Topic: Columns UI (Read 4613072 times) previous topic - next topic
Columns UI
Reply #4550
Is it possible to show total playtime of an album in the grouping? - Maybe even sort by it?
good idea...
musicmusic, what you say?
can you add this feature?
It's slightly complicated at the moment, but once I tackle %group_index%/%group_count% there will be some better tracking of group size changes so maybe then it will be less complicated to implement
ok... thx for response.
i'm looking forward to it
Columns UI
Reply #4551
Hmm.. I only changed the CPU priority, it shouldn't make things noticeably slower unless something else with higher priority is eating the CPU. Can you keep an eye on CPU usage and see if there is anything significant? Also can you try disabling reflections? Or maybe you have some huge artwork images for some files and it is related to that? I would prefer not to make a setting for this unless absolutely necessary..
It's weird as it seems like your component is the only thing that is doing anything significant in foobar during the stalling period. I don't use complicated DSP and stuffs. My computer is a Core 2 4300 with 2GB RAM, so I don't think it's that slow. Here's a screenshot of threads tab when it's stalled:
Columns UI
Reply #4552
The red and green should mean that it is reading different files' artwork. (It will read four at once). Is it definite this started with 0.3.3.x?
Maybe you scrolled down somewhat and then back up? The displayed files' artwork could be somewhere at the back of the queue then, I can change the logic a bit if that is the case.
Columns UI
Reply #4553
Yes, green is newly created threads and read are closing down threads. Typically I see four newly created threaded of columns UI dll when it reads artworks. When it's stuck I see more than 4 green ones like the pic I posted. Some threads are somehow stuck I guess.
Yes, pretty sure.
Not really. AFAICT it's random.
Idea for improvment:
Currently artworks are not cached between playlists, can you make them cached, too?
Columns UI
Reply #4554
Bug
When the album tag isn't present Columns UI doesn't display the correct cover art. For some reason it picks a cover with a name that contains a dot. For example t.est.jpg. If more than one cover has a dot in the name it selects in alphabetical order.
If the album tag IS present and no cover is found the correct no-cover image is displayed.
Columns UI
Reply #4555
where could I download new version column_ui?
I just can't open yuo.be && http://music.morbo.org/ recently.
I'm sure these URL can work two months ago.
and I'm really appriciate that any one can offer me a new version by
any way.
THKS.          My email is:  swordharley@mail.sdu.edu.cn
Columns UI
Reply #4558
More than four just means that process explorer is not keeping up, green is threads created in past two seconds or something so it is doing something.
Yes, pretty sure.
If that's the case, I can add a thread priority option, so you can check if it does make a difference.
Nothing is cached at all between playlists with NG Playlist, I don't plan on changing that (causes resource usage build up over time etc.).
Bug
How are things configured on the artwork tab in settings?
You have the correct URL. If you provide a tracert it may give some insight into the problem..
Columns UI
Reply #4559
I guess we're just not behind the Great Firewall of China? as springsonata seems to be, going by his (her?) email address...
Yes, but as these URL can work two months ago I thought it could be a temporary client/provider problem rather than a censorial issue.
Alessandro
Columns UI
Reply #4560
If you see this message (), I can confirm you the display bug with vertical/horizontal splitter when using foobar2000 AND Logitech Setpoint.
If I close Setpoint, I have no display problem anymore.
Infos: Vista Premium 64 bits + Logitech Setpoint 64 bits (MX Revolution) 4.60 + Foobar 0.9.5.4 + Columns UI 0.3.3.2
ps: filters + "type as you find" is a very great combination. I now don't use albumlist anymore. Thank you for this feature !
Columns UI
Reply #4561
THX everybody. I access the yuo.be by Proxy server now and got the new version.
cool. We can change the group font.
Columns UI
Reply #4562
Blah! So it wasn't just XP x64. Did you install SP1 as well?
Columns UI
Reply #4563
I found a display bug related to grouping. If I have artwork displayed in groups and then I go to the Grouping preferences and hide the groups for the currently active playlist, then the artwork correctly disappears but the blank column header remains causing the other column titles to be misaligned with their respective items. Activating another playlist and returning to the original playlist rectifies the problem. Happens with autosizing on or off.
Columns UI
Reply #4565
aphasia: Reproduced. Thanks for the report, it'll be fixed for next build.
Columns UI
Reply #4566
Bug
Well, properly I assume.
Front
...album art\%album%
The other two boxes are empty.
And the checkbox I can't even figure out what it's for. Nothing changes if I check it or not.
Columns UI
Reply #4567
If the album field is not present, that will result in:
...album art\?
And ? is similar to *, it means any single character..
something like [...album art\%album%] or $if(%album%,...album art\%album%) should work.
Columns UI
Reply #4568
^It does. Thanks.
Columns UI
Reply #4569
I forgot to mention...
Yes, I have reinstalled Vista, then I installed SP1.
Unfortunately you need Microsoft to fix their OS.. you can try this update, it's the only post SP1 one for the wow64 layer that I could find:
http://support.microsoft.com/kb/946924/ (just request it using the link in the top-left corner)
Columns UI
Reply #4570
musicmusic: If you haven't already fixed it, the arrows that show the sort direction are incorrect (at least compared to explorer). Nothing important though
Columns UI
Reply #4571
In a similar vein, if one selects all the items in a playlist and then presses home, the first item in the playlist will not be selected unless some other item in the playlist had previously been selected. Similarly with end.
Columns UI
Reply #4572
Hello!
Does any of you could give me more possibilities of what I can write as "column name" in the playlist view configuration? I mean, like [%date%], [%tracknumber%] etc....
I need particularly something like:
1.[folder_name] - something that shows me the name of the folder the given mp3 is in.
2.[the_whole_playlist_track_number] - it was before but suddenly I do not have this option - I want to have the whole playlist with numbers from 1 to up to the size of the playlist.
Thank you for your help!
Best regards,
Theriel
Columns UI
Reply #4573
I've done that. After a long processing of installation (mail, password, all this stuff), and a restart, I've seen NO changes. :/
But it's not a major problem (for me), because I prefer to use XP.
Columns UI
Reply #4574
Hmm yes they do seem to be pointing in the opposite direction :ph43r: Fixed for next build, thanks.
Also should be fixed in next build, thanks
OK, it was just a stab in the dark. The only solutions then are to not use SetPoint (or those other apps), or to use a 32-bit version of Windows.
