Topic: Removing LATM/LOAS headers (Read 6244 times) previous topic - next topic
Hi everyone,
I have some files that were previously encoded with AAC-HE and use LOAS transport. Now I need to get the raw data from those "containers". As far as I understand there's an header per frame which depends on the transport format used (LOAS, LATM, ADTS ...). Is this correct?
So I need to know the size of that header. Where can I get such information?
Remove ADTS headers:
ffmpeg -i ADTSinput.aac -absf aac_adtstoasc -acodec copy output.mp4
Remove LATM:
http://forum.doom9.org/showthread.php?p=1453484#post1453484
VLC can play these files as long as they are muxed in a ts or mp4 container, but I found out that if you remuxed a ts file with VLC it would strip the LATM bit packing from the stream.
First I would use eac3to with the -demux parameter to demux the ts file and get the raw audio stream as a file.
So then I use a command like this to remux the .aac file back into a transportstream and VLC will do it's thing.
vlc.exe -I dummy aud_latm.aac --sout #std{access=file,mux=ts,dst="aud_nolatm.ts"} vlc://quit
Also works using: mux=mp4,dst="aud_nolatm.mp4"
