything was working great on my system as recently as yesterday using EAC, MAREO and iTunesEncode-46. Today though, I decided to follow the EAC guide for a more correct configuration (http://home-12.tiscali-business.nl/~tpm54044/index.htm ) as well as install AccurateRip. Now everything's gone haywire! I believe the problem is with iTunesEncode because iTunes can still add .wavs and rip cds with no error. Below is the command that I'm executing (I'm manually running it to try to isolate the issue) and the output. The track is never added to the library in iTunes. Also, after iTunesEncode errors out, when I exit iTunes it warns me that "One or more applications are using the iTunes scripting interface." Anyone have a suggestion? E:\EAC>itunesencode.exe -e "AAC Encoder" -i "K:\Lossy\Linkin Park\Meteora\01 - Foreword.wav" -o "K:\lossy\Linkin Park\Meteora\01 - Foreword.m4a" -a "Linkin Park" -l "Meteora" -t "Foreword" -n "1" -y 2003 -g "Rock" -dArtist: Linkin Park Album: Meteora Title: Foreword Genre: Rock Year: 2003 TrackNumber: 1 Input File: K:\Lossy\Linkin Park\Meteora\01 - Foreword.wav Output File: K:\lossy\Linkin Park\Meteora\01 - Foreword.m4a Encoder: AAC Encoder Delete From iTunes: True Starting iTunes Encoder... Please Wait... Encode Progress at 100% Encoder Finished, Adding Tags (if any) Error getting tracks, user cancelled convert? NOTE: I also tried putting all the files in the same directory and running the simplified version of the command detailed below. Same result. itunesencode.exe -i "Foreword.wav"
