It’s called Kameleon because it can change into anything you want it to be. It’ll take you a while to find all the features but the beauty is you can turn things on or off to suit your style
This really has taken a phenomenal amount of coding and checking by Br3tt and it is just magnificent… Br3tt you can be very, very proud of this one and I’ve enjoyed every minute of testing it too
Kameleon, enjoy...
Looks sexy
Thanks for the hard work boys.
Thanx.
ingenious
thanx
Is it possible that the config eats up a lot of CPU cycles? It's taking like 70-80% of the CPU cycles on my C2D E6600.
Edit: Sorry it's more like 50-60%. The rest is used by other processes.
Edit2: I think I might have fixed it although I'm not sure exactly how I did it
Edit3: Are there any Vista compatible compilations of foo_trackinfo and foo_skip? Because I get warnings every time I open foobar.
for me (intel E6850) CPU is between 0 and 2%, your initial problem is certainly due to another application.
afaik trackinfo_Mod (and not trackinfo which is not used in this config) and foo_skip are compatible with Vista too, btw i use XP SP3. Do you use the components from my site??
1. Uses AVS from Winamp installation folder, if you have it. It eat low CPU
2. Install Microsoft Visual C++ 2008 Redistributable Package (x86) (http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en)
3. Sorry for my bad English
PS Falstaff, its the best foobar config i've ever see:)
Yea I got the package and copied those.
And those other applications would be hogging the CPU through the foobar process? Wouldn't the taskmanager associate those cycles with the process causing them?
Ok I solved the trackinfo problem. The ddl was there but unused so I removed that one. But the foo_skip.dll from the package is still not loading.
Failed to load DLL: foo_skip.dll
Reason: This component is not compatible with this version of Windows and needs to be recompiled with a newer version of the foobar2000 SDK; please contact the author of this component to obtain an updated version of this component.
Falstaff, awesome work. Thanks!
Andu, use this foo_skip.dll - it works fine! http://www.saunalahti.fi/~cse/foobar2000/foo_skip.zip (http://www.saunalahti.fi/~cse/foobar2000/foo_skip.zip)
Thanks AlStorm. That one did work for me
Falstaff, add this foo_skip.dll in your config, its last version (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=30361&view=findpost&p=607923) of plugin
And thanks for great config again:)
Little bag:( It become(it makes? - sorry for my english) then I set variables kameleon_artistart_path and kameleon_artistart_filename in Preferences > Tools > Extended Variables
(http://pic.ipicture.ru/uploads/090215/thumbs/kyyQNYT6SR.jpg) (http://ipicture.ru/Gallery/Viewfull/13343008.html)
Could some one explain the syntax for
kameleon_coverart_path = music folder
kameleon_artistart_path = music folder
kameleon_artistart_filname = artist.jpg (and not %artist%.jpg !)
kameleon_default_width = 864
kameleon_default_height = 630
kameleon_playcount_max = 100
kameleon_left_panel_width = 320
kameleon_disable_filetype_info = 0
kameleon_cycle_bg = 1
if these are defaults there not working as they should as this would suggest the cover art is in the same place as the music.
Oh, awesome! Thanks for this new skin!
Incredible skin, Br3tt! You kick ass. However, I have a few questions:
-Which .png do you have assigned to the "Cover is loading" Image on the Chronflow plugin? Is it the one labeled nocover.png which I assumed must be used in the "No Cover Image" field?
-Why can't the optional left panel be made thinner than 320 pixels?
-Is there a way to resize the height of the window that pops up when one clicks "chronflow" or the playlist viewer? I'd like Kameleon to default to the playlist viewer, but I do not need the window to be as big.
-Is there a way to force the Kameleon background to NOT show album art in the background, like in Curacao? Edit: I figured this one out: Force Wallpaper > Do Not "hide panel on startup."
-The background cycler variable does not do anything for me. It always displays the default wallpaper wp1.jpg (not the other ones, like the grey one, the blue one, etc.)
I'd appreciate your input.
This skin is so complete! Keep up the good work
Thank you, great skin! Much improved over Curacao, great additions.
That initial big CPU hit is Chronflow loading the cover art images into memory, my CPU initially runs 70+% but will drop down to 10% when everything is loaded and running, Kameleon is very well optimized. Tweaking the Chronflow settings can help but unfortunately it's a resource hog. But pretty
Here a bug!
(http://img3.imageshack.us/img3/4632/capturexg5.jpg)
My config:
(http://img25.imageshack.us/img25/6511/32795674bd5.jpg)
It's OK if I set: kameleon_artistart_filename: artist.jpg
And I think U should change position of 2 buttons in this picture:
Here a bug!
My config:
Hmmm... you show me the Cover pic bug and talk about artistart filename ???!!
so the problem is about covers :
kameleon_coverart_path : default (=music folder) / specified path (i.e: C:/covers/) (be careful, specified path must close with a '/')
kameleon_coverart_filename : i.e: folder.jpg / folder.* / %album%.jpg / etc ...
if nothing setted in Foo_exvar, it search for folder.jpg images in the music folder, is it your case ? does it happen with all covers CD or only some of them ?
ok, thank you.
Holy mudkipz, that's a really sweet piece of art. Thanks for sharing, mate.
Yay finally! Gonna test it now! <3 Br3tt!
Edit: I keep getting a warning from Shpeck when I start Foobar:
Original Winamp or some other Winamp emulator has been detected. This can result in wrongly reported data, nonfunctional plugins and other conflicts, be warned.
KAMELEON v1.0b released. some fixes ... (lastest foo_skip plugin too)
the bug cover display (bad scale in the CD Case) is maybe fixed because i can't reproduce it, but i've made a little change...
Here a bug!
My config:
I understand it!
It is necessary to remove any extra spaces before and after the %artist%.jpg!
After that, the picture shows a well
LOL, of course
Very beatiful work, but i'd like to see you tackle a lighter/easier on the eye config instead. I admit it's very nice, but i can't see myself using that for my actual config. edit: through more white in there too for a change too : )
I use Discogs for my artist art, and then use %DISCOGS_ARTIST_ID%_1.jpg for my artist image. However, It doesnt show up
I have kameleon_artistart_path set to E:/foobar2000/images/Artist/, and kameleon_artistart_filename to %DISCOGS_ARTIST_ID%_1.jpg.
This should work I guess?
foo-exvar do not handle variables like %var%, except %artist%, %album%, %album artist% be cause i have tweaked the code in K to handle them.
so all other %% can't work without some coding ... Same for all titleformat functions (like $replace(...) for example), they are not supported by foo_exvar.
i'll add this info in the INSTALLATION NOTES. (done)
the more white it can be is to use a full white wallpaper as background :
(http://xs136.xs.to/xs136/09070/whiter405.png.xs.jpg) (http://xs136.xs.to/xs136/09070/whiter405.png)
Man! This is a miracle! Br3tt thank you soooo much!!!
You're welcome Mr. Pac
What i mean is that maybe you should try something different. Too much stuff, bells and whistles. I suppose you'll say 1) i do it for my personal needs or 2) If you don't like it don't use. But the thing is that not many "waste" so much time to give configs to the community so maybe you could experiment with something else. Maybe a Pimp my Foobar kind of thing. I'll be the first to submit : D http://img8.imageshack.us/img8/3366/clipboard01gx0.jpg (http://img8.imageshack.us/img8/3366/clipboard01gx0.jpg)
Don't mean to sound like an ungrateful asshole, keep doing what you like most : )
these components are new versions:
foo_run
foo_lastfm_radio
foo_uie_lyrics
why the required components are not foo_audioscrobbler?
foo_lastfm_radio meaningless without foo_audioscrobbler
and please, delete foo_playback_custom (automatic editing tags and corrupted hash files of torrents and dc++)
Hey Guys.
Thank You Br3tt for this theme:) it's great but it's slow as hell on my pc.
Any help??
Hmm... Now it's working ok for cuple of minutes and then it slows down. You can see that when you try to switch between different panels ect..
Really great work Falstaff
I specially like how easy it is, to adapt the config, to my needs, that's quite an achievement with Panel Stack Splitter.
snapix font cannt support chinese and japanese
Happens still here, but also not reproducable. (v0.9.6.3 beta 1 with kameleon 1.0b fully installed)
First of all - another great config Thanks for great work
Nevertheless I've got a few problems with Kameleon
1. CPU usage - over 60% sometimes (c2d@3.2Ghz so I don't think that hardware is the case). I've noticed it jumps so high only in two moments - when lyrics or now playing panel is active (even worse when both)
2. Playlist switcher should be in the left panel (wishlist:P), I'm using it a lot and it's somehow weird now
3. Chronoflow - viewing by playlists? (It's probably more for developer of chronoflow;))
Thanks for the great config!
I have a question:
I want to set the cover file name like this:
If there is a file named %album%.jpg, then use that one, if not, use the file folder.jpg
Is it possible?
& I also receive this warning when start foobar: "Original Winamp or some other Winamp emulator has been detected. This can result in wrongly reported data, nonfunctional plugins and other conflicts, be warned." How to fix it?
Thanks in advanced
Thank you very much, Brett! Kameleon is really amazing. Visually stunning, everything worked out in great detail. The new left, right and "now playing" panels are a big improvement (I didn't think that was even possible) over your last configs.
Now some constructive criticism:
In my opinion, Album List and Playlist Switcher could be implemented in a better way. Currently they open in a panel roughly 600x300 big. Ideally, this should be something like 300x600 because both AL and PS can have many rows and don't need too much space horizontally.
I suggest that the panel for AL and PS has the same size as the left panel and appears directly above it. This would be a nice combination of Ibiza (position) and Curacao/Kameleon (functionality). The buttons to show AL/PS could be moved to the right of the play/pause, etc buttons.
For my needs that would be perfect because when I browse playlists or AL, I am anyway more interested in what happens in ELPlaylist than the visuals of the left panel.
Maybe you have kmplayer started
read post #28 above (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=615358)
be sure that there is no gap in the variables values
I just found a little bug with foo_input_mslive.dll. Kameleon freezes when I open a mms stream, it worked fine with curacao. Probably some of the new code in ELPlaylist?
Sure, I read the whole thread before reporting. I have not even set a custom variable for the album art. About 50% of the time (it decides always when I start foobar) it works, 50% it doesn't. When I find a common property (probable of the resized cover image, I suppose) I will report.
Artistart issue: I just read the drawback of foo_exvar, that it is not capable of reflecting my artist art naming scheme for your theme:
Folder: $replace(%path%,%directoryname%\%filename_ext%,)
Filename: folder.jpg
Is there any chance you might include this (I hope often used) convention to store the artist image in the folder hierarchy one level above the album art?
hi, amazing config br3tt . as always .....when i start a track, background image is automaticly set to the cover image of the band, is it possible to set a bg image that is displayed even when i play a track
Click on the alien cat above playlist
ohhh. missed that one ... thanks for the help
ok, wait for more info about pics ...
yep, i'll try to add support for common functions like $replace and for some variables like those mentionned ... i may need your help to test this new fcl
i don't use foo_input_mslive ... will try ... btw i use foo_msnalt.dll and have no problem
first of all, awesome skin, brett! it's one of best skin ever made for any music player, and by this one, you moved standards of making an awesome skin.
my question : why doesn't my foobar shows artist image? i already read tutorial and did everything as it should been done, and read this whole article, but no go.
i created "ArtistArt" folder where are all my artist photos, in kameleon_artistart_path, my values are : D:/MZLV/glazba/ArtistArt/, and in kameleon_artistart_filename, my values are : %artist%.jpg. I tried to change to artist.jpg, but still nothing. How does my artist art path should look like? Cheers
Just a small question - the style settings for Album List are inside ColumnsUI settings. Everytime I import one of your fcl's, the settings are reset to white bg/black Tahoma font (defaults).
Is it a problem with ColumnsUI/Album List, or is it your config is set with defaults for Album List?
Thank you, nice config.
Hey Br3tt what can we do about the performance issue ?? The config is great but every few minutes it uses loads of cpu power and the config becomes unresponisve. Any help??
here, CPU is around 2 or 4 % with all panels (Vis, Spe ...) visible ! so K cannot be responsible ...
BUT if you use Chronflow, on track change, CPU can grows to 70% or 80% or over before going down to normal values (2% or 4%),
SO, it is a Chronflow issue already known by Chronflow users. To optimize this, be sure that you have READ and set the Chronflow performance panel as discribed on my site (http://br3tt.free.fr/html/K/index.htm)
If you have a low/old CPU, just do not use Chronflow panel ...
must work, my personnal needs for artist path are similar to yours, be sure you have the good path, not space add too much?
my settings are :
(http://xs136.xs.to/xs136/09070/foo_exvar_set271.png)
just replace the path value by your.
Be sure that your artists photo are named %artist%.jpg like you say it to me (
ex: Pink floyd.jpg)
try this fcl (http://br3tt.free.fr/files/K/kameleon_1.0b2.fcl) file to see if it works now... *waits for feedback* sorry, $replace(...) inside foo_exvar not supported
try this fcl file : http://br3tt.free.fr/files/K/kameleon_1.0b3.fcl (http://br3tt.free.fr/files/K/kameleon_1.0b3.fcl), %DISCOGS_ARTIST_ID% support added ... *waits for feedback*
Fantastic config!
Artist picture doesn't work here also!
kameleon_artistart_path J:/mp3/artists/
kameleon_artistart_filename %performer%*.*
I tried %performer%.* and %Performer%*.* and %PERFORMER%*.* and so on, but nothing.
I need help!
Awesome setup, Br3tt. thx for the hard work.
Just i quick pointer, updating to the latest lyrics show panel decreases my CPU usage from 17% to ~4%.
http://www.hydrogenaudio.org/forums/index....showtopic=55692 (http://www.hydrogenaudio.org/forums/index.php?showtopic=55692)
Get it there.
Also I'm getting the same issue with the wrong sized album art in the left sidebar.
Thanks, but isn't foo_msnalt.dll (http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Components_0.9/MSN_Now_Playing_(alt)_(foo_msnalt)) a now playing component?
Fantastic config!
I need help!
Maybe I'm totally off, but isn't in the windows path always a backslash, so it would be "J:\mp3\artists\". At least that is how it works for me.
I wondered about that in the readme, but then I already had copy pasted the paths and it worked.
Fantastic config!
I need help!
as already said and mentionned in the instyallations notes on my site, foo_exvar do not handle %% variables, excepted those i have coded (%album%, %artist%, %album artist% ... read the doc!)
btw, i can include %performer% for the next build ==> done, try this fcl file : http://br3tt.free.fr/files/K/kameleon_1.0b3.fcl (http://br3tt.free.fr/files/K/kameleon_1.0b3.fcl) i've added %performer% and %band% too , gimme feedback
my settings are :
Be sure that your artists photo are named %artist%.jpg like you say it to me (ex: Pink floyd.jpg)
thanx for help, but im 100% positive there's no any space between, before or after the titled path for filename or path.
anyway, check this, i can't see any failure why it wouldn't work but it still doesn't work :S
http://img293.imageshack.us/img293/7557/hmmdx8.jpg (http://img293.imageshack.us/img293/7557/hmmdx8.jpg)
Get it there.
Solved my high CPU usage too (it wasn't chronoflow case at all)
Now only one thing remains on my "than it will be perfect" list.. playlist switcher in the left panel (is it even possible?)
Get it there.
what was your CPU usage problem please, that can maybe help others ... Thanx
You are missing a backslash at the end of the path. there is an explicit warning about that inside instructions.
my settings are :
Get it there.
It was solved by updating Lyrics Show Panel to the latest version as explained in the post he quoted. Actually there are a lot of components which aren't up to date in the package. I don't think all of them have performance updates since then but some might and others might solve other issues. If you could provide a component list like for Ibiza that would make it much easier to update the components that Kameleon uses
Edit: As a matter of fact it improved performance on my system by a lot too.
Get it there.
lyrics show panel -> updating it helped (link's above) in my case in dropped from 30-40 to 2-10% CPU usage
you have forgotten a "/" at the end of the path !!!
fix it and retry
hmm, still no luck.
i forgot it probably when i was transfering artist art to simplier path, but before then, i still had '/' thing at the end of the path, and it weren't work.
damn.
fix it and retry
hmm, still no luck.
damn.
sorry, but this work here, take care of all again, can't say better, sorry...
Br3tt, I have the bug with bad scaling of cover image to
And, maybe, you should add tutorial how to show or not cover image in the background? (I can`t find where it change)
Great config as usual, thank you very much !!!
1. for the scale problem in the CD case, please, show me a screenshot of your foo_exvar settings panel + an example of path where your cover is stored (and filename used), and send me the image cover used
==> WITHOUT ALL OF THAT, it's difficult to help because all work fine for me.
thanx by advance, you or another people that have this problem
2. viewing the Curacao tutorial page can help you, the way to always use the default wallpaper bg is discribed in a video
http://br3tt.free.fr/tutorials/C/index.htm (http://br3tt.free.fr/tutorials/C/index.htm) ==> the second video ... for Kameleon, enter splitter settings (right click on the playlist header for example), select the panel named '-> Force Wallpaper', then UNCHECK 'hide panel on startup' option, if you have read more carefully my installations notes, i explain how to to that, not only for this panel/boolean option, but just generally, it is the same way to activate or not all panels/boolean that begin by '-> '
fix it and retry
hmm, still no luck.
damn.
i delete whole foobar, including app data from my documents, then installed on whole another disk, do everything as it's been said - AND IT WORKED!
woohoo
thanks for help man, and congrats on the best skin ever made for foobar
now it works like a charm thanks again!
(http://img16.imageshack.us/img16/5232/kamyj1.jpg)
again.. playlist switcher in left panel? :X
fix it and retry
hmm, still no luck.
damn.
woohoo
cool, btw that was a weird issue you had.
http://img16.imageshack.us/img16/5232/kamyj1.jpg (http://img16.imageshack.us/img16/5232/kamyj1.jpg)
nice bg, mind sharing it ?
Hello Brett, I'd like to recommend a few tweaks to Kameleon:
1. Change "disc" to "Disc," as in "disc 1/2," just to make it look nicer. It's easy enough to change on my own though, but some users might want this.
2. Consider changing the track title font from size 7 to 8. When viewing tracks with asian characters, size 7 font is too small to show the characters nicely, and when I changed it to 8, it looks fine.
3. Change the panels in the right panel to be square in size. As in your earlier configs, artist images were always shown as squares, and thus since Ibiza I've been saving the artists as square images. Now, to show them correctly I'd have to resave them all as rectangles. Otherwise, I just changed "nokeepaspect" to "keepaspect."
4. Is there a way to make Kameleon show the last playlist used? I could do this in Curacao, but when I open foobar with Kameleon, it goes to my default library playlist.
5. Can the very topmost panel bar (path info of track and google/audioscrobbler search buttons) be hidden? I don't use that stuff so much, so it would make more space on the screen for the playlist.
Thank you very much for your consideration! And again, awesome, awesome, AWESOME job on Kameleon. I love it.
http://nodate.deviantart.com/art/I-love-music-45811627 (http://nodate.deviantart.com/art/I-love-music-45811627)
leave a fav when you're there she deserves it
maybe it's kinda small but it works perfectly as a wall for foo
anyway, i have another question, it isn't connected to some problem, just for info
when kameleon count track "as listened", in meaning of time that has to pass to count track as listened? before i use "kameleon", i used "foo smooth", and it count track as listened after one minute, when does kameleon count? if it's whole track, is there any option to change it? i have huge library, and i wan't to listen random tracks all the time, so i often don't listen to whole track, but to half of it, but then i wan't my track to be marked as "listened" after one minute or half track pass. is there any option to do so, because in my right panel, i use stat so i want to build my chart with fav songs i find out recently and i play it more often then tracks i play before.
i prefer keep it lower case.
huumm, i'll see, that right it is too small for asian chars.
no, since Curacao, i only use landscape image for artists, it's quite better. Ibiza belong to past now
it does like all other skins , if not for you, it is due to foobar settings, not due to Kameleon... Check your settings in the foobar Prefs.
i will make this possible by using an Extended variable infoo_exvar in a next build. ok.
thanx for enjoying K
I believe that you can change when a track's playcount is updated through Play Count Mod (preferences > tools > play count mod). There's a slider bar called "counter update settings" that can be changed to reflect when a song is updated based on the percentage of track that's been played. I have mine set at 50%.
Hope this helps.
"Playback Statistics Custom" settings or "Play Counter" (the official playback stats plugin) settings. But do not use both, "Play Counter" store information in a database, and "Playback Statistics Custom" in the music file. Play counter do not work well when statistics tags are present in the music file.
file -> startup playlist -> last playlist
(at least it works with my foo:))
ty, added to my fav
thanks !
1. The problem with CD case can appear when default cover image is using (in case when I don`t have cover)
You can see it at this screenshot http://img10.imageshack.us/img10/2627/cdcasebuggn8.jpg (http://img10.imageshack.us/img10/2627/cdcasebuggn8.jpg)
And this bug didn`t disappear until then I import .fcl again
My foo_exvar settings panel is blank, because all cover images are store in the each album folder on hard drive and called "folder.jpg"
2. And about background image - I`ve seen a video before asking, just can`t find panel named "Force Wallpaper", because clicked on wrong place , sorry
It`s Ok now, thank you
In that case, what is the ratio you're using for the artist images? Is it 4:3?
Thanks! It worked for me. I guess when I loaded Kameleon, it reset or something.
thanx for the details. I've maybe fixed it, not sure because i can't reproduce it
try this fcl file : http://br3tt.free.fr/files/K/kameleon_1.0b5.fcl (http://br3tt.free.fr/files/K/kameleon_1.0b5.fcl)
and gimme feeddback ASAP please !!!
EDIT: nobody who have this bug can check it and give me feedback please ? Thanx by advance.
Just tried it: so far the bug did not occur any more, I restarted the player 10 times using different albums where the bug occured before. So for me, the problem seems to be fixed. When it occurs again I will report.
And thanks for switching to landscaped artist pictures. I was right for all the years
Hmm.. I tried you new .fcl - unfortunately, it doesn`t help it appears rarely, meseems.
Some new details: the bug appears from time to time 50:50 and only when start-restart foobar - it means that bad scalling image shows just after start foobar, before playing music, and then it doesn`t disappear until foobar being restart. (some times needed a couple restarts or more)
...and then cover image is Ok after foobar start, it is Ok further, even I change covers many times, as opposed to first case
oh, me again.
i have another info question, this time connected with playlist queue viewer.
i download required component to show playlist queue list, but it seems he doesn't work with kameleon (it works fine on other skins), so in future, it would be nice to add this feature
new try please : http://br3tt.free.fr/files/K/kameleon_1.0b6.fcl (http://br3tt.free.fr/files/K/kameleon_1.0b6.fcl)
IMPORTANT : are you using the last version of Panel Stack Splitter ?? v0.3.6.2 ??
oh, me again.
Do you mean Playback Queue Viewer (foo_pqview) ? It works like a charm with K.
Well, after import fcl and first restart, the bug appeared again, but then during the 20`s restarts I didn`t see its.
Let`s see that happens further, I`ll immediately tell you.
By the way, I use 0.9.5.6 version, and Windows Vista if it`s important of course...
Yes, I use the last version 0.3.6.2alfa of Panel Stack Splitter
how about installing the latest version of foobar2000, beta or stable and see if the bug still shows up? just an idea.
Br3tt, can you make a "sticker" like the mp3 and flac stickers for the cd cases you made in Graphics Browser, which will appear on multiple cds with their number? for example: #1, #2 etc.. Do you like the idea? I have many multiple cd albums (with the same cover) and in graphics Browser they seem the same..
oh, me again.
yeah, i paste same component in component folder, and when i click "add to playback queue" it doesn't show any list.
oh, me again.
you have to define before the playlist to use for the Queue, have you done it ? (in the menu of the foobar Toolbars : Playback -> Playback Queue Viewer)
Any word on whether the height of the coverflow/playlist/album browser can be changed and/or be kept fixed?
As shown in the screenshot below, the height of this pane is 40% of the skin, and only about 175px is really needed to use coverflow/playlist/album browser.
(http://img217.imageshack.us/img217/9067/kameleonns7.jpg)
http://img217.imageshack.us/img217/9067/kameleonns7.jpg (http://img217.imageshack.us/img217/9067/kameleonns7.jpg)
no setting for that (not yet)
you should fix the colors for your quick search panel ...
I just registered to thank you for such an amazing theme! All the hard work put into this is much appreciated!
Thanx and welcome on HA Sgolym
Kameleon 1.0c released (http://br3tt.free.fr/html/K/index.htm)-> added some variables for foo_exvar paths and filenames : %band%, %performer%, %discogs_artist_id% + some fixes
is your site hosted from your computer or just a really slow webhost?
Thanks for the fast FCL revisions! You kick ass!
Are these two buttons backwards? It seems that they indicate the opposite of what they do.
(http://img4.imageshack.us/img4/7030/kameleonbuttonha5.jpg)
on my provider host. fine here (maybe too many downloads lol)
After playing around with Kameleon a little longer I've decided its awesome.
Curacao was great, but this just beautiful.
However I have 2 feature requests
1. Under the Library menu, i am missing the rescan library option.
I'd love to see that added to your menu's.
2. A third option on the aliencat background switcher to show Album Art, Artist Pic or Default Bg's
I've got some large album pics that look really good as backgrounds. Plus some artist's have pretty ugly mugs
curious, anyone here on windows 7 x64 and having an issue with chronflow? I have the latest ATI beta drivers and prior to that it was the default windows 7 drivers, and chronflow keeps throwing the unable to get hardware accelerated pixelformat or whatever it says. I guess I won't be using that feature. other than that you have outdone yourself again Falstaff!
you should consider hosting your files on rapidshare. you can create a free 'collector's account' and host your files there. when people download your files, you get points. you can exchange the points for a premium account.
as popular as your skins are, you could get a lot of points very fast
With the 0.9.6 line of foobar it reloads the library automatically when changes to the library folders occur.
Looks like it time to update then
Thx for the fast reply
This scaling bug is still happening with FLC 1.0c. No idea what is triggering it.
(http://img4.imageshack.us/img4/8408/bugbk2.jpg)
I searched and searched and could not find this menu sequence.
Of course I can find "File" But when I click it I find no such option as "Startup Playlist. Where is it exactly?
Fantastic config Falstaff!
Great work br3tt!!!
i have a problem thou. when i add my music library, an than creates an auto-playlist, i get an error when i restart foobar, than foobar closed, what ca i do?
the error i get:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0408DF50h
Access violation, operation: read, address: 0A785000h
Call path not available.
Code bytes (0408DF50h):
0408DF10h: 75 DE E9 37 02 00 00 8B 7C 24 38 8B 4C 24 44 8D
0408DF20h: 14 7F 8B C2 8B 54 24 50 2B D0 85 ED 8B 01 8B 4C
0408DF30h: 24 54 89 54 24 34 0F 86 12 02 00 00 89 6C 24 38
0408DF40h: 83 FF 03 8B F7 76 65 8D 57 FC C1 EA 02 83 C2 01
0408DF50h: 8B 19 81 CB 00 00 00 FF 89 18 8B 59 04 0F B6 69
0408DF60h: 03 81 CB 00 00 FF FF C1 E3 08 0B DD 89 58 04 8B
0408DF70h: 59 08 0F B7 69 06 83 C0 04 81 CB 00 FF FF FF C1
0408DF80h: E3 10 0B DD 83 C0 04 89 18 8B 59 08 C1 EB 08 83
Stack (07ACF950h):
07ACF930h: 7C967E3F 7C9CB178 7C967DE9 01269E84
07ACF940h: 01D025E0 0000FFFF 7FFDF000 00255220
07ACF950h: 00000000 070CAF40 00000000 06DE2970
07ACF960h: 006B006C 00000000 0000000A 0000000C
07ACF970h: 00000000 000002E8 00000000 00000006
07ACF980h: 04096CEF 00000002 00000001 00000101
07ACF990h: 00000007 06FDE7A8 00000000 00000000
07ACF9A0h: 000005CC 0A6D0020 00000000 00000000
07ACF9B0h: 00000000 00000000 00000000 00000007
07ACF9C0h: 07ACF9B0 07ACF9F8 07ACFBF4 07ACFA00
07ACF9D0h: 02BF0000 7C960202 00000011 02BF09B8
07ACF9E0h: 02BF0000 00000000 07ACF9D8 7C9600A4
07ACF9F0h: 07ACFC1C 7C95E900 7C960208 FFFFFFFF
07ACFA00h: 00000FA0 7C961066 7C9601BB 0000007C
07ACFA10h: 00000000 7C9600A4 0AB20000 FFFFFF73
07ACFA20h: 02BF0050 076C0000 0A6D0000 00000000
07ACFA30h: 00C701D8 00000000 00000000 FFFFFF6A
07ACFA40h: FFFFFF69 07ACFA78 04094F2B 06DE2970
07ACFA50h: 07311688 07311688 06DDC978 00000001
07ACFA60h: 06D61698 07ACFA54 02BF01B8 07ACFAA0
Registers:
EAX: 0AD11018, EBX: FF000000, ECX: 0A785000, EDX: 00000036
ESI: 000000DA, EDI: 000001EE, EBP: 00000000, ESP: 07ACF950
Crash location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+004C9580h)
Loaded modules:
foobar2000 loaded at 00400000h - 0053B000h
ntdll loaded at 7C950000h - 7C9F8000h
kernel32 loaded at 7C800000h - 7C94D000h
COMCTL32 loaded at 77370000h - 77473000h
msvcrt loaded at 77BB0000h - 77C08000h
ADVAPI32 loaded at 77D70000h - 77E1A000h
RPCRT4 loaded at 77E20000h - 77EB2000h
Secur32 loaded at 77F90000h - 77FA1000h
GDI32 loaded at 77EC0000h - 77F09000h
USER32 loaded at 77CE0000h - 77D70000h
SHLWAPI loaded at 77F10000h - 77F8C000h
SHELL32 loaded at 7E1E0000h - 7EE24000h
ole32 loaded at 77480000h - 775BD000h
shared loaded at 10000000h - 1002A000h
UxTheme loaded at 5B210000h - 5B248000h
COMDLG32 loaded at 76310000h - 76377000h
IMM32 loaded at 762F0000h - 7630D000h
LPK loaded at 62EC0000h - 62EC9000h
USP10 loaded at 754A0000h - 7550B000h
avgrsstx loaded at 003A0000h - 003A5000h
RocketDock loaded at 00A70000h - 00A82000h
PSAPI loaded at 76B70000h - 76B7B000h
MSCTF loaded at 74670000h - 746BC000h
msctfime loaded at 753F0000h - 7541E000h
foo_uie_albumlist loaded at 00B10000h - 00B4D000h
foo_dsp_std loaded at 00B70000h - 00BB8000h
foo_uie_wsh_panel loaded at 00BE0000h - 00C0F000h
OLEAUT32 loaded at 770C0000h - 7714B000h
gdiplus loaded at 4C920000h - 4CAC6000h
foo_run loaded at 00D90000h - 00DBD000h
foo_uie_vis_channel_spectrum loaded at 00DE0000h - 00E1D000h
MSIMG32 loaded at 762E0000h - 762E5000h
WINMM loaded at 76AC0000h - 76AED000h
foo_albumlist loaded at 00EC0000h - 00F2B000h
foo_cdda loaded at 00F50000h - 00F90000h
foo_uie_graphical_browser loaded at 00FB0000h - 01044000h
foo_rgscan loaded at 01060000h - 010BB000h
foo_exvar loaded at 010E0000h - 01108000h
foo_chronflow loaded at 01230000h - 01291000h
OPENGL32 loaded at 5F1C0000h - 5F28C000h
GLU32 loaded at 69030000h - 69050000h
DDRAW loaded at 736C0000h - 7370B000h
DCIMAN32 loaded at 73B20000h - 73B26000h
foo_playback_custom loaded at 01DC0000h - 01E05000h
WINSPOOL loaded at 72F60000h - 72F86000h
foo_playcount loaded at 01E50000h - 01E7A000h
foo_ui_std loaded at 01EA0000h - 01F74000h
foo_uie_quicksearch loaded at 01FA0000h - 01FE6000h
foo_utils loaded at 02010000h - 02054000h
foo_skip loaded at 02080000h - 0209D000h
foo_uie_lyrics loaded at 020C0000h - 0211D000h
WININET loaded at 43D00000h - 43DD0000h
Normaliz loaded at 02130000h - 02139000h
iertutil loaded at 43A80000h - 43AC5000h
foo_menu_addons loaded at 02360000h - 0239C000h
foo_runcmd loaded at 023C0000h - 023F4000h
foo_uie_panel_splitter loaded at 02420000h - 0246F000h
foo_input_std loaded at 02490000h - 025CF000h
foo_lastfm_radio loaded at 025F0000h - 02638000h
foo_uie_trackinfo_mod loaded at 02660000h - 026B6000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_uie_elplaylist loaded at 026E0000h - 02749000h
foo_ui_columns loaded at 02770000h - 028AB000h
foo_converter loaded at 028D0000h - 0293C000h
foo_vis_shpeck loaded at 02960000h - 0299E000h
mscms loaded at 73A90000h - 73AA5000h
icm32 loaded at 60CE0000h - 60D21000h
atioglxx loaded at 03BA0000h - 0471A000h
VERSION loaded at 77BA0000h - 77BA8000h
WS2_32 loaded at 71A00000h - 71A17000h
WS2HELP loaded at 719F0000h - 719F8000h
SXS loaded at 75DF0000h - 75E9F000h
CLBCATQ loaded at 76F70000h - 76FEF000h
COMRes loaded at 76FF0000h - 770AB000h
jscript loaded at 75BB0000h - 75C2D000h
xpsp2res loaded at 08650000h - 08C26000h
imagehlp loaded at 76C30000h - 76C58000h
DBGHELP loaded at 59B80000h - 59C21000h
Stack dump analysis:
Address: 04096CEFh, location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+004D231Fh)
Address: 7C960202h, location: "ntdll", loaded at 7C950000h - 7C9F8000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C9600A4h, location: "ntdll", loaded at 7C950000h - 7C9F8000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C95E900h, location: "ntdll", loaded at 7C950000h - 7C9F8000h
Symbol: "strchr" (+00000113h)
Address: 7C960208h, location: "ntdll", loaded at 7C950000h - 7C9F8000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C961066h, location: "ntdll", loaded at 7C950000h - 7C9F8000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9601BBh, location: "ntdll", loaded at 7C950000h - 7C9F8000h
Address: 04094F2Bh, location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+004D055Bh)
Address: 7C96017Bh, location: "ntdll", loaded at 7C950000h - 7C9F8000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 04052E26h, location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+0048E456h)
Address: 040568BBh, location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+00491EEBh)
Address: 040567F6h, location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+00491E26h)
Address: 04091EB6h, location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+004CD4E6h)
Address: 04050F1Fh, location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+0048C54Fh)
Address: 03C1C233h, location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+00057863h)
Address: 027F0000h, location: "foo_ui_columns", loaded at 02770000h - 028AB000h
Address: 03D058E0h, location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+00140F10h)
Address: 03EBE375h, location: "atioglxx", loaded at 03BA0000h - 0471A000h
Symbol: "atiPPHSN" (+002F99A5h)
Address: 0123FE5Dh, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 012325E5h, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 01232464h, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 01010000h, location: "foo_uie_graphical_browser", loaded at 00FB0000h - 01044000h
Address: 7C960040h, location: "ntdll", loaded at 7C950000h - 7C9F8000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 01265788h, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 0125356Ah, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 0127F958h, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 0125704Fh, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 01231DF9h, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 012537FBh, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 012552B0h, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 012538A0h, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 7C80B713h, location: "kernel32", loaded at 7C800000h - 7C94D000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839AC0h, location: "kernel32", loaded at 7C800000h - 7C94D000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B720h, location: "kernel32", loaded at 7C800000h - 7C94D000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 01253821h, location: "foo_chronflow", loaded at 01230000h - 01291000h
Address: 01000004h, location: "foo_uie_graphical_browser", loaded at 00FB0000h - 01044000h
Version info:
foobar2000 v0.9.6.2
UNICODE
Windows 5.1
Additional info:
Default User Interface 0.9.5 (foo_ui_std)
WSH Panel (uie) 0.7.2 (foo_uie_wsh_panel)
Run Command 1.0 beta 3 (foo_runcmd)
Album List 4.3 (foo_albumlist)
Shpeck - Winamp vis plugins wrapper 0.3.0 (foo_vis_shpeck)
Extended Variables 0.3.1 (foo_exvar)
Chronial's Coverflow 0.3.0 (foo_chronflow)
ReplayGain Scanner 2.0.8 (foo_rgscan)
Channel Spectrum panel 0.17.2 (foo_uie_vis_channel_spectrum)
Panel Stack Splitter 0.3.6.2(alpha) (foo_uie_panel_splitter)
Last.fm Radio 0.5.4 (foo_lastfm_radio)
Playback Statistics 2.1.6 (foo_playcount)
Run services 0.3.5 (foo_run)
Converter 1.2 (foo_converter)
Standard Input Array 1.0 (foo_input_std)
Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01] (foo_uie_lyrics)
Quick Search Toolbar 2.8l (foo_uie_quicksearch)
Standard DSP Array 1.0 (foo_dsp_std)
Album list panel 0.2.2 (foo_uie_albumlist)
ELPlaylist 0.6.4.2(beta) (foo_uie_elplaylist)
Playback Statistics Custom 1.4.3 (foo_playback_custom)
Graphical Browser rev015 (foo_uie_graphical_browser)
CD Audio Decoder 2.1.4 (foo_cdda)
Menu Addons 0.4.1 (SSE) (foo_menu_addons)
Columns UI 0.3.6.5 (foo_ui_columns)
Playlist Tools 0.6.2 beta 6 (foo_utils)
Skip Track 0.4 (foo_skip)
foobar2000 core 0.9.6.2 (Core)
Track info panel mod 0.8.0 beta [Jan 5 2007 - 13:36:12] (foo_uie_trackinfo_mod)
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]
Moderation: Codeboxed.[/size]
A crash in ATI OpenGL driver, used by Chronflow. Make sure you have installed the latest drivers for your graphics card.
I'm using Vista
I can't use mouse to select Albums in cover flow
I would have to agree with this, the most playlists I have at once is about five, and there's a lot of extra space. It would be awesome if you could add an option to change the height of the playlist.
Thanks Brett
For example. if an artist name contains a / , let's say Ac/dc then i use this variable to search for the cover
How can I convert my ibiza/curacao line to work with kameleon?
C:\Program Files\foobar2000\covers\$replace(%artist%,/,,?,,) - %album%.jpg
it worked in Curaçao, but then again, extended variable wasn't in use then...... can i in some way, get this to work in kameleon
again br3tt, i was sceptical at kameleon at first, but now i loooove it. your finest creation ever
Very nice config Br3tt, thank you.
It only takes 10 minutes to config Kameleon for my system, wow.
But I have a question for my understanding.
It seems that the bg pictures in Kameleon look sharper than in Curacao. Is there a different way in drawing or do I need new glasses?
Thank You!!!
but i don't know what component is responsible for that "startup playlist" thingy
Thanks a lot!
installed the latest driver today, still get the same problem.
important to notice that it works fine when i add some music folders one by one. but when i add all my main music dir, i get this crash, what can it be?
Hey Br3tt Congratulations on releasing the new config, it's good
Thanks for the collapsible track infos
but I'm stuck with extended variables, I can't get my artist pics to show. How can I convert my ibiza/curacao line
$puts(artist.path,$replace(%path%,$directory(%path%,1)\%filename_ext%,)artist.jpg)
into something working with kameleon?
tia
oh and... Is there any way to copy different parts of code between your configs? We can copy panels but pasting them into another configuration sucks Would like to have left part of Kameleon combined with the right part of Curacao
I have the problem that the Graphical Browser is black since i was in the options menu, but i didnt change anything! (the Album Art and the ABCDEF... - list doesnt show up)
ups fixed it!
but i have a question:
how can i change it that when i single-click on the abcdefg-list that the ELP-Panel jumps to that album?
...how can i change it that when i single-click on the abcdefg-list that the ELP-Panel jumps to that album?
Right click the letters/Settings/Others/Click actions/Single click/set it to (default)
It's how I have mine set too
oh, me again.
well, it's accepting and playing songs in right order i set to play, but there's no list to see which one is next.
edit: i get it by myself. pqviewer makes one playlist where he stores queue tracks
thanx brett
Can someone please tell me how i can sort a playlist by track and not by album? I have a playlist with radio streaming locations and it gets very ugly with this type of sorting.
hello Br3tt!
first thing first: Kameleon is absoluyely A M A Z I N G!!
man you're a foobar GOD!
but one thing doesn't work for me. it's foo_exvar and displaying artist photos.
i've specified my path and it is:
kameleon_artistart_path = G:\foo\artist\
so can anyone help? few pages earlier someone has the same problem but no one has post a reply.
pls help me!
hello Br3tt!
pls help me!
take care, you have forgotten a 'e' in kameleon_artistart_fil
ename, and if not enough to make it works just replace '\' by '/' and all will be perfect!
kameleon_artistart_path = G:/foo/artist/
btw, answer to your question already given on foobar2000.pl by
maciej3
is it normal that all visualisations stop when you scroll through the ELP-Panel?
btw, answer to your question already given on foobar2000.pl by maciej3
You're on polish forum :x damn, i love it even more now
Cheers from Poland
hello Br3tt!
pls help me!
take care, you have forgotten a 'e' in kameleon_artistart_filename, and if not enough to make it works just replace '\' by '/' and all will be perfect!
damn so lame
so THANK YOU very much and please man never DON'T stop what u do with foobar!!! damn fantastic!!!
done for the next build , here is a little preview ... btw i can't fix the size in the scroll text panel.
(http://xs536.xs.to/xs536/09081/kameleon_black652.png)
Cheers from Poland
My grand father was Polish, so i am a little too
i don't no, ask to the developper of PSS and Spectrum Channel components
Visualizations never stop for me, always running
I have beneath cover.jpg additionally back.jpg (backside of cover) and disc.jpg (disc picture). (from DUI Album Art).
Would be nice to have some use of this pictures in Kameleon.
They stutter with an intel Q9450. Processor timings go up significantly when you scroll through that panel.
Br3tt. The reason he messed it up is that you make the same typo on your default variable list on your website:
kameleon_artistart_filname = artist.jpg (and not %artist%.jpg !)kameleon_default_width = 864
You may fix this typo to stop confusion. Thanks.
On upper right corner of cover in ELPlaylist you can see the codex (mp3 or flac etc.).
Please consider to add widely used codex shorten (shn).
but I'm stuck with extended variables, I can't get my artist pics to show. How can I convert my ibiza/curacao line $puts(artist.path,$replace(%path%,$directory(%path%,1)\%filename_ext%,)artist.jpg)
tia
Hi Br3tt, I've got the exact same problem. I've got all my artist pics in the album folder of the artist just like I do with the folder pics. In curacao it worked with the code nikolai4ik uses but now in Kameleon I can't get it to work.
Also in Curacao you included the option of hiding the top bar. That option isn't available anymore in Kameleon, is it possible to include this?
Keep up the good work, Br3tt.
tia
For the last time, functions do not work with foo_exvar, learn to tag you %artist% tags to be free of this or find a better way to store artists pics... the best is a unique folder that contains all the artists images named %artist%.jpg (ex: Jimi Hendrix.jpg, ... ). Other way, modify the code in K to bypass foo_exvar uses...
Yep, i'll add an extended varaible to allow to hide/show the top panel (path)
really ? .... fixed, thanx.
Yeah That caught me out too Falstaff.
Excellent work as usual though. Got no complaints and I can not think of anything to improve.
Tell a lie is there anything you can do to make the custom menu's auto close instead of staying open once you clicked them?
[lie]Of course i can make them auto close!! done soon !![/lie]
Wait! That feature would be awesome...Is that really a lie that you can make them autoclose, or is that coming in a later build? I'd be stoked if you make it happen, Br3tt!
Unfortunately it can't be done
If it can not be done why not have the same menu system as Curaçao where it was a button that unfolded when needed sure it's gray but at least it auto closes.
Is it really that much of a problem to click one more time?
Playlist switcher in the left panel would be a better treat :x
You mean the whole playlist/quicksearch panel? I guess that would significantly streamline usage for people that navigate through their library that way. =) Let's hope our lobbying does not fall on deaf ears. Br3tt's got a lot of requests, though...We'll see.
All,
Maybe it's just me and this is REAL basic... Doesn't apply to Br3tt specifically...
When I go back into tag and rename after playing songs my tags are all messed up.
How do you use the "play count" and "ratings" without foobar messing up your tags? I find myself disabling these things because it wipes out hours of hard work. Do you folks edit the way your tags are updated within foobar? Thoughts?
Thanks, Casey
That is mostly caused by some dll files. You can try to delete all your dll files and just use the components given by Br3tt.
Amazing config - thanks!!
Quick question on Chronflow - is there any way to get it to display the first JPG it finds in an album folder to use for album artwork, i.e. *.jpg? I have this working well for all other album art splitters except Chronflow... if anyone knows how to get this working it would make my day!
Also, I recently installed the foo_discogs (http://www.discogs.com/help/forums/topic/147021) component and am having trouble downloading artist/album artwork. When I use the context menu on a track or album, the "Update Album/Artist Art" command is always grayed out... in the foo_discogs Configuration > Album/artist art tab, I have "Fetch" checked for both Album & Artist artwork, as well as "Fetch all available art" yet no artwork is being downloaded. I have tried using the "Write tags" command (the only one not grayed out besides "Configure tag mappings" and "configuration") and the album artwork is indeed present in the preview page - I just have no way to download it to the album folder! What am I missing? Any help is much appreciated - thanks again!
Not sure if this helps - but it seems that once I added the Artist Artwork variables to Extended Variables, I started experiencing this same scaling issue w/Album artwork in the main lefthand splitter. I added these 2 lines to Extended Variables:
kameleon_artistart_path - N:/Music/---- Artist Art ----/
Restarted foobar and while the Artist Artwork now worked fine, the album artwork had the scaling issue several people have previously mentioned. So I removed these 2 lines from exvar, restarted foobar, and the issue went away... hope this helps in some way to track down the issue.
2 pages back i asked
anyone who can figure this out . is it possible to somehow make it compatible with extended variables
look at this
nice config really! I finally decided to change my old one, as it is based on panels ui, and new foobar versions have so many tasty features
Now I'm trying to figure out all those new plugins, have some troubles
1. Where is chronoflow part in Kameleon? I removed it, and it seems ok... (it annoyed me with error message on the start, and do not have priviledges to update graphics card drivers).
2. Can I have 3 configs (Kameleon, Curacao and Ibiza) simultaneously and switch them on-the-fly in Preferences? Now when I import a config, all others disappear
3. Besides, I have noticed a strange glitch:
(http://img7.imageshack.us/img7/7608/foobarqjn1.th.png) (http://img7.imageshack.us/my.php?image=foobarqjn1.png)
The now playing text is too large (I had to reduce it from 19 to 6!). It might be due to 120DPI settings for my computer, however, I hope it helps someone.
Again, nice config, thanks!
Seems like you don`t have "snapix" font installed
Hmm, indeed I hadn't. Thank you!
(but again, had to set it to 14)
I guess we're in the same boat. I wrote about it on page 2 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=615397). Well, the thread is growing really fast!
I tried to do something myself, but the code for this is a lot more complex than in earlier configs. All those panels are closely connected to each other, to ELPlaylist and even some kind of check is performed. Anyway, a lot of code would have to be re-written. If you have the time, Br3tt... I would appreciate it
http://br3tt.online.fr/files/K/kameleon_1.0c2.fcl (http://br3tt.online.fr/files/K/kameleon_1.0c2.fcl)
test it and gimme feedback please[/b][/size][/color]
hi falstaff, first: the best foobar config ever....thanks
a litte qestion: is it possible to make the path to the artist pics relative (by using foobar as portable app)?
thanks
frank
lol!
i have a E6850 with 3.00 Ghz and foobar takes 50% when i scroll through the list!
I think i have found a new Benchmark for my PC!
And it takes 120 mb ram!
That really SUX!
But the Problem is:
The design kicks asses so i will stick to this config! (or i will by a new Intel Processor only for foobar!)
(http://www.freeimagehosting.net/uploads/a79c1079c9.jpg)
Still happening on about 1 out of 15 restarts with 1.0c2.
But, RAM memory usage went down about 10-15mb, and I was pleased about that.
Note: I do not use exvars for my album art.
Vista 32-Bit
Component List:
ABX Comparator 1.3.3
Album List 4.3
Converter 1.2
Convolver 0.3
Noise Sharpening DSP 1.0.0
Tube Sound 0.8
File Operations 2.1.1
freedb Tagger 0.6.1
Last.fm Radio 0.5.2
Masstagger 1.7.1
ASIO support 1.2.6
Kernel Streaming Output 1.2.2
Playback Queue Viewer 0.2
Run services 0.3.4
Skip Track 0.4
Columns UI 0.3.6.5
Quick Search Toolbar 2.8|
RAR reader 1.1
ZIP/GZIP reader 1.0
Shpeck - Winamp vis plugins wrapper 0.3.1
OK, i have re-coded the CD Case panel, now it must work for everyone
I appreciate your hard work, really, but I noticed this bug two times again.
Maybe it is not a code problem ? maybe foobar versions or operating systems, some components maybe... you know it much better I think
If you have any suggestions about components etc. incompatibility I would offer to everyone, who has this bug, show version of comp. etc., if needed of course, maybe we will find some regularity.
Anyway, this bug don`t make me inconvenience anymore, because it appear very rarely.
lol!
That really SUX!
But the Problem is:
problem is elsewhere, i have the same CPU and when no scroll, i'm under 2%, when scrolling, near 20%
about memory usage, it depends of the playlist size and library size. HERE, i'm near 65000 Kb with a library ~28000 tracks
thanks
frank
just try, it should work
very very very weird, maybe a Vista issue with Panel Stack Splitter, i'm under XP P3, and it never happens.
Hey, Br3tt! I'm not one for nitpicking, and this is not a behavior I really care about, but the interface moves down about 1 pixel when I click the aliencat.
Below are screenshots:
(http://www.freeimagehosting.net/uploads/e05909f7d1.jpg)
(http://www.freeimagehosting.net/uploads/fc6735a4e9.jpg)
For an easier comparison, just click the aliencat button really fast =).
How annoying, it never once cropped up during Beta testing but I am XP SP3 too, although I was also running it on Windows 7 on and off with no problems
Hey, Br3tt! I'm not one for nitpicking, and this is not a bug I really care about, but the interface moves down about 1 pixel when I click the aliencat.
Someone please help me...
thanks
frank
i tried in extended variables: kameleon_artistart_path = %FOOBAR_PATH%/artists
but it doesn't work!
just a tip to refresh all panels bg
thanks
frank
just enter :
./artists/
thanks
frank
just enter :
./artists/
it works!
falstaff = foobar king
another question:
i use multivalue field for artist (for example: "elton john; george michael")
if i have a pic in artist pic "elton john, george michael.jpg" it will be display....
but if i have only a photo by "elton john.jpg", can i display "elton john.jpg" when "elton john; george micheal" is playing?
in my old panels ui config with album art panel with this source worked fine: "Artists/$substr(%artist%,0,$sub($strrchr(%artist%,','),1) ).jpg", but that doesn't work in extended variables...
any idea???
thanks frank
@franki :
http://www.hydrogenaudio.org/forums/index....st&p=615869 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=615869)
I am planning to switch to Vista over the weekend are all plugins compatible with Vista?
normally yes
i really think that is a Vista problem with PSS, coz all people that have reported this to me are under Vista ... is someone with this bug under XP ?
If you don't use foo_exvar for cover art (because file already named folder.jpg and are stored in music folder), try to enter this and see if it fix the problem (maybe ...) :
kameleon_coverart_path = default
After some tries, I can say that it still happens. I'm running Vista SP1, foobar 0.9.6.3 beta 1, and Kameleon 1.0c2.
It doesn't happen everytime though, I have to restart foobar a couple of time before seeing the effect.
(http://i193.photobucket.com/albums/z210/dagneau/foobar2000.png)
Entering:
This still allows the bug to happen. It occurs about once every 10 or 15 foobar restarts and is fairly random.
All of the plugins I listed here
http://www.hydrogenaudio.org/forums/index....st&p=615937 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=615937)
are the latest as of 2/17/2009 and work perfectly under Windows Vista.
The ones provided by Br3tt are also compatible, except foo_skip.dll in an early revision of Kameleon, which should have been replaced by http://www.saunalahti.fi/~cse/foobar2000/foo_skip.zip (http://www.saunalahti.fi/~cse/foobar2000/foo_skip.zip) by now.
Bug still there.
Just wanna show you some details:
(http://www.abload.de/thumb/greenshot_2009-02-17_2xrhn.jpg) (http://www.abload.de/image.php?img=greenshot_2009-02-17_2xrhn.jpg)
(http://www.abload.de/thumb/greenshot_2009-02-17_2bqtc.jpg) (http://www.abload.de/image.php?img=greenshot_2009-02-17_2bqtc.jpg)
Small arrows in first pictures are missing (red ovals)
Jewel case seem to be smaller in first picture and drifted to left.
Hope that helps.
I'm using Vista SP1 too.
The same happens with my bug. In fact, the jewel cases shift identically, and the covers contract just the same. So, while the bug is random, the effects are pretty predictable, which might lead to some way to fix it. Who knows?
This post may have gotten lost in the shuffle of sorting out the album art scaling issue, so here goes again... any help is much appreciated!
- Quick question on Chronflow - is there any way to get it to display the first JPG it finds in an album folder to use for album artwork, i.e. *.jpg? I have this working well for all other album art splitters in Kameleon except Chronflow... if anyone knows how to get this working it would make my day!
- Also, I recently installed the foo_discogs (http://www.discogs.com/help/forums/topic/147021) component and am having trouble downloading artist/album artwork. When I use the context menu on a track or album, the "Update Album/Artist Art" command is always grayed out... in the foo_discogs Configuration > Album/artist art tab, I have "Fetch" checked for both Album & Artist artwork, as well as "Fetch all available art" yet no artwork is being downloaded. I have tried using the "Write tags" command (the only one not grayed out besides "Configure tag mappings" and "configuration") and the album artwork is indeed present in the preview page - I just don't see how to download it to the album folder! What am I missing? Any help is much appreciated - thanks again!
- Does anyone have a favorite Album Art Downloader? I have been using Album Art Downloader XUI v0.24 which seems to work great, but is there something even better out there (preferably a Foobar component so I can download art while listening to an album)?
Hi Br3tt !
I think, one of a solution would be replacing cd cover code from Curacao config, because I have never seen this liitle bug in Curacao before.
I guess it is not so important to see cover inside of CD case or without this one The special version for Vista users f.e..... before you self will return to Vista
To
Lonk NY# Quick question on Chronflow - is there any way to get it to display the first JPG it finds in an album folder to use for album artwork, i.e. *.jpg? I have this working well for all other album art splitters in Kameleon except Chronflow... if anyone knows how to get this working it would make my day!
It is impossible as I know, you can only add variables like
... and any possible names of covers you have
The simpliest way is using constant name of covers or use programs for grouping file rename if you have so huge music collection.
it doesn`t exist. as far as I know again
By the way, I use Album Art Downloader too with script which automatically saves cover art files into album/artist folder with name "folder.jpg" and problem of Chronflow you are talked above is solved.
You are wrong here.
The possible option is CD Art Display, except latest beta is buggy for me. it is standalone, but integrates into foobar via component.
Got serious Problems here:
When a Song got a "timestamp" like:
<FIRST_PLAYED> : 2009-02-18 12:25:55
<LAST_PLAYED> : 2009-02-18 12:25:55
<PLAY_COUNTER> : 1
<PLAY_STAMP> : 2009-02-18 12:25:55
The "title"-info will promptlydisappear. While playing a song the first time, this happens even within listening to it.
What should i do? Remove play_counter?
Falstaff
good job, amazing config
it possible, make album art bigger? (like in curacao)
Falstaff
just read the installations notes
d) Width of the optional left panel:
kameleon_left_panel_width : numeric value [320-500]
http://br3tt.free.fr/html/K/index.htm (http://br3tt.free.fr/html/K/index.htm)
<PLAY_COUNTER> : 1
which components are you using to save stats ?
- Playback Custom Statistics or Play counter (official stats plugin)
PCS store stats info in the music file TAGs
PC store them in a database and do not affect the music file
go to Prefs --> Tools ---> ...
and be sure you have set them the way you want
Falstaff
thank you, sorry for silly question
My foobar is black!
[a href="http://img179.imageshack.us/my.php?image=f2kug0.jpg" target="_blank"]
Would it be possible to jump to the default playlist/or previous by clicking the Kameleon button?
Because i think it would be more usefull than resizing f2k!
OK, new try that might fix the bug on Vista or Seven systems ...
http://br3tt.online.fr/files/K/kameleon_1.0c5.fcl (http://br3tt.online.fr/files/K/kameleon_1.0c5.fcl)
test it and gimme feedback please, ty
Ok, I couldn't wait any longer, so I added Playlist switcher and Album list to the left panel myself. It works the same as in Curacao, without covering parts of ELPlaylist.
Br3tt, if you are interested, I could send it to you and you could incorporate it in further versions.
I'm really happy because that was the only thing about Kameleon that I didn't like. Now it's perfect
I'm interested in that, I too found the new playlist switcher a bit...well... a bit too big. Mind sharing with us exxecutor?
OFF TOPIC, ELPlaylist topic recommended for this. btw here is some help :
right click ion ELPlaylist -> Settings
then
1.modify the default group by order and/or the default sort order
OR
2.add an alternative sort order that you can use by right click contect menu
(http://img17.imageshack.us/img17/1808/sortwz1.th.png) (http://img17.imageshack.us/img17/1808/sortwz1.png)
thanks mate. love ya
Very nice!!! How the heck did you pull that off? Now, I wouldn't mind to have it be just half of the left panel (with album art on top) and as a clickable panel, but I am sure that if Br3tt goes that way, he can easily pull it off.
@felimz:
is the bug fixed ??? http://www.hydrogenaudio.org/forums/index....st&p=616261 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=616261)
@felimz:
I was just writing my post regarding this.
YES!!!!! After about an hour of testing, I cannot reproduce the bug. I think you fixed it my friend.
What seemed to be the problem? I'm intrigued?
@felimz:
great news
PSS bug with Vista or Seven(sometimes default %width%, %_height% seem to be weird... or somthing like that)
i was displaying the Cd Case in a PSS panel included in another one (Parent) which was integrate in the main PSS one, so 3 level of PSS embedment. I've reduce this # of level to 2 by coding the cd case display in the PSS level 2 and removed the unused level 3
@felimz:
great news
Ah, well, you are the man!!! I can't wait until you release it officially along with any other little changes you might be working with.
Again, THANK YOU, Br3tt!
The cover scaling bug seems to be fixed, people!!![/size]
Hmm, no transparency.
hell yeah! br3tt would u mind looking into this :> Kameleon would be complete for me then (and many others for sure )
Do you mean transparent playlist switcher and album list? Is this even possible?
To share what I did (toggle-able playlist switcher and album list over the left panel): Link! (http://rapidshare.com/files/199768897/Kameleon_left_panel.fcl)
To alter the dimensions of the panel, right click on the playback buttons to enter the main splitter settings, script-tab, scroll down and change the numbers shown below.
Afaik unfortunately not.
Is there any way to display some global playlist info? Like e.g. how many albums or tracks are in a playlist etc.
Enjoy
Thanks! Already using Maybe it's not Br3tt-perfect but very useful
Enjoy
Thanks for the fcl exxecutor, I got two small questions though. You seem to have opted for a non-capitalized playlist for the tracks, could you point me in the direction on how to change them back to capitals cause I can't seem to find it.
Also, how did you get those playlist stats on your playlist switcher?
Enjoy
Pretty kickass temporary implementation until hopefully Br3tt makes this a part of the UI somehow...
Right now I got my numbers at:
(-> Left_Playlists,12,60,296,332)
(-> Left_Albumlist,10,56,298,340)
and it works beautifully with Kameleon's default dimensions.
Thanks!!! =)
Note: Could you reupload this left-panel config after Br3tt posts the new Kameleon revision that fixes the cover scaling bug in Vista? Thanks!
I want to use the set of buttons for Next/Prev/Play/etc from Curacao in Kameleon, as they are much brighter. But buttons "bt-open-off/bt-open-on" are not present in Curacao. Is there any chance to find them?
Enjoy
just right click on the playlist to enter ELP settings, then go to tab 'field definition' then search the CAPITALIZE entry, and replace 1 by zero to disable it
Kameleon run pefect now!
Thanks for the positive response I'm definately no PSS pro, that's why I really hope that Br3tt would take over this project.
For now, this (http://rapidshare.com/files/199918513/Kameleon_1.0c5_left_panel.fcl) is the updated version!
It's basically %length% and %size%. In the playlist switcher preferences, tick "Use titleformatting" and enter your code.
Edit: This is my full code (something similar was posted here some time ago):
////////CONFIG////////
////HEADER COLOR////
$puts(headercol,$rgb(100,150,250,255,255,255))
////NORMAL PLAYLIST COLOR////
$puts(listcol,$rgb(255,255,255,150,200,255))
////NOW PLAYING////
$puts(nowplaycol,$rgb(100,150,250,100,150,250))
$puts(nowplayindic_a,'>>' )
$puts(nowplayindic_b, '<<')
$puts(nowplayindic_c, '<>')
$puts(nowplayindic_col,$rgb(100,150,250,255,255,255))
////ITEM-COUNTER COLOR////
$puts(countercol,$rgb(144,144,144,255,255,255))
////ITEM-LENGTH-COLOR////
$puts(lengthcol,$rgb(88,88,88,144,144,144))
////FADING LINE COLORS////
$puts(fadebegin,$rgb(100,150,250,255,255,255))
$puts(fadeend,$rgb(255,255,255,100,150,250))
//FADING IN SECTION HEADER//
$puts(fadesymbola1,\)
$puts(fadesymbola2,/)
$puts(fadelengtha1,30)
$puts(fadelengtha2,30)
//FADING IN DIVIDER//
$puts(fadesymbolb1,--)
$puts(fadesymbolb2,)
$puts(fadelengthb,35)
////////CONFIG-END////////
$if($greater($len(%title%),0),
$if($strcmp(%title%,-),
$transition($repeat($get(fadesymbolb1),$get(fadelengthb)),$get(fadebegin),$get(fadeend))
$transition($repeat($get(fadesymbolb2),$get(fadelengthb)),$get(fadeend),$get(fadebegin)),
$if($strcmp($left(%title%,1),-),$transition($repeat($get(fadesymbola1),$get(fadelengtha1)),$get(fadebegin),$get(fadeend))$get(headercol)
$substr(%title%,2,$len(%title%)) $transition($repeat($get(fadesymbola2),$get(fadelengtha2)),$get(fadeend),$get(fadebegin)),
$if($stricmp($right(%title%,3),-AB),
$if(%is_playing%,$get(nowplayindic_col)$get(nowplayindic_a)$get(nowplaycol)$left(%title%,$sub($len(%title%),3))$get(nowplayindic_col)$get(nowplayindic_b),$get(listcol)$left(%title%,$sub($len(%title%),3))),
$if($stricmp($right(%title%,2),'-S'),
$if(%is_playing%,$get(nowplayindic_col)$get(nowplayindic_a)$get(nowplaycol)$left(%title%,$sub($len(%title%),2))$get(nowplayindic_col)$get(nowplayindic_b),$get(listcol)$left(%title%,$sub($len(%title%),2))),
$if($stricmp($right(%title%,2),'-R'),
$if(%is_playing%,$get(nowplayindic_col)$get(nowplayindic_a)$get(nowplaycol)%title%
$get(nowplayindic_col)$get(nowplayindic_b),$get(listcol)%title%)
$tab()
$ifgreater(%size%,0,$get(lengthcol)%length%
//$if(%is_playing%,$get(countercol)|$get(nowplayindic_col)$get(nowplayindic_c),)
$get(countercol)|%size%,)
Thanks exxecutor. One last thing and then I'm off your back. How can I add padding settings for the stats on the playlist so they don't stick to the outer right edge of the playlist switcher?
great news
Hey Br3tt !, You are genius
The bug seems to be FIXED !!!Thank you so much!
<PLAY_COUNTER> : 1
I had Playcount.dll and playcountstatistics.dll, removed the last one and tried manually removing the time stamps by rightclicking and going to properties.
But nothing happend. Really bad shit, didnt had these problems with older configs from you.
Still with playcount.dll its the same thing: after aproxximatly one third of having played one song -> song title gets invisible.
Br3tt, would you help me please !
There is one problem, that I can`t solve, and it`s not for El Playlist topic I guess.
Every time, after adding new files using Album List, I have to right click on playlist and choose sort - preset default, to sort playlist as I want (by Album)
Take a look at screenshot please, maybe there is some settings in the code, that I don`t know
(http://img242.imageshack.us/img242/8625/foobarje0.th.jpg) (http://img242.imageshack.us/my.php?image=foobarje0.jpg)
[a href="http://img242.imageshack.us/my.php?image=foobarje0.jpg" target="_blank"]
I am having what I think is the same problem. When I search, for example "Pink Floyd," the first album that comes up is "A Collection of Dance Songs." This means that it is sorting alphabetically, even though I have all sorting rules to sort albums by date. After I click on "Sort>>preset default," the playlist gets arranged correctly and "The Pipe at the Gates of Dawn" appears first.
I have tried all ways of sorting, but it ain't working. I have also done "Force Sorted," but the search results always get sorted alphabetically. I have even removed /runcmd=Playback/Order/Default from the startup shortcut.
Note: this only occurs on the search results, not on my library autoplaylist.
For now, this is the updated version!
Thanks, man!!! =) Excellent job.
hi falstaff, your config is the best working config ever...i use foobar for many years and now it looks good, too! thank you for your work.
i change some things like color and use a playlist switcher on the left and a filter for better search and kick the chronflow, while to slowly...
here 2 screens:
Screenshot 1 (http://www.dj-atrac.de/bernstein.jpg)
Screenshot 2 (http://www.dj-atrac.de/bernstein2.jpg)
thanks!
frank
ich höre musik, also bin ich!
Auto Playlist Properties/force sorted
It is playlist switcher option, am I right?
But I want to use Album list panel
I noticed that foobar sorts my music by ARTIST every time, independently that I write in the "sort format".
I just want get sort by album after clicking on Album list, without context menu.
not due to Kameleon or ELP, coz it works fine for me.
Playlist used by Album List Panel is 'Library View' and just the first time the playlist is created, i use context sort menu to apply default preset sort
then when clicking on an artist in Album List, it automatically (Album List Panel Settings!) send tracks of this artist WELL SORTED in the 'Library View' playlist.
check your settings.
here 2 screens:
thanks!
frank
you're welcome
what is the component under ELP in the Screenshot #2 ? CUI filters ??
you're welcome
[/quote]
correct, filters!
correct, filters!
[/quote]
not facets and not so comfortably but it works!
@Freedom-loving
Preferences --> General --> Sort incoming files by: %path_sort%
It seems to work with your ELPlaylist settings, so i guess your music's stored properly
You can experiment with $tab(n) in your playlist switcher code (adds n tabulator characters). For instance:
%title%$tab(3)%size%$tab(2)
Another thing you could do is change the width of your playlist switcher. Go to Splitter Settings, select -> Left_Playlists, click Configure, select Playlists and change the width to whatever you like. Note that if you have many playlists and do that, the scrollbar will come into view.
Does anybody know why Chronflow's "Find as you type" is only working in an extra window (Dockable Panels) but not in a PSS in Kameleon?
Another point. In 1.0c5 the cover overlay for the big picture is not working for me, in 1.0c2 everything is fine - chair-foobar-problem?
Hey Br3tt, thanks again!
I have a little problem, any time i open the cover flow, foobar freezes and i get this log:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 04C0DF5Ah
Access violation, operation: read, address: 0C556000h
Code bytes (04C0DF5Ah):
04C0DF1Ah: 38 8B 4C 24 44 8D 14 7F 8B C2 8B 54 24 50 2B D0
04C0DF2Ah: 85 ED 8B 01 8B 4C 24 54 89 54 24 34 0F 86 12 02
04C0DF3Ah: 00 00 89 6C 24 38 83 FF 03 8B F7 76 65 8D 57 FC
04C0DF4Ah: C1 EA 02 83 C2 01 8B 19 81 CB 00 00 00 FF 89 18
04C0DF5Ah: 8B 59 04 0F B6 69 03 81 CB 00 00 FF FF C1 E3 08
04C0DF6Ah: 0B DD 89 58 04 8B 59 08 0F B7 69 06 83 C0 04 81
04C0DF7Ah: CB 00 FF FF FF C1 E3 10 0B DD 83 C0 04 89 18 8B
04C0DF8Ah: 59 08 C1 EB 08 83 C0 04 81 CB 00 00 00 FF 89 18
Stack (086EF968h):
086EF948h: 7C967E3F 7C9CB178 7C967DE9 01E59E84
086EF958h: 028F25A0 0000FFFF 7FFDF000 00265688
086EF968h: 00000000 0DAD7D30 00000000 0799FD00
086EF978h: 00000008 00000000 0000000A 0000000C
086EF988h: 00000000 000002E8 00000000 00000006
086EF998h: 04C16CEF 00000003 00000001 00000101
086EF9A8h: 00000007 07B18F30 00000000 00000000
086EF9B8h: 00000558 0C4C0020 00000000 00000000
086EF9C8h: 00000000 00000000 00000000 00000007
086EF9D8h: 086EF9C8 086EFA10 086EFC0C 086EFA18
086EF9E8h: 052A0000 7C960202 00000011 052A09B8
086EF9F8h: 052A0000 0DAD7D30 086EF9F0 7C9600A4
086EFA08h: 086EFC34 7C95E900 7C960208 FFFFFFFF
086EFA18h: 7C960202 7C96017B 7C9601BB 0000007C
086EFA28h: 00000000 7C9600A4 0C180000 00000000
086EFA38h: 052A0050 08210000 0C4C0000 086EFA78
086EFA48h: 01870000 7C960202 00000011 018709B8
086EFA58h: 01870000 0833D728 04C14F2B 0799FD00
086EFA68h: 0DA7DC68 0DA7DC68 07999D08 00000001
086EFA78h: 07942148 018709B8 01870000 0834A0F0
Registers:
EAX: 0F7678EC, EBX: FF000000, ECX: 0C555FFC, EDX: 00000066
ESI: 0000019B, EDI: 000001C7, EBP: 00000000, ESP: 086EF968
Crash location: "atioglxx", loaded at 04720000h - 0529A000h
Symbol: "atiPPHSN" (+004C958Ah)
Loaded modules:
apphelp loaded at 771F0000h - 77212000h
foo_playcount loaded at 00B10000h - 00B3A000h
foo_discogs loaded at 00B60000h - 00BF7000h
foo_ui_std loaded at 00CE0000h - 00DB4000h
foo_uie_lyrics loaded at 00DE0000h - 00E3D000h
Normaliz loaded at 00E50000h - 00E59000h
foo_uie_trackinfo_mod loaded at 01080000h - 010D6000h
foo_exvar loaded at 01100000h - 01128000h
foo_rgscan loaded at 01250000h - 012AB000h
foo_uie_graphical_browser loaded at 012D0000h - 01364000h
foo_uie_vis_channel_spectrum loaded at 01380000h - 013BD000h
foo_menu_addons loaded at 013E0000h - 0141C000h
foo_cdda loaded at 01440000h - 01480000h
foo_ui_columns loaded at 014A0000h - 015DB000h
foo_converter loaded at 01600000h - 0166C000h
foo_utils loaded at 01690000h - 016D4000h
foo_uie_elplaylist loaded at 01700000h - 01769000h
foo_runcmd loaded at 01790000h - 017C4000h
foo_uie_wsh_panel loaded at 017F0000h - 0181F000h
foo_audioscrobbler loaded at 01990000h - 019C0000h
foo_albumlist loaded at 019E0000h - 01A4B000h
foo_skip loaded at 01A70000h - 01A8D000h
foo_input_std loaded at 01AB0000h - 01BEF000h
foo_uie_albumlist loaded at 01C10000h - 01C4D000h
foo_lastfm_radio loaded at 01C70000h - 01CB8000h
foo_run loaded at 01CE0000h - 01D0D000h
foo_playback_custom loaded at 01D30000h - 01D75000h
foo_vis_shpeck loaded at 01DC0000h - 01DFE000h
foo_chronflow loaded at 01E20000h - 01E81000h
foo_uie_quicksearch loaded at 029B0000h - 029F6000h
foo_dsp_std loaded at 02A20000h - 02A68000h
foo_input_alac loaded at 02A90000h - 02AB0000h
foo_uie_panel_splitter loaded at 02AD0000h - 02B1F000h
atioglxx loaded at 04720000h - 0529A000h
xpsp2res loaded at 08DB0000h - 09386000h
mswsock loaded at 719A0000h - 719DF000h
DNSAPI loaded at 76EC0000h - 76EE7000h
mdnsNSP loaded at 16080000h - 160A5000h
Iphlpapi loaded at 76D00000h - 76D19000h
rasadhlp loaded at 76F60000h - 76F66000h
hnetcfg loaded at 62F40000h - 62F97000h
wshtcpip loaded at 719E0000h - 719E8000h
Address: 04C16CEFh, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 04C14F2Bh, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 01096000h, location: "foo_uie_trackinfo_mod", loaded at 01080000h - 010D6000h
Address: 04BD2E26h, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 04BD68BBh, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 04BD67F6h, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 04C11EB6h, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 04BD0F1Fh, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 0479C233h, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 048858E0h, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 04A3E375h, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 5F1C32ECh, location: "OPENGL32", loaded at 5F1C0000h - 5F28C000h
Symbol: "glTexImage2D" (+0000002Ch)
Address: 01E2FE5Dh, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 01E226CBh, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 7C802530h, location: "kernel32", loaded at 7C800000h - 7C94D000h
Symbol: "WaitForSingleObject" (+00000000h)
Address: 01E2225Fh, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 01E55788h, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 01E4356Ah, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 01E6F958h, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 01E4704Fh, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 01E21DF9h, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 01E437FBh, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 01E452B0h, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 01E438A0h, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 01E43821h, location: "foo_chronflow", loaded at 01E20000h - 01E81000h
Address: 05051515h, location: "atioglxx", loaded at 04720000h - 0529A000h
Address: 00505050h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004F4F4Fh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 05050000h, location: "atioglxx", loaded at 04720000h - 0529A000h
Version info:
foobar2000 v0.9.6.2
UNICODE
Windows 5.1
Additional info:
Discogs Tagger 1.15 (foo_discogs)
Audioscrobbler 1.3.16 (foo_audioscrobbler)
ALAC Decoder 1.0.1 (foo_input_alac)
at first i had this problem every time i just oppened foobar. i mannaged to find out that the problem was with to cover arts, kinda wierd but when i've deleted them the problem was solved. now the problem is only when i open the cover flow.
(http://img21.imageshack.us/img21/9962/44535985yx6.th.jpg) (http://img21.imageshack.us/my.php?image=44535985yx6.jpg)
Maybe you have to update your graphic driver - and use "["codebox"]" for such long text, please.
If someone would like to have the old Ibiza CD-Case, I have modified it.
(http://img19.imageshack.us/img19/8991/75484797dt2.th.png) (http://img19.imageshack.us/my.php?image=75484797dt2.png)
Download: http://rapidshare.com/files/200338779/case.7z (http://rapidshare.com/files/200338779/case.7z)
@Falstaff
I am looking for a reasonable Auto-Rating mode since cwb_hooks doesn't work anymore (and there is no other solution to get the system date to my knowledge).
So i decided to download your kameleon and "spy out" your solution .
At first, i'm very impressed by your work
Your kameleon is really fabulous, but:
1.) Rating
You have a clever solution but it has the same problem like all other current ones:
It only considers the time between first played and last played, since there seems to be no other way for that purpose.
Not your fault, but the lack of a function that calls the system date.
If you - the master of configuring foobar - couldn't find anything reasonable, i'll probably do it without auto-rating as long as it isn't possible to catch the system date.
But has it ever struck you that you have different "autorate.nbdays.sub" variables in Trackinfo mod and ELPlaylist?
That causes a different display of auto-rating (Trackinfo mod substracts 1 playcount all 5 days, ELPlaylist only 1 playcount all 30 days).
And you use Playback Statistics and Playback Custom in your config.
You should renounce Playback Custom, since it updates tags silently (only a proposal ).
If you'd stick on the official Playback Statistics there is another thing:
Have you known that Playback Statistics offers a %played_per_day% field?
You could radical shorten your Auto-Rating code with it if you'd use (with "autorate.nbdays.sub"=30):
//$if(%_isplaying%,
$puts(autorate.add,2)
$puts(autorate.nbdays.sub,30)
$puts(daterange,$ifgreater(%play_count%,1,$muldiv(%play_count%,100,$replace(%played_per_day%,.,)),0))
$puts(fix,$div($get(daterange),$get(autorate.nbdays.sub)))
$puts(counter,$sub($div(%play_count%,$get(autorate.add)),$get(fix)))
$puts(rating,$if2($meta(rating),$if2(%rating%,$ifgreater($get(counter),5,5,$ifgreater($get(counter),0,$get(counter),0)))))
$puts(no.set,$if(%rating%,1,2))
instead of:
//$if(%_isplaying%,
$puts(aa-fp,$year(%first_played%))
$puts(mm-fp,$month(%first_played%))
$puts(jj-fp,$day_of_month(%first_played%))
$puts(aa-lp,$year(%last_played%))
$puts(mm-lp,$month(%last_played%))
$puts(jj-lp,$day_of_month(%last_played%))
$ifgreater($if2(%rating%,0),0,
$puts(rating,$if2(%rating%,0))
$puts(no.set,1)
$ifgreater($get(aa-lp),$get(aa-fp),
$ifgreater($get(mm-lp),$get(mm-fp),
$puts(nb.aa,$sub($get(aa-lp),$get(aa-fp)))
$puts(nb.mm,$sub($get(mm-lp),$get(mm-fp)))
$ifgreater($get(jj-lp),$get(jj-fp),
$puts(nb.jj,$sub($get(jj-lp),$get(jj-fp)))
$puts(nb.mm,$sub($get(nb.mm),1))
$puts(nb.jj,$add($sub(30,$get(jj-fp)),$get(jj-lp)))
$puts(nb.aa,$sub($sub($get(aa-lp),$get(aa-fp)),1))
$puts(nb.mm,$add($sub(12,$get(mm-fp)),$get(mm-lp)))
$puts(nb.aa,0)
$puts(nb.mm,0)
$puts(nb.jj,0)
$puts(autorate.nbdays.sub,5)
$puts(daterange, $add( $add($mul(365,$get(nb.aa)),$mul(30,$get(nb.mm))),$get(nb.jj)) )
$if(%play_counter%,$puts(rating,$div(%play_counter%,$get(autorate.add))),$puts(rating,0))
$puts(rating,$sub($get(rating),$get(fix)))
$if($greater($get(rating),5),$puts(rating,5))
$if($greater(0,$get(rating)),$puts(rating,0))
$puts(no.set,2)
It should do the same (except rounding errors. But this effects your code too), if i understood your auto-rating purpose right.
2.) Playlist Switcher
It seems that there is a problem with the dimensions of the playlist switcher (maybe... )
[a href=\"http://www.abload.de/image.php?img=kameleonn9u6.png\" target=\"_blank\"]
And i hope you pardon my blasphemous post...
EDIT: typo
EDIT2: Inserted a shorter code.
EDIT3: Problem with Playlist Switcher recognized and solved by lowering the height of it (to activate its scrollbar).
I hope this has not been discussed yet, but I have a bug when using Kameleon.
The shortcuts via the letters at the bottom of the playlist do not work for me. I can click the letters, but it doesn't jump to the right spot on the list. I created the autoplaylist as instructed and am using foobar v0.9.6 on a Vista x64 Machine.
I used Curacao before and it worked without any issues!
Any help would be appreciated.
Tried. still not good.
right click in panel--->settings--->other--->single click action---> default
That did it bubi,
thanks alot!
@Falstaff
thanx, fixed
You should renounce Playback Custom, since it updates tags silently (only a proposal wink.gif).
i use only Playback Custom to embed stats in music file tags, official playcount component only use to get the %add% stat info.
While we're on the subject of ratings & statistics... regarding the ratings tool that is underneath ELP (5 "stars" and heart) - I would like to update my config so that it saves the ratings to a database rather than tagging the actual file. Is this possible and/or recommended?
You can do it by changing the command for each button in the trackinfo mod panel.
I currently don't have kameleon installed but look at entries like:
$button(0,0,0,0,16,16,$get(n.image),$get(mh.image)1.png,TAG:SET:rating:1,)
And change this part:
TAG:SET:rating:1
to simply:
1
and you'll have the rating information stored in the playback statistics database instead of the files tags
e) Cycle the wallpaper background: # of wallpaper that are cycled
kameleon_cycle_bg : numeric value [1-6]
Can you give more information, how this works? Can I cycle between different artist photos? Is this limited to wallpaper? What do I have to change in Script to access all artist photos? Did I miss some information in your instructions?
yes, it's limited to wallpapers only (not for artist photo ou cover cd).
if # of wp is > 1, then wallpaper will change depending of the active track name (using $CRC32 function as a random function)
Is it possible to make one image a default artist image if there isn't any? some cd backgrounds are just too crowded for decent use.
oh yeah Br3tt you rock with these skins. It's truly amazing work that you keep making.
Thanks for all the help getting this config tweaked... this is by far the best foobar config yet... One strange thing I have noticed tho is that when I play the first track after opening foobar/Kameleon, it pauses for well over a minute or two, frozen, and I can see in Task Manager that WERFault.exe is using most of the CPU (25% on a quad core). After about a minute or two foobar will unfreeze, the track will start playing and werfault.exe will exit. This has also happened when the 2nd track starts, but never the 3rd or following tracks. Only 1st or 2nd tracks after opening Foobar.
Also, is it normal for this config to use 365MB RAM? That is what it is using on my system - luckily I have 4GB but I still thought that was quite a bit... I am also using Milkdrop2 for my Vis, and only Cover Art above this on left sidebar...
FYI I am running Vista Ultimate SP1 x86 w/4GB PC2-1066 RAM & Q6600 C2Q proc. Any help or other similar experiences would be much appreciated - thanks.
At about 3,000 songs, with Milkdrop and Coverflow enabled, my Kameleon fb2k does not tax more than 100MB RAM out of the system. CPU (Q9450) usage fluctuates from 3% from 7%.
Note: Windows Vista Ultimate 32-bit with latest compatible plugins installed, plus ASIO and five DSP's running at all times.
my short answer (and btw preview of v1.1 ):
(http://xs536.xs.to/xs536/09086/charge249.png.xs.jpg) (http://xs536.xs.to/xs536/09086/charge249.png)
i'm under XP SP3 with 4GB of RAM + C2Duo E6850 + nvidia 8800 GTS
Libray is near 29000 tracks. RAM never go over 100,000 Kb.
Br3tt,
Are the changes/additions I see on that screen-shot ever going to make it to the official release? Some of those things look pretty nifty (I see a mute button, a quicksearch bar to the left (?), a gorgeous background, and some + -- icons!)?
=) Here's to hoping!
EDIT: This post has been edited by Falstaff: Today, 19:50 (!!!)
Disregard, please.
Album List and Playlist switcher panels will be integrated in left panel (buttons AL and PANEL around the QuickSearch toolbar)
the 4 buttons near the QuickSearch toolbar are Quicksearch for the same ... Artist/Album/Title/Genre
+ & - are buttons to Expand or Collapse groups in the Playlist
Mmmm 55090 tracks takes 200mb of memory lol but I do run other plugins like the known memory hog winamp DSP for DFX as the lazy asses at DFX aint made one for foobar.
IF there is a decent DSP plugin for foobar let me know.
Nice additions though, going to be real useful.
this is just too beautiful to be true I think you will cross another line of awesomeness with 1.1 Can't wait and thank you sooo much for listening to our requests
I will answer this question, although it is sort of off-topic:
I use (what I think are) five essential foobar plugins: Resampler (PPHS)>>Convolver>>Noise sharpening>>Advanced Limiter>>Tube Sound
That is the actual chain I run, in that order. My modded X-fi has a better frequency response at 24bit 48Khz, so I resample all music accordingly. Then, I convolute the audio from an RMAA impulse response using convolver, which tends to serve as a natural equalizer for my card. Noise sharpening uses a delta function f(x) + f(x)' to heighten peaks, which works quite well...I set this at 50% even though some people use it at different levels for different reasons, like cleaning up pops from vynil rips. Advanced Limiter prevents clipping due to your hardware/software/file setup, so I typically have this component last. Finally, I add a tube sound amp. simulator, which warms up the music quite a bit. I put it after the limiter because tube distortion usually works through sound clipping (although with pleasant results).
I hope this helps...sorry for the digression. But, to tie back into the thread, Foobar2000 plus Kameleon runs at less than 100MB/7% with all of this enabled (including visualizations).
NOTE: I keep compulsively reloading this page waiting for release 1.1! I'm so stoked. =)
Two things I've noticed that you may want to look into, Brett...
1. In the "Info" panel in the left-hand panel set, under "User Info," "Album gain" and "Track gain" both show the "dB" value twice. Example, "Album Gain: -9.11 dB dB." I removed the extra "dB" from the per-second coding for that panel. You may want to change this in the next release of Kameleon.
2. Also, not sure if this is a Kameleon issue or not, but when I add new tracks to the media library then play them for the first time, the playstamp is given the value "2" instead of "1". Any ideas?
Thanks again for your work on this config!
Edit: Actually, I've been noticing with ANY track I play, the playcount is getting updated twice. So a track with a playcount of 2 increases to 4, after being played once. (it should go to 3!)
Falstaff, while you're working on v1.1, have you looked into the problem with foo_input_mslive, I can hardly believe I'm the only one using it? A fix would be greatly appreciated.
And a suggestion, ever considered a own NoCD cover for radio stations, like you did for last.fm, when there is no album art?
Wow, that new left panel looks so promising! Exactly what I was waiting for. Thanks so much!
it's becauses stats writing are activated in the both stats plugins !!! you have to disable stats wrinting in foo_placount.dll (Prefs -> Tools -> Playcounter, then uncheck the 3 TAGs inthe Tag writing frame)
after, in the settings of Playback Statistics Custom, select where stats have to be written (files or database)
i have explain that in the doc for 1.1, so not available online yet
It will be hard for me to say goodbye to my in the meantime very loved Curacao.
you can do it soon ... i'm preparing hte packages for v1.1a
ohh nice! can't wait to upgrade:)
doc updated; Takaji, just check the chapter D/ all is explained
and ...
v1.1a released !!!
cheers
got a prob after updating see:
(http://hakker.hopto.org/temp/foobar.jpg)
I guess
kameleon_elp_header_height
in extended variables is set to 0 by default.
Set it to 3 and all will be back to normal (worked with me)
Got the same problem as above:(
And got something else. I can't configure the foo_playcount.dll plugin. it does not appear in the preferencesmenu. any help?? thx
ok, fixed, download the .fcl file one more time, should be fine now.
I guess
right ! but now, it's fixed, if extended variable kameleon_elp_header_height do not exists, it takes the value 3
Very nice
First I was surprised because the headers were gone, but it was easily fixed.
If there only was a way to hide the scrollbar of playlist switcher...
Very nice
are you never happy ? i'll see that later, maybe 1.2
Nah, Im very happy, thats just a tiny detail. The rest is more than perfect
indeed the revision solved the problem
another thing. are the extended variables different because the artist background isn't working anymore or is it coded that way? Not that I mind it but I just noticed it
That just looks amazing!
I have this same issue as well. There is nowhere for me to configure the PlayCount component either, although I do have the Playback Statistics Custom component config.
Also, I have removed each unnecessary component and left only the components included w/Kameleon and foobar.exe is still using 300+MB RAM and a good amount of CPU as well (anywhere from 8-30% or more during normal use!). When I first open foobar.exe I can watch the process in Task Manager build up RAM and it takes a good 10 seconds or so before I actually see the Foobar window open. As mentioned in my previous post, the first & second tracks played after opening Foobar will sometimes take over a minute before starting the audio and during this minute, foobar appears completely frozen/unusable.
I tried temporarily removing what I thought might be the more CPU/RAM intensive components such as dsp, comserver2, shpeck, & chronflow and CPU usage went down considerably (to about 1-5% instead of 5-25%) but RAM only went down from about 300MB to 235MB, so my only guess is that it is something wrong w/my config. I do have 90,000+ mp3's in my media library, but the only playlist that is active has only 100 or so MP3's in it.
Task Manager with all components active:(http://img179.imageshack.us/img179/5430/taskmgr.th.jpg) (http://img179.imageshack.us/my.php?image=taskmgr.jpg)
Active Components:(http://img3.imageshack.us/img3/2222/activecomponents.th.jpg) (http://img3.imageshack.us/my.php?image=activecomponents.jpg)
Any help with this as well as the PlayCount issue is much appreciated!
@Lonk NY: just read my answer, all is explained on my site now
library size --> RAM
There is nothing to configure on Playback Statistics (foo_playcount) except:
Preferences --> Advanced --> Tools
There's no need for something else
read the doc ! (do i loop ?)
-> force wallpaper panel option (hide on startup) to check
After an ATI driver update, I can no longer import fcl's. Is chronflow the problem? For the hell of it, I found a config on Deviant Art that doesn't use chronflow and it imported fine. Otherwise, an import with a chronflow requirement crashes foobar. I'm assuming chronflow is the issue.
So my question is: Is there any way to use your config without a chronflow import requirement?
just for you : http://br3tt.free.fr/html/K/index.htm (http://br3tt.free.fr/html/K/index.htm)
check line #3
Uhm is it intentional that the artist isn't displayed in the background by default? Now I have to click the alien cat every time I want the artists to show.
Otherwise it's a fine update
check line #3
Sweet! Thanks!
Edit: That did it. I'm back in business....thanks again.
up 5 posts!
If you look 3 posts above you...
http://www.hydrogenaudio.org/forums/index....st&p=617175 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=617175)
, maybe so far ...
(http://www.themomretreat.com/community/images/smilies/hyper.gif)
Last post on page syndrome.
Btw you will have this problem all the time since the changes/additions in the docs aren't highlighted. And nobody will bother reading the entire thing to find the few changes.
I just did a brand new foobar2000 install and got the full kameleon pack and imported the fcl and then noticed when I hover over a track that the popup is white box only. Am I missing some setting setup?
ELP Settings/misc/enable colour key/transparent
ok I did that and now when I hover over a track nothing shows....is that the idea? I thought the popup was supposed to show track info and stuff?
It shows comments
No comment = no pop-up
Add a comment and try it then
It shows comments
no comment does mean a pop-up
It shows comments
http://www.hydrogenaudio.org/forums/index....st&p=617198 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=617198)
The new versio is just awesome!!!!!!!!!!!!!!!!
thanks alot Br3tt!
thanks alot Br3tt!
you're welcome
not a doc addition Andu, all was discribed since the 1st release, but as i see, you'ven't read it the first time too
B/ Panel Stack Splitter settings (panels that can be shown/hidden on startup)
Default layout display the left panel with 3 mini panels (ART, LYR and SPE) + right panel (collapsed). For your convenience, you can choose which panels to show/hide on startup if these don't match your tastes
1. for the mini-panels in the Left Panel, Right click on the Left Panel header (ART PHO LYR ... SPE) and enter Splitter settings,
then for each panel beggining by "->", you can check or not the 'hide panel on startup' option (restart needed of course coz of startup options )
btw, when i make additions in the doc, i indicate it in the change log ! The next time i'll use highlight effects for you ...
1.1a :
- album list panel and playlist switcher panel moved to the left panel as mini-panels
- added QuickSearch toolbar always visible at the bottom of the left panel + Quicksearch buttons to look for same ... artist/album/title or genre
- added 2 buttons + and - to collapse/expand groups in the active playlist
- bug fix in Track info panel about db info doubled + some alignement fixes
- added a new button in the playlist header area to hide/show the top panel (Path + Google buttons + Last.FM radio button)
- added a grid dot background for the now playing panel (under scrolling texts)
- added Popups in ELPlaylist on Track mouseover if %comment% exists (display the comment in the popup)
- added Popups in the right Graphical Browsers (artist + album for Cover case mode, artist name for photo mode)
- dropdown menu entries are now transparent
- documentation updated below (popup transparency in ELP, statistics &rating : where to store them? ... ), check chapter D
- tweaks
NO COMMENT !
Edit: typo
1.1a :
- tweaks
SEX SEX SEX SEX SEX SEX SEX SEX
INCREDIBLE job, Br3tt!!! I am positively stoked .
Will begin testing now! So far so good!
1.1a :
- tweaks
NO COMMENT !
Edit: typo
Erm thx for not being patronizing
Have you actually checked chapter D? Because after reading the changelog (before downloading the new version)
I did. The force wallpaper thing is not mentioned in that chapter.
Just for the heck of it I tried to be fair and ran a string search on both the terms 'force' and 'wallpaper' in your docs too. Neither leads to a passage in the docs that could solve that issue.
But yea the problem is obviously with me
Edit: Oh wait I'm supposed to magically know that there is a new entry in the Panel Splitter Settings or that you've changed a value in there.
as said, there is NO new entry !! all was explain in the doc since the beginning, but i see that you don't want to understand... that's a shame ...
Oh I understand you perfectly well but you don't seem to understand me.
Once again.
1) The doc does not mention that there is an option to force a wallpaper.
2) The changelog does not mention that such an option was added or that a preexisting option was changed.
So unless you expect every user to know each option by heart and actually review every single panel on every update there is no way in hell anybody can know this. Especially not somebody that doesn't have the time to read every single post in this thread.
But like I said it's obvious that the fault lies with me.
Have you actually checked chapter D? Because after reading the changelog (before downloading the new version) I did. The force wallpaper thing is not mentioned in that chapter.
well, i guess string search doesn't search in the screenshots -> Force Wallpaper - tick/untick hide panel on startup? is this helpful?
Br3tt is working his ass off with pleasing people around and some here are acting like "whining little bitches" (damn, i've always wanted to say that )
99% problems here is already solved in docs, you just have to read and look carefully
Next addition to come (1.1b), a new button for a foo_run command 'Scaicha' to open the your personnal Scaicha page that give you stats about genre you are listening using last.fm scrobblerchart
(http://xs536.xs.to/xs536/09080/scaicha_button439.png)
for example, mine is : http://scaicha.helld.ru/index.py?name=Br3t...mp;color=random (http://scaicha.helld.ru/index.py?name=Br3tt33&ignore=&merge=&period=overall&color=random)
What do you think about it ?
Don't get me wrong, but I think it will be too much. Other buttons are really useful, but this.. not that much On the other side you can hide that panel so it won't do any harm if it's there
hi there .. where can I disable delay of popups in the right Graphical Browsers ?? 8-)
I already solved my problem. Thx for pointing out something that Br3tt already explained ages ago to me.
I was trying to be helpful and point out a flaw in the communication policy but nevermind that. Just forget everything I said and keep on doing things the way they are done now. Just don't wonder if you have to answer these type of questions all the time.
enter GB settings,(right click on it -> Settings) then check this
(http://xs536.xs.to/xs536/09080/gb_popup447.png.xs.jpg) (http://xs536.xs.to/xs536/09080/gb_popup447.png)
So I was using kameleon_rate_to_db=1 because I didn't want to change the "Date Modified" for my mp3's, but then I noticed that once I moved an album folder from one location to another, the ratings would get lost! So I gave in and changed the above setting back to "0" so that ratings get tagged in the file... however, now when I rate an mp3, the tags are lost, at least in the Vista Windows Explorer view as well as in the dbPowerAmp tab in file properties:
First 2 tracks were rated with default setting (in Tag, not database):
[a href="http://img12.imageshack.us/my.php?image=rating3.jpg" target="_blank"](http://img12.imageshack.us/img12/4453/rating3.th.jpg) (http://img10.imageshack.us/my.php?image=rating1.jpg)
Anyone know what the deal is with this?
and ... v1.1a released !!!
cheers
Thanks Br3tt!
Very nice update Falstaff, thanks, I specially like the new search box, still have the foo_input_mslive problem though, oh well ...
Actually, it's nice to have more buttons, put in your own png and make a foo run command you need. I for example have a youtube and wiki button there.
nice update!
However I have a problem. When i move cursor over left panel, it is constantly updating-reloading images, which results in annoying flickering. I made a small video to demonstrate - http://rapidshare.com/files/201479405/kameleon.avi (http://rapidshare.com/files/201479405/kameleon.avi)
it was present in previous version, but botton quick search buttons make it even more obvious.
an AWESOME config. 2 problems however:
1st: playlist is showing: song title AND artist (should be title only) 2nd - popup is showing ALWAYS:
(http://img262.imageshack.us/img262/2821/clipboard1.th.jpg) (http://img262.imageshack.us/my.php?image=clipboard1.jpg)
... just read the doc , D/ 6.
there's no info about how to change %title% - %artist% to %title%
ok i can live without popup (is showing even if i don't have any comment, i don't know what colour to choose in ELp) but (http://img243.imageshack.us/img243/2821/clipboard1.th.jpg) (http://img243.imageshack.us/my.php?image=clipboard1.jpg) there is an artist name and should not be. how to remove?
as explained in D/ 6. in the doc, you have to set the transparent colour to use to allow popup transparency
normally %artist% added after the %title is %album artist% tag filled and different from the %artist% tag, or if there is no group header en your ELP.
BUT, it seem to be a bug and now i always fdisplay %artist%
i'll fix that asap.
nice update!
it is a Panel Stack Splitter issue. all buttons flicker on mouse over on one of them, on fast PC (or good GC) it's very annoying, but in your case, it looks bad, i know, but i can't do anything for you. sorry
Great updates, thanks for the "static" search bar!
And my problem, that playcounter f***s the title info is solved, too. Thanks dude!
pop up problem solved: in foobar2000.exe right mouse click and in compatibility tab - choose 3X disable: themes, composition, dpi (just for 1 foobar restart/ later after colour choose untick all!!) .then go to ELp properties and choose D/6 that gray in custom colour: r/g/b 40/40/40 . for me it was working.
i'll fix that asap.
way too complicated.
Easier way is to disable hovering in the elp settings
nice update!
I was suspecting that
Anyway, great job, thank you again!
I have another problem - on dual display setup, when foobar is on the secondary monitor, the ELPlaylist popup does not show.
In order to show you must deselect "prevent going outside of display" in settings/misc.
Thought might help somebody else.
nice update!
(if got MOST recent drivers) maybe try to set 16x aniso and 6x antialias &wait for vertical refresh in nvidia/ati panel? i know it is windows, but if vista it could help i hope
thank you, but no Vista ever and I'm limited with priviledges to play with system settings.
hi falstaff,
all works fine, but one question please is it difficult for me to exchange wsh-panel (seekbar) to path-panel???
It is dangerous to click the taskbar: if you click off the mark: the track jump!
PIC (http://www.dj-atrac.de/frank_foobar.jpg)
thanks frank
i have an issue and can't solve it by myself (damn noob)
my playlist in 1.1 looks like that:
http://img100.imageshack.us/my.php?image=footrouble.jpg (http://img100.imageshack.us/my.php?image=footrouble.jpg)
any help?
Hi br3tt
first of all i wanna thank you so fucking much for this asskicking skin!
Im using it since the first release but i got one Problem with 1.1a
Why is it not as kameleonlike as the Version before?
I get always the Same background like u see on the Pic beneath
[link]
How do i get this feature back?
somebody has the problem that coverflow doesnt show up?
I fixed it with loading no coverflow version of coverflow and reloading the one with coverflow, and it works!
(Might also work with just re-importing the coverflow version)
Hi br3tt
[link]
Read the thread and documentation. Tick -> Force Wallpaper.
Hi br3tt
[link]
as said in the DOC !
then for each panel beggining by "->", you can check or not the 'hide panel on startup' option (restart needed of course coz of startup options biggrin.gif)
so, for -> Force wallpaper ... modify the 'hide on startup' option
EDIT: felimz replied just before me
Regarding this common question, you should spell it out in your doc. Write it in
bold red letters: "To toggle background artist art and static background, modify..." Hopefully that way people will stop asking that question.
Also, there's this typo in your doc that's been driving me crazy since release 1.0a:
kameleon_default_width : mumeric value, i.e.: 900
thx 4 ur help! now everithing is great!!!!
Regarding this common question, you should spell it out in your doc. Write it in bold red letters: "To toggle background artist art and static background, modify..." Hopefully that way people will stop asking that question.
done
hi falstaff,
thanks frank
hi falstaff,
thanks frank
I think what he means is that when he is tabbing into another app by clicking on the taskbar, sometimes he clicks on the foobar seekbar, and the track jumps to the spot he clicked. So, he wants to switch the file location bar at the top with the seekbar to avoid mistakenly clicking on the foobar seekbar when switching apps.
My suggestion? Alt+Tab on XP or Win+Tab if you are in vista to switch apps. Or, you can slightly reduce the foobar window size from its maximized position, which will put the seekbar slightly above its current position.
hi falstaff,
thanks frank
ok, i can switch the seekbar to the top, no problem (change $sub(%_height%,18) to 18), but how can i change the path info to the ground?
lg frank
i'll fix that asap.
Hey Br3tt, are you fixing this in the next release or are you able to upload a temporary .fcl in the meantime? Thanks
Outstanding config, Br3tt!!! Brought me back to CUI.
I have a question:
I have a keyboard shortcut for Alt+Enter to display Properties (context/playlist). When I press that key combination, the Properties dialog is displayed, BUT the selected item is played. I can't find anywhere that the behaviour is defined for the key combo; I don't want the selected item to be played.
Any ideas??
any help?
anyone please...
@dinog et Van.quish and others :
.fcl updated to fix elp issues (with and without chronflow) (but not the fcl in the full pack)
ok works fine for me!
thank you very much
I have a problem which I assume no one else does.
When I start foobar - it defaults to shuffle playback even tho I've gone into settings and set "Playback Order Shuffle" to "hide panel on startup". If I click thru the modes via the playback buttons at the bottom, when it get's back to "default" order it plays fine in order. As you can imagine this is a pain to do every single time I start foobar now.
Anyone any ideas?
This works in reverse too if you select shuffle and hide default it still uses default until you reselect shuffle.
I'm having this problem too. I'd like it to start on shuffle, and even with the proper things hidden, it still starts on default. Any ideas?
Edit: Just fixed it, I should've read up a bit. I just reversed my settings and now it's doing what I want it to, but the default order button shows on startup instead of the random button, which is only minor.
I apologize if this issue has been answered already, I have searched this thread, but have not found my answer. When my artist art is used as my wallpaper, it is massively oversizing it, meaning I only see a small portion of the image. please help. Examples below:
(http://img11.imageshack.us/img11/9260/foon.th.jpg) (http://img11.imageshack.us/my.php?image=foon.jpg)
and the actual image:
(http://img214.imageshack.us/img214/3307/pinkfloyd.th.jpg) (http://img214.imageshack.us/my.php?image=pinkfloyd.jpg)
Thanks in advance.
Not sure what you mean by "reversed my settings". I would like to resolve this, too. Would you mind explaining your fix?
[a href="http://img11.imageshack.us/my.php?image=foon.jpg" target="_blank"]
Thanks in advance.
What Br3tt means is you need the correct aspect ratio. I also use widescreen with a native res of 1920x1200. That means any res (example: 2560x1600, 1920x1200, 1600x1200, 1280x1024, 800x600, etc...) at that aspect ratio will display your background correctly.
[a href=\"http://img11.imageshack.us/my.php?image=foon.jpg\" target=\"_blank\"]
So there is no way to have it simply display the picture with it fitting into the space available? it will always stretch it out to fit only the width? why? that doesn't really make sense to me.
Is there any way to code it so that it will fit to which ever is larger the height or width? that way if a picture is in portrait instead of landscape, it will fit top to bottom and you will be left with black on the sides (which I am totally ok with). Any tips for me to alter it myself would be appreciated.
In another config I use sometimes, I see this line:
$imageabs(0,0,%_width%,%_height%,$get(artist.pic),noexpansion)
would that help?
Thanks again, and kudos on the beautiful config.
so, i see you don't understand how it works in my config, so i'll try to do a quick explain to make you understand this.
first, i've decided to not display empty area when the bg pic doesn't fit the whole window, like this :
(http://xs536.xs.to/xs536/09094/ratio_fitted128.png)
- to do without empty area, 2 possibilities :
1) displaying the bg pic to take the whole place without keeping the aspect ratio (nokeepaspect option of $imageabs(...)), but it is really ugly to stretch images :
(http://xs536.xs.to/xs536/09094/stretched775.png)
2) displaying the bg pic but keeping the aspect ration of the pic ! it's what i have done, but in order to respect my first need (no empty area) i center the pic and i zoom it (in or out) to fill the whole space in the window !
(http://xs536.xs.to/xs536/09094/ratio_ok_fit_ok743.png)
if i don't do this, in the example you gave, a 'portrait' format image like your (ratio near 3:4) to be displayed in a 'landscape' format window (ratio near 4:3), you'll add empty area at the left and at the right of the picture, it is really not sexy for my point of view.
is it more clear now ?
Now, if you want to display pics in another way, i'll not help you, take your titleformat's manual and code it by yourself. Sorry... choices had to be made, i made them.
Regards,
Well, I had "playback order default" panel hidden on startup, and "playback order shuffle" panel not hidden. When I did this, foobar would load and show the shuffle symbol in the bottom button, yet tracks would play in default order.
What I simply did was show the "playback order default" panel, and hide the "playback order shuffle" panel. This way when foobar would load, my tracks would play in shuffle order, but there is still the problem of the wrong button showing at the bottom (the default order button).
So, I consider my problem mostly solved. My tracks now shuffle on load, but the wrong button image shows. I'm not sure if this is an error with Kameleon, perhaps Brett can attest to that?
Hope this helps.
would that help?
kenboldt, I was having a sorta similar issue with album art and artist photos. From earlier configs of Brett's I had been keeping my artist images as squares, since those earlier configs showed the artist pics in a 1:1 ratio. Since Kameleon those artist images are now in 4:3 it seems, so what I needed to do was remove the "nokeepaspectratio" tags from some of the lines of the code,
which I have no problem with doing I also had to fix the way album art was displayed, since not all my album covers are square (example, Japanese singles from the 90s came on small 8cm CDs in long cases, which made for a long album art, more in a 1:3 aspect ratio). So in most cases, it's just the case of removing the "nokeepaspectratio" and replacing it with "keepaspectratio".
I hope this helps you with the issue of artist images being stretched to fit the wallpaper in Kameleon. Alternatively, you could just force the wallpaper, as I do.
Hmm, strange. My set-up behaves a bit different regarding playback order. It always starts with the order I used the last time. Even when I use Shuffle (albums) or something else which is not present in Kameleon's button-options and re-start foobar, the order will stay the same until I manually change it. I have tried several combinations of hiding shuffle/default panels but that doesn't influence it in any way.
it's normal, CUI or PSS don't offer permanent global variable to allow skinners to save the playback order, so, when you restart foobar, Kameleon has no idea of what is the last playback order used (the active one coz foobar remains it him!)
so, Kameleon always starts with the same playback order button, and can be different from the real active one ... no other way possible, that's a shame, i know.
well, first of all, hi there folks!!
now, i have newbie problem, lol....few days ago, i upgraded my foo to kameleon 1.1, and everything looks and works perfectly, cpu usage (single core!!) is not higher than 3-5%, however, there are two little things that bothering me. first, google cover search button is not responding, even tho i c/p the command line as stated in the ''manual'' and another, which plug-in is proper for audioscrobbler, i put ''foo_audioscrobbler.dll'' in the components folder, but nothing's changed on my last.fm profile, regardless of correct user & pass i entered in the tools->audioscrobbler section. wrong plug-in or i did something else wrong? thanks and greetings from croatia !!
EDIT: foo version is 0.9.6 beta4
@Falstaff
He he, i made it with Tabbed Panel Stack mod and integrated PSS's for the panel order buttons (and indicators), since other than PSS the tabbed panel stack mod remembers the last tab before shutdown and isn't forced to hide a specified panel at startup
@Falstaff
ohohoo good i have to give it a try !! thanx
It has some disadvantages still:
if you load or reload the fcl, the panel order that the fcl is saved with is indicated, no matter what playback order is actual running.
And you should avoid using other methods to switch the playback order (menu, shortcuts etc.) of course.
But this can be easily solved by a click on the button.
And then: the tabs are flickering on switching...
(But maybe caused by the panel stack splitter)
EDIT:
Oh, and you need T.P. Wangs modification of foo_uie_tabs (to work on vista)
http://theo.foobar2000.com.cn/projects/fb2k-0_9_6-ports/ (http://theo.foobar2000.com.cn/projects/fb2k-0_9_6-ports/)
Hope this helps.
Thank you, Takaji!!
I'm on 0.9.4 and Vista and foobar won't start now. An initial process shows up at about 7,000 kb and subsequent attempts at opening foobar yield processes of about 1/10th that size. Any ideas? I had just installed kameleon and was running it to see the changes.
Hi there, first of all, thanks a lot Falstaff for your hard work, this is an excellent configuration.
My Album Art (folder.jpg) is displaying correctly for most of my albums except when it comes to multi-disc albums because i put each disc on separate folders, something like this:
%artist%\%date% - %album%\Disc %discnumber%\
How can I display the Album Art for those multi-disc albums without having to put the same picture (folder.jpg) in each "Disc N" folder?
Thanks in advance.
Regards,
Not sure if you intended it to be this way, but that post came across incredibly rude. Not sure why I deserved that. Anyway, back on topic, I do fully understand how it is working in your config, and I respect that it is your config, and you can have it look how you want. I was looking for some advice as to where I could tinker with things to get it to look how I would like it. I don't know much about titleformat code, but I do understand the basics, and the theory of programming in general, and I was hoping that you might be able to point me in the direction of the lines of code I might be able to play with to see if I can get it looking how I would like. If you really don't want to help, that's fine, you aren't required to, but I would appreciate it if you could just point me in the right direction.
I have a question:
Any ideas??
Anyone know why Alt+Enter would
Play the selected item? Is this an ELPlaylist thing?
I just discovered the button in Kameleon to display the properties dialog, but I am used to using the keyboard short-cut.
When I start search an album, playlist show:
I have a question:
Any ideas??
Anyone know why Alt+Enter would Play the selected item? Is this an ELPlaylist thing?
As soon as I started using Brett's configs I noticed this happening too. I'd like to know why alt+enter doesn't bring up the properties dialogue anymore, either
Regards,
first, my intentions were not to be 'rude', so excuse me if you had take it like this.
now, to change the display of bg images, i said that i'll help you because it's a mod of the config, and i don't want to modify it for the reason explained in previous posts. Now if you want mod it, you can, no problem, but if you're not able to find the lines to change, i'm afraid that you'll be alble to do it by yourself ... but i hope i'm wrong, and i just can tell you that you need to enter splitter settings (right-click on 'Kameleon' icon button at bottom, -> enter splitter settings, go to the tab that contains the script 'Per Track', and look for the blocs that calculate ratio and then display the images depending on the ration format (3 blocs, there are comments in the code).
here are the piece of code to modify...
Thanks for the tip, I appreciate it. I do love tinkering with things, so this should be fun.
thanks for this nice config. I have one problem with it though. Whenever i click on the bottom letters to jump to the artist with name that start with that letter nothing happens. the screen just stays the same place. any ideas?
Read back in the thread, it's been covered
OK, never mind, right click the letters/settings/others/click actions/set single click to default
appreciate it. thanks
Nice config, but there is an issue.
When using the Album List Panel, i frequently start typing the item I want to select that item. Then i want to use my keyboard to add it to the playlist, using SHIFT+ENTER as it says in the context menu.
However nothing happens. Non of the shortkeys mentioned in the context menu work. They did work when using the deafult layout, so something must have changed when installing Kameleon.
This also happened with the other two configs of your making.
Is there a setting I'm missing or is it just a bug/missing feature. If it's the latter could you take a look at it and implement it?
It is strange, but then I installed foobar 0.9.6.3 something happens with chronflow
There are not any actions on mouse click, only scrolling through covers works.
Is it chronflow problem ? or config ?
I use Vista.
Anybody who knows how i can make the arrow buttons work with graphical browser and coverflow?
Where're nocover & loading pics
Can someone help me with the above issue? Any info is much appreciated, thx!
Also, for some reason, shpeck is now displaying in its own window, rather than in the VIS panel. How can I force shpeck to display in the VIS panel? Right now it is blank/black:
(http://img220.imageshack.us/img220/12/shpeck1.th.jpg) (http://img220.imageshack.us/my.php?image=shpeck1.jpg)
@ Shpeck issue: make sure to tick "Integrate with winamp skin" in the Milkdrop configuration menu (found in the Foobar preferences under Visualisations >> Shpeck).
Thanks but this box was already checked. I tried unchecking it and Foobar froze on me. Any other possibilities?
I think there is something to correct in your epl playlist code about the autorating, you use %play_counter% that works only if you have play_counter tags instead of $get(play_counter) that will work for play_count and play_counter tags
I use play_count and i had to replace the line
by
$if($get(play_counter),$puts(rating,$div($get(play_counter),$get(autorate.add))),$puts(rating,0))
to have the stars display correctly.
merci pour le bug je corrigerai cela rapidement.
by
Thanks - but I don't see this code anywhere. What I was editing originally to change the Rating from tag to database was this code in the Rating splitter:
$if(%_isplaying%,
$ifequal($get(rating),1,
$button($get(rate.x),$get(rate.y),0,0,12,12,$get(img)'/rating/set'$get(no.set)'/r'$get(rating)'.png',$get(img)'/rating/set'$get(no.set)'/r1x.png',$ifequal(%kameleon_rate_to_db%,1,0,TAG:SET:rating:0),TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,0,12,12,$get(img)'/rating/set'$get(no.set)'/r'$get(rating)'.png',$get(img)'/rating/set'$get(no.set)'/r1.png',$ifequal(%kameleon_rate_to_db%,1,1,TAG:SET:rating:1),TOOLTIP:"Average")
$ifequal($get(rating),2,
$button($get(rate.x),$get(rate.y),12,0,12,12,$get(img)'/rating/set'$get(no.set)'/r'$get(rating)'.png',$get(img)'/rating/set'$get(no.set)'/r2x.png',$ifequal(%kameleon_rate_to_db%,1,0,TAG:SET:rating:0),TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),12,0,12,12,$get(img)'/rating/set'$get(no.set)'/r'$get(rating)'.png',$get(img)'/rating/set'$get(no.set)'/r2.png',$ifequal(%kameleon_rate_to_db%,1,2,TAG:SET:rating:2),TOOLTIP:"Good")
$ifequal($get(rating),3,
$button($get(rate.x),$get(rate.y),24,0,12,12,$get(img)'/rating/set'$get(no.set)'/r'$get(rating)'.png',$get(img)'/rating/set'$get(no.set)'/r3x.png',$ifequal(%kameleon_rate_to_db%,1,0,TAG:SET:rating:0),TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),24,0,12,12,$get(img)'/rating/set'$get(no.set)'/r'$get(rating)'.png',$get(img)'/rating/set'$get(no.set)'/r3.png',$ifequal(%kameleon_rate_to_db%,1,3,TAG:SET:rating:3),TOOLTIP:"Very Good")
$ifequal($get(rating),4,
$button($get(rate.x),$get(rate.y),36,0,12,12,$get(img)'/rating/set'$get(no.set)'/r'$get(rating)'.png',$get(img)'/rating/set'$get(no.set)'/r4x.png',$ifequal(%kameleon_rate_to_db%,1,0,TAG:SET:rating:0),TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),36,0,12,12,$get(img)'/rating/set'$get(no.set)'/r'$get(rating)'.png',$get(img)'/rating/set'$get(no.set)'/r4.png',$ifequal(%kameleon_rate_to_db%,1,4,TAG:SET:rating:4),TOOLTIP:"Excellent")
$ifequal($get(rating),5,
$button($get(rate.x),$get(rate.y),48,0,12,12,$get(img)'/rating/set'$get(no.set)'/r'$get(rating)'.png',$get(img)'/rating/set'$get(no.set)'/r5x.png',$ifequal(%kameleon_rate_to_db%,1,0,TAG:SET:rating:0),TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),48,0,12,12,$get(img)'/rating/set'$get(no.set)'/r'$get(rating)'.png',$get(img)'/rating/set'$get(no.set)'/r5.png',$ifequal(%kameleon_rate_to_db%,1,5,TAG:SET:rating:5),TOOLTIP:"MegaHit")
I have it set just as above now but when I rate a track I lose all tags when viewing in Windows Explorer, dbPowerAmp, etc. Foobar seems to read them OK though... Another thing is that I have foo_playcount.dll loaded but no config for it in Foobar Preferences:
(http://img27.imageshack.us/img27/8461/playcount.th.jpg) (http://img27.imageshack.us/my.php?image=playcount.jpg)
Also, if anyone can help me with the shpeck issue, that would be great too! This config was working so well until recently - not sure what went wrong.
foodunit moved topic to "not my release elplaylist"
You are still writing Ratings to tag and foobar writes tags with ID3v2.4/UTF-8 and win explorer can't read this (I'm not sur if 2.4 or UTF-8 is the problem).
Go to Preferences-->Advanced-->Tagging/Mp3-->check ID3v2 compatibility Mode
Or install AudioShell Extension (AudioShell (http://www.softpointer.com/AudioShell.htm)) - it can read UTF-8 and prepares additional columns for win explorer.
Cause there are no preferences.
The only thing you can do is to check/uncheck writing database entries to tags in Preferences-->Advanced-->Tools-->Playback Statistics
Anyone?
Maybe you should have a look at Curacao and it's code. There are such buttons.
Anyone?
Eerr..sorry, i don't mean buttons, i mean cursor keys on keyboard...how can i browse coverflow and graphical browser with them?
The command in Curacao for GB-Button is COMMAND:'Edit/Jump/Previous/by album' (Previous/Next, by album/artist)
Maybe you can use this for a shortcut.
I apologize if this is obvious. I have a question about play count. I understand that there are two options, one writing to the tags, and one to the database. Is there any way when writing to the database for it to reflect in the little number by the song name and the stat panel? Or is that just tags. Where are the database statistics shown? Thanks.
I'm talking about the official Playback Statistics now, I don't know anything about PBS Custom.
The database ratings are shown in the properties tab of the properties panel in the Playback Statistics section. But they are also shown there, if you are rating in tags.
To show ratings there are two different ways of it.
Via the metadata %rating% - relating to Database and Tags, or via meta(%rating%) - relating only to the tag Rating.
And with the metadata %rating% there are some problems with confusing double-ratings, if you have two different rating values in database and tags. The Rating is not shown properly, it's a mix of both them.
So you can request the Rating by asking for meta(%rating%) and then for %rating%
I hope I talked in a clear way, if not, ask again.
Well, I got same problem as I got in first version of FooKameleon. My artist art won't show up, although my address is correct. Last time I had this problem I fix it by reinstalling whole foobar and kameleon. I did this time twice, but no go. I know you're tired of answering questions like this, but check out this picture and you'll se no one had this problem before:
http://img26.imageshack.us/img26/6972/blahf.jpg (http://img26.imageshack.us/img26/6972/blahf.jpg)
In artist panel, there's pictures of artists,in exvar is correct adress and folder does contain valid pictures. What's the problem?
In previous version, if there's no artist art, fookameleon would load cover art instead of artist art, but now it's just baroque wallpaper. Is something changed since last version (in visual meaning of background) except default wallpaper and how can I change it to be as it used to be before?
Also, how can I change default text for track name ( http://img49.imageshack.us/img49/812/sdas.jpg (http://img49.imageshack.us/img49/812/sdas.jpg) ) to show in Calibri or in some other font? Thanks so much
Anyway, big props on new realease of Kameleon, it's awesome and probably best skin ever released for Foo Peace
Maybe a silly answer, but check you slash directions.
terry
terry
=( Nah, I tried that already, but still nothing.
Anyway, thank you for your help
Thanks for the reply. Here's my issue. I would like to have the number of times played reflected in the little number by the song title and the statistics panel on the left side without writing to the tags. This may be impossible.
On Falstaff's site, he gives 2 options for playback statistics, one using the official(written to database) and one using the custom (written to tags).
Under Preferences>tools there should be a play counter settings page, but on mine I don't have it (using 0.9.6.3). Under Preferences>tools>Playback Statistics Custom>database dropdown, if i select only foo_custominfo database, the playback numbers are not updated. My question is where that foo_custominfo database is located and shown (I realize you're responding about the offical playback statistics). Again, I apologize if what I'm asking is obviously impossible or that I'm misunderstanding something.
answer already given : 1. in the doc, 2. post #329 http://www.hydrogenaudio.org/forums/index....st&p=617667 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=617667)
i want to let the pl and al list panel aways max size when i click on them.
is there a way to do this?
and thanks for this great config.
you are amazing!
sorry for the bad english.
you are amazing!
Yes, it's possible and it was one of the first things I tweaked for my personal use
Right-click on PL-button, then go to splitter-settings, script.
Search for this part:
$if($isvisible_c(-> AL),
$if($isvisible_c(-> Max),
You have to change the single next row to:
$imagebutton($add($get(lpf.x),5),$add($get(lpf.y),7),15,21,$get(z)'/bt/AL_up0.png',$get(z)'/bt/AL_up0.png',PANELSHOW:-> Max:0;$if($isvisible_c(-> AL),PANELSHOW:P8:0;PANELSHOW:-> AL:0,PANELSHOW:P8:1;PANELSHOW:-> AL:1);$if($isvisible_c(-> ART),PANELSHOW:P1:1,PANELSHOW:P1:0);PANELSHOW:-> ART:0;$if($isvisible_c(-> PHO),PANELSHOW:P7:1,PANELSHOW:P7:0);PANELSHOW:-> PHO:0;$if($isvisible_c(-> LYR),PANELSHOW:P2:1,PANELSHOW:P2:0);PANELSHOW:-> LYR:0;$if($isvisible_c(-> INF),PANELSHOW:P3:1,PANELSHOW:P3:0);PANELSHOW:-> INF:0;$if($isvisible_c(-> VIS),PANELSHOW:P4:1,PANELSHOW:P4:0);PANELSHOW:-> VIS:0;$if($isvisible_c(-> STA),PANELSHOW:P5:1,PANELSHOW:P5:0);PANELSHOW:-> STA:0;$if($isvisible_c(-> SPE),PANELSHOW:P6:1,PANELSHOW:P6:0);PANELSHOW:-> SPE:0;$if($isvisible_c(-> PL),PANELSHOW:P9:1,PANELSHOW:P9:0);PANELSHOW:-> PL:0;REFRESH,,)
Then search for the row after
,$if($isvisible_c(-> Max),
and replace it with
$imagebutton($sub($get(lpanel.w),14),$add($get(lpf.y),7),15,21,$get(z)'/bt/PL_up0.png',$get(z)'/bt/PL_up0.png',PANELSHOW:-> Max:0;$if($isvisible_c(-> PL),PANELSHOW:P9:0;PANELSHOW:-> AL:0,PANELSHOW:P9:1;PANELSHOW:-> PL:1);$if($isvisible_c(-> ART),PANELSHOW:P1:1,PANELSHOW:P1:0);PANELSHOW:-> ART:0;$if($isvisible_c(-> PHO),PANELSHOW:P7:1,PANELSHOW:P7:0);PANELSHOW:-> PHO:0;$if($isvisible_c(-> LYR),PANELSHOW:P2:1,PANELSHOW:P2:0);PANELSHOW:-> LYR:0;$if($isvisible_c(-> INF),PANELSHOW:P3:1,PANELSHOW:P3:0);PANELSHOW:-> INF:0;$if($isvisible_c(-> VIS),PANELSHOW:P4:1,PANELSHOW:P4:0);PANELSHOW:-> VIS:0;$if($isvisible_c(-> STA),PANELSHOW:P5:1,PANELSHOW:P5:0);PANELSHOW:-> STA:0;$if($isvisible_c(-> SPE),PANELSHOW:P6:1,PANELSHOW:P6:0);PANELSHOW:-> SPE:0;$if($isvisible_c(-> AL),PANELSHOW:P8:1,PANELSHOW:P8:0);PANELSHOW:-> AL:0;REFRESH,,)
Good luck!
Ok, now I understand what you want.
It looks like an addtitional 3d Party Plugin, like foo_playcount (unofficial)
Ok, you need to have foo_custominfo to be installed to get the database.
http://wiki.hydrogenaudio.org/index.php?ti...m)#Introduction (http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Components_0.9/Playback_Statistics_Custom_(foo_playback_custom)#Introduction)
you are amazing!
and replace it with
Good luck!
thanks
I'm sure it's been mentioned before, but is there anyway I could use if statements in the extended variables. That is, define a variable outside of it and then call it with extended variables? For the album art, I want it to first scan for folder.jpg -> cover.jpg and if not, *.jpg
Hello, Br3tt!
Thank you for your assembly. This is a very great work!
I ask for help, please with a problem in assembling Kameleon 1.1a:
(http://img164.imageshack.us/img164/4395/kameleon.th.jpg) (http://img164.imageshack.us/my.php?image=kameleon.jpg)
1. Any font on the panel Chronflow looks crooked. Any!
2. In the WSH Panel has no indication of numbers. Is only visible to the slider.
My operational system Windows XP SP3.
P.S. Sorry for my English. :-)
Did you install all the fonts?
Yes, of course. everything is done according to the instructions
1. for the Chronflow problem, it is a chronflow issue, try to download the last available drivers for your graphic card, that might fix it... if not, try a post in the chronflow topic, thanx.
2. for your WSH display pb, it is because you haven't installed the font saxmono, maybe i've forgot it in my package ... you can easily find it on dafont.com
or change the line :
var g_font = gdi.Font(-9, weight_normal, italic_no, uline_no, "saxmono");
by replacing saxmono by another font ...
Thanks in advance.
I still need help with this.
I don't use Kameleon, but I think it's similar to Curacao. You have to rewrite some code in ELP and PSS to go up the dir if there's no folder.jpg in the music folder.
So I would say you copy the pictures.
Edit: When will the final come, Br3tt? I'm waiting impatiently.
Thank you very much. Try it!
I have a small question. I noticed that with Kameleon the left panels like the lyrics panel, spectrum panel, albumart panel,....the transparency is different then that of the playlist. This is especially noticeable when using dark backgrounds. In curacao it was the same transparency for everything. Is there a way to make the transparency of the left panels match that of the playlist or vice versa.
Note I'm still on Kameleon 1.0 so I don't know if that changed with 1.1, I'm waiting for the final so I can mod that to my liking.
Is it possible to play an album when I double click the album in the ELP panel?
ELP right click > settings > behaviour > click action / group
Firstly, i greatly thank Br3tt for making such awesome skin but i'm having some problems here. well, sorry for my bad english skills but i want to know how i can remove this "diagonal cross" from my wallpaper (somehow i see it looks quite bad in it )
ex:
(http://i292.photobucket.com/albums/mm39/Bernkastel07/Sample1.jpg)
Become like this
(http://i292.photobucket.com/albums/mm39/Bernkastel07/Sample2.jpg)
edit: now i've got a new problem ...
I already put all the tracks i need into a folder but the foobar doesn't accept it as a group but many "albums" as you can see. I tried many "sort..." ways but it has still divided the tracks into many "albums" and it's really hard to see, though there's still some albums my tracks are placed in a group. As you can see below:
=> Can anyone help me to solve these problems? ^^''
In your first picture there's a "?" at the artist line, so you have to tag the files with an artist.
I also think there's no album tag.
um, really thank for your advice but... is there a way to put them in one artist/artist at once? Because it's quite hard to tag every files one by one and there're tons of them i need to do the same...
I did no batch tagging with foobar so far.
Are the filenames with artists?
Then select all > Properties > Automatically Fill Values /Source=File Names/ Pattern
eg. 01 - Britney Spears - I love you so > Pattern: %tracknumber% - %artist% - %title%
If filenames don't include artist you have to do this manually via freedb- or discogs-tagger or via Prperties Panel and typing the artist, afaik.
Foobar works best when all your music is properly tagged, artist and album tags are the bare minimum. You don't need to tag them one by one, just select all the songs from the same album at once and assign it an artist and album tag. Do that for all your music and it will look the way you want.
Thanks everyone every much!!
Well, after doing as you guys told but now i'm facing a final problem here '' That is there's some albums but has a variety of artists (ex: a vocal collections album)=> the result is it devided into many albums but with the same image the problem i want to solve is how to group them in same path folder so that they can still be an album but with many different artists (like the "folder structure" way in the library).
I'm terribly sorry that i have too much troubles, I also tried by google but it's hopeless (maybe because of my stupid key words).
It's greet skin!!!!!
Thanks Br3tt!!!!
Album Artist > Various Artist or eg DJ Bumba's Top 100 > Album Artist > DJ Bumba
You need some foobar basics - read the foobar wiki
THNKS!! you guys really helped me a lot
Would it be possible to change the date display code to the following code in the Group Header of ELPlaylist?
$put(%_DATE_%,$left(%date%,4))
$ifequal($len($get(%_DATE_%)),4,
$puts(nb1,$left($get(%_DATE_%),1))
$puts(nb2,$left($right($get(%_DATE_%),3),1))
$puts(nb3,$left($right($get(%_DATE_%),2),1))
$puts(nb4,$right($get(%_DATE_%),1))
Reason I ask is I have my date in the format YYYY-MM-DD
The original code doesn't take this format into account.
is it possible to collapse groups like this
+Artist
+Album
+disc1
songs
+disc2
songs
Everywhere where you have %_DATE_%, replace it by $year(%_DATE_%)
Hope that helps
I updated to the latest beta version of foobar (0.9.6.4 I think?) and my images no longer load with the Kameleon skin. Ideas, anyone?
Edit: Weird, after checking settings for a bit, the layout suddenly "changed," and all the Kameleon images loaded. Not sure what happened, but it's fixed.
Great UI. Thank you so very much for this one!!!!
That said, what is the correct dimension/aspect ratio for artist pics and album covers? I was trying 500x390 for Artist but, its getting distorted. Anyone has a good suggestion about correct aspect ratio.
Thanks again
Thanks again
You are better off having all album art EXACTLY square (download as close as you can get then resize in PS or similar), I normally use 500x500 or 700x700, then they work perfectly in Chronflow and the CD Cases in Kameleon. Artist pics are the exact opposite, you really need them similar to your screen resolution, I tend to download artist wallpaper from fan sites which works perfectly, 1024x768 or similar ratio. I also put Artist.jpg in every single album folder which enables me to have a different artist background pic for each album if I choose, or just duplicate the same Artist.jpg into each folder
Thanks again
not possible, Kameleon doesn't distord pics ! it crops them if their ratio is different from the main window ratio, crop but keep them centered !
HTH
Thanks again
HTH
You are right. Refresh issue prolly. When I change the artist and come back to the newly updated artist again, the picture shows correct aspect ratio. I wonder how to use the cover art or different art in the background instead of default artist pci from the specified folder. Please let me know. I am clickinhg the foobar mask and getting the regular artist pic. It would be nice if I could get the coverart as BG or another pic. I understand the wallpaper option. Thanks.
i'll fix that asap.
I've been scouring this thread hopefully looking for someone who didn't like this as well. I find it a tad bit annoying. Don't really need to see the %artist% after %title% unless it's various artists. Has anyone edited that out themselves, and if so, where?
Love the theme btw Falstaff
See my post below, the code I posted messed up the board formatting so I attached the elp file.
The code I posted before showed the artist when the track was playing.
Download this and import it to fix everything.
http://rapidshare.com/files/209523832/kameleon.elp (http://rapidshare.com/files/209523832/kameleon.elp)
single .fcl file on my site already fix this bug, ... it's only the .fcl in the main archive which has this issue (sorry too lazy to repack it)
next build will be clean (v1.2) release soon.
Kameleon v1.2.0 released, check http://br3tt.online.fr (http://br3tt.online.fr) for files and change log ...
bye
Thanks for the update Br3tt!!!
Thanks Br3tt, I can't get enough of this config.
I have a quick question about playback statistics custom. Is there a way to prevent foobar from jumping to the front when it registers a playcount? For example, I have it set so that at 50% pb statistics custom writes a playcount, but when that happens, foobar moves to the front of the windows i have open (I can't tell if it does it all the time). Thanks for any help.
Ben
I've just did a fresh install of v1.2.0 on a fresh install of foobar.
When going through the component settings on your site I noticed that you say to disable stat writing on the official playback statistics plugin.
Problem is I don't have the official playback statistics showing up in my foobar preferences.
Any idea why that would be happening?
Also I noticed a few changes/bugs/regressions that I just wanted to point out.
1. The album art shows up in the background after every restart, I need to manually click on the icon to change after every restart.
2. The album list and playlist switcher are now the full size of the side panel? Is this by design?
Plus I have a request, would it be possible to add a button at the bottom next to the controls that controls the stop after playback function?
I disabled my original playback statistics plugin by:
View (on kameleon) > toogle toolbars (in case it's hidden) > Library (on foobar toolbar) > Playback statistics > Monitor playing tracks (uncheck).
Great skin. Been using it since 1.0
Oh, and just a suggestion / question. Is it possible that the wallpaper would only change if artist art is present (e.g. it won't change to album art). My album art isn't high resolution, therefore the background is terrible pixelated. Plus, my player ratio is set to 4:3 (also appropriate for artist art); album art gets clipped.
Just a quick question, can it be configured so that when I click any of the menus (File, Edit, etc.) the menu collapses totally when I open something from it or click somewhere else?
As it stands the menus stay expanded until I click the title for the menu currently expanded (So if I click "File", the file menu stays open until I click "File" again).
kameleon_hide_scrollbar_AL_and_PL = 1
and i got this problem
1 (http://s566.photobucket.com/albums/ss109/klxy/?action=view¤t=771x5.jpg)
i'm happy to see that al and pl updates
great config!
thank you
sorry for my bad english.
a good no cover pic
2 (http://s566.photobucket.com/albums/ss109/klxy/?action=view¤t=FB6.jpg)
That's already been asked. AFAIK there is no way of doing that.
[quote name='runrunaway' date='Mar 16 2009, 11:58' post='621614']
it's the reason that i've just put this as an option !
set it to 0 and be happy
Great changes Thx very much.
What I noticed: When I click or move the mouse over the playback order button, it turns almost black and stays that way. In this case, it's very hard to recognize the different modes.
@exxecutor
Have you installed the latest Panel Stack Splitter 0.3.6.3a?
In previous versions there was a bug with mousover images.
Hehe, i knew it was something simple Thx!
Question for Falstaff -- Is there a way to cycle the Artist Pic & Album pic the way you cycle the wallpapers when cycle flag is set? As I have already chosen the path for artist folder, the background wallpaper defaults to that Artist pic if I click the mask. It did not pick a different Artist pic when I put it in that particular album folder. But, if we can cycle the pics like artist1.jpg, artist2.jpg artist3.jpg etc. it will be fun.
I have question not really concerning the new 1.2 release. On the info panel in the track info section the comment part only is able to display one line, which is barely enough for one sentence. Since I have abundant vertical space I'd like to have that comment to be able to show x amount of lines so it would be able to show a small biography of the artist. I tried for hours to find a solution but can't seem to find a way. Can anyone help please?
First of all, congrats on new release FooKameleon gets better and better with every new realease.
This is side question, I was looking at some Q's and I saw this picture ( http://s566.photobucket.com/albums/ss109/k...rrent=771x5.jpg (http://s566.photobucket.com/albums/ss109/klxy/?action=view¤t=771x5.jpg) ) my question is : how can I get playlist time statistic and black searchbar? Also, it would be great when alphabetic listing would be more practic : when I make one click on random letter, FooKameleon would jump to the first alphabetic ordered artist of chosen letter (but not play it, which is more practical when you have big library, because when you're making queue playlist and double click on letter, it mess up whole your queue playlist) Thanks
About the alphabetic listing, you can change it to the way u want by:
+) Right click on 1 of the letters, choose settings
+) Select the tab Others
+) Change Single click from None to Default
Is it possible to filter the playlists so that kameleon_elp_header_height is 0 for one playlist but 3 for another?
thank you so much. it's way more practical this way
Hello
First of all, thanks Br3tt for this layout which seems great.
However, I have a display problem on the now playing panel :
(http://img150.imageshack.us/img150/8291/scrnl.th.jpg) (http://img150.imageshack.us/my.php?image=scrnl.jpg)
Do you know where it could come from ?
Skeksis, like some before you, and already discussed in this thread, you did not install all the necessary fonts.
Well I managed to get all working but Chronflow. I simply don't get what to do in step D.2.3
$ifgreater($strstr($lower($if2(%kameleon_coverart_path%,'default')),'default'),0,$replace(%path%,%filename_ext%,)$replace($if(%kameleon_coverart_filename%,$lower(%kameleon_coverart_filename%),'folder.jpg'),'%band%',%band%,'%performer%',%performer%,'%discogs_artist_id%',%discogs_artist_id%,'%path%',%path%,'%directoryname%',%directoryname%,'%filename_ext%',%filename_ext%,'%filename%',%filename%,'%album artist%',%album artist%,'%artist%',%artist%,'%album%',%album%,'.*','.jpg'),$if($stricmp($right(%kameleon_coverart_path%,1),'/'),%kameleon_coverart_path%,%kameleon_coverart_path%'/')$replace($if(%kameleon_coverart_filename%,$lower(%kameleon_coverart_filename%),'folder.jpg'),'%band%',%band%,'%performer%',%performer%,'%discogs_artist_id%',%discogs_artist_id%,'%path%',%path%,'%directoryname%',%directoryname%,'%filename_ext%',%filename_ext%,'%filename%',%filename%,'%album artist%',%album artist%,'%artist%',%artist%,'%album%',%album%,'.*','.jpg'))
What part of this needs editing?
just paste this code in the box 'Sources' like said in the doc !
Ok than I did it right. Because I got confused whether paths were to be edited there or not. First I copy pasted it but didn't work. So I thought I had to edit something and tried that too.
It's probably my paths and file names in extended variables.
So I got the paths ending correctly with "/"
And I put file names as %album%*.*
Anything wrong there? reads perfectly well except for chronflow, no image at all.
EDIT: Btw what does the heart do?
EDIT 2: Last thing I believe. How do I set it so that if no artist art is found (but cover is), display default background? Force Wallpaper not it.
And kameleon_cycle_bg works for all background right (not just default)? If I have Red Hot Chili Peppers 1.jpg and Red Hot Chili Peppers 2.jpg it will cycle between the two? (being that I set it as %artist%*.*). But if I have 7 RHCP backgrounds can I set value to 7? Or is maximum 6?
EDIT 3: For example album names with : what should the path to the album art be? replace : by what? tried _ - x and space. none worked.
Hi,Falstaff
"Album List (AL) and Playlist Switcher (PL) panels are now opened in maximized mode by default in the LEFT PANEL"
Can you make it on Info panel?
I would (maybe more people) like to use default width and height. So I think that could be useful.
And there is a bug:
Splitter Settings→Script→PerTrack
$font(SegoeUI,8,normal)
SegoeUI without a blank space.
And there is a problem,see the pic...
I set path panel to hide,and after the song is changed,I click "↑" icon.....
This config is awesome,THANKS!
Possible to create an icon to link wikipedia for artist/band bio?
Hello, is there no possibility one this style can use without having to do still some manual adaptations? With me the style does not hit anyhow so properly and I can also provide no more Playlist or use!
it works perfectly without manual adaptations dude!
after, if adaptations are needed, it is just because people want to have it like their tastes
and i remain to you this advertisement on my first post :
--- use at your own risk and matching your foobar capacities ---
Bye
Hi,Falstaff
And there is a bug:
Splitter Settings?Script?PerTrack
I set path panel to hide,and after the song is changed,I click "?" icon.....
Sorry my bad english.
thanx, bug fixed for next build (1.2.1, release soon, optimized version )
so........you accepted all my suggestions?
[a href="http://xs537.xs.to/xs537/09126/kameleon_1.2.1311.png" target="_blank"]
... INFO now opens maximized too, good suggestion.
happy to see the answer!
and i was forgot to say......
it's not just info pane......l
STAT panel........... please
sorry...
write an english post to me is too hard....
i can only read
sorry...
i can only read
no, i do not want to maximize STA by default, sorry.
sorry...
i can only read
ok,i understand.
1 question...
why does chronflow and el playlist collapse/expand icons display on same panel with abcdefg(AB PANEL).................this panel,also rating system,too?
somethime i don't want to use collapse/expand buttons and don't want to use AB panel........
i just want to see that rating system aways,see what i rated to that song or i can rate to...........(this is just like ibiza and curacao config)
but i must open ab panel to do that...
and sorry for the bad english...
i know it's not easy to read,sorry again..
v1.2.1 RELEASED !
(http://th05.deviantart.com/fs44/300W/i/2009/080/7/2/Kameleon_v1_2_1_Released_by_Br3tt.jpg) (http://fc75.deviantart.com/fs44/i/2009/080/7/2/Kameleon_v1_2_1_Released_by_Br3tt.jpg)
Change log :
1.2.1 :
- OPTIMIZED version of KAMELEON ! Elplaylist refresh is 60% faster ! very notable on big playlist load/change, a really big improvement.
- AL, PL and INFO panels in the LEFT main panel are now opened maximized by default for comfort.
- Added a new foo_run button to launch Wikipedia info about the now playing ARTIST. foo_run button name = "Wiki" / foo_run path command is : "http://en.wikipedia.org/wiki/$replace(%artist%,' ','_')"
- bugs fixed (File/Open, AL/PL display over other panels fixed, ...)
the bug is not fixed.
see my pic...
(http://i566.photobucket.com/albums/ss109/klxy/19667.jpg)
and wiki update is a pefect update.
now i can use it to see some of my favorite artist/band of news for an easy and quick way!
@runrunaway
Hotfix done, download it again, must be fixed all the case now ... i hope
fixed,everything is allright but one..
segoe ui still not fixed at all.
i show you an image,because i don't have an idea how to write it....
(http://i566.photobucket.com/albums/ss109/klxy/3369.jpg)
sorry, just fixed in the header playlist
so, i've replaced Segoe UI by Tahoma everywhere now,
check this .fcl and gimme feedback please.
http://br3tt.free.fr/files/K/kameleon_1.2.1.fcl (http://br3tt.free.fr/files/K/kameleon_1.2.1.fcl)
bye
and chronflow and ratiing system............
is possible to be that what i posted?
this is the last question...
not with me, i'll not change anything there.
and chronflow and rating system............
so sad...
Great update, as always
For you, runrunaway:
Right-click the "Kameleon"-button, then go to splitter-settings, script. Add those lines:
Per track tab:
$imageabs($add($get(pbt.x),170),$add($get(pbt.y),5),90,16,$get(foo_path)'images/curacao/rating/set1/r0.png',nokeepaspect,,255)
Per second tab:
$puts(cf_name,'kameleon')
$puts(foo_path,%FOOBAR_PATH%)
$puts(z,$get(foo_path)'images/'$get(cf_name))
$puts(pbt.x,7)
$puts(pbt.y,$sub(%_height%,50))
$ifgreater(%rating%,0,
$puts(rating,$if2(%rating%,0))
$imageabs($add($get(pbt.x),170),$add($get(pbt.y),5),90,16,$get(foo_path)'images/curacao/rating/set1/r'$get(rating)'.png',nokeepaspect,,250)
Note that I use the curacao rating icons (higher resolution), so maybe you have to change that.
that wasn't his request ...
That's no problem, it's also for everyone else who's interested.
It just lets you see the rating of the current song if you dont use the AB panel (similar to Curacou, under the album art).
(http://img228.imageshack.us/img228/8863/ratings.jpg)
yes but do not allow to modify the rating
Hi br3tt
i love your config, it's really great!
But, its not perfect, well, not for me.
So, could you help me to improve it for myself?
On this picture, all tasks that I want to perform are circled.
http://s10b.directupload.net/images/090321/3celrusa.jpg (http://s10b.directupload.net/images/090321/3celrusa.jpg)
By "replace by albumlist" I mean, to put the albumliust back to the place where it was in the earlier versions of Kameleon (1.0 I think), because the current behavior really annoys me.
I hope you could help me.
Can one also put this the cover are not covered separately from a folder separate directly from the day ID3? If not all cover liked to pack by hand in a folder there some songs the cover have already integrated!
sorry but your traductor is shit ! we do not understand at all what you want to say !
Shazbot, nanu nanu !
Regarding chronflow it's probably my paths and file names in extended variables.
What does the heart do?
How can I make the background cycle between artists pics? For example if I have multiple Red Hot Chili Peppers back grounds
Album names with : what should the path to the album art be? replace : by what? tried _ - x and space. none worked.
Bug: When pressing INFO AL or PL, if you than press spe, art, lyr, etc it will load as full panel, and it won't split if you try to add more. You have to press again in INFO AL or PL to put things right.
The heart button changes <MOOD> tag to 1. In effect, it changes the track number to gold.
The "i hate this song" button beside it changes <SKIP> to 1. Testing it, it doesn't really skip the track. It changes the track number to an "i hate this song" icon.
Pushing both buttons turns the track number into a golden "i hate this song", signifying your bipolarism.
It doesn't seem to have any connection with the love/hate track in Last.fm, which is a pity.
not a bug, when you are maximized in the left panel, you can switch to another panel but it stays maximized (wanted!), just click the zoom out button to go back to panel stack display (mini-panels)
nm.
Nice cfg ^^
RTFM
You need to add additional entries to run services.
Can one allow to not indicate the cover directly from the file MP3? (ID3Tag ) without separate folder for it to make?
hmm .. strange issue, but when I updated from 1.2 to 1.2.1 I've problem with foobar. There is no fonts in playlist, now after returning to old version, still I can't see fonts. Adding screenshot
(http://img15.imageshack.us/img15/5069/fooi.th.jpg) (http://img15.imageshack.us/my.php?image=fooi.jpg)
Anyone? I'm guessing it's not possible?
Ok than I think we should be able. After pressing AL or PL of Info which automatically loads maximized, if we click SPE twice next. First it would show SPE maximized. After the second click, it would minimize. Pratical.
It's your skin in the end. I'd be appreciated if you could help me with my questions being that the heart button was already clarified.
hi brett...
i've got a little trouble with stats... (with 1.2.1, but not with 1.2.0).
i can't see them...
you can view a 1.2.0 screenshot here (with stats) :
(http://img519.imageshack.us/img519/5645/120p.th.jpg) (http://img519.imageshack.us/my.php?image=120p.jpg)
and a 1.2.1 screenshot here (without stats) :
(http://img21.imageshack.us/img21/1672/121egn.th.jpg) (http://img21.imageshack.us/my.php?image=121egn.jpg)
I don't understand...
hi brett...
i can't see them...
change made from 1.1 to 1.2.x : now, stats only use %play_counter% tag info and no more %play_count% tag
you can change %play_counter% values in GB Stat and in ELPlaylist panels to make it match you %play_count% tag ...
Falstaff,could you add an option for info panel to switch the follow cursor or now playing mode?
... the RIGHT-CLICK is so difficult ? Sorry, but not a real need in my pov...
Kameleon bug has been reported here (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=70623&view=findpost&p=623251) and seems to be causing users to want silly things. Please fix this.
oh
Sorry, but it is not a bug in the way that displaying only the year (4 digits only) is intentional in Kameleon.
thanx for the report btw.
If you're going to insist on the 4-digit format, could you use $left(%date%,4) or something to allow longer dates to not interfere?
i'll check that asap, promised
like this?
(http://i566.photobucket.com/albums/ss109/klxy/5596.jpg)
i did not find the option,so how to?
i meant info left panel...
how i can change shuffle order to random in new version?
cant find code in script settings...
BUG?: It is a bug but not sure if it's fixable. When viewing a different playlist that is not the one playing, if you try to minimize all album headers in the - button it will take you back to the playlist that is currently playing. Gets annoying to me as I'm constantly editing songs and many times they are on a different playlist.
Falstaff, could you please answer my questions above? thx
fixed in v1.2.2 just released Change log :
1.2.2 :- Bug fixed : sometimes playlist switcher left panel had bad refresh (very annoying) => no more now (btw no more reproduced with the fix)
- Bug fixed : buttons + / - to expand or collapse the playlist ativated too the 'Show now playing command' => removed
- YEAR display in the playlist header : now, long dates are accepted but it still display only the Year (it take by default the 4 digits on the left : 2005-07-24 => 2005)
- Tweaks
Change log :
1.2.2 :
- Tweaks
(http://img53.imageshack.us/img53/4656/capturar.th.jpg) (http://img53.imageshack.us/my.php?image=capturar.jpg)
How to change font size to look better? see image, please.
Tanks
digital font available in this pack from my site : [a href="http://br3tt.free.fr/files/K/fonts-kameleon1.2.7z" target="_blank"]http://br3tt.free.fr/files/K/fonts-kameleon1.2.7z (http://img53.imageshack.us/my.php?image=capturar.jpg)
Tanks,
Tanks,
AK-47,
i have the following error
Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 012EBE32h
Call path:
entry=>app_mainloop
Code bytes (012EBE32h):
012EBDF2h: 50 8B CE FF 53 08 5B 5F 5E C9 C2 04 00 8B 06 57
012EBE02h: 6A FF FF 74 24 0C 8B CE FF 50 20 8B F8 83 FF FF
012EBE12h: 75 04 33 C0 EB 16 8B 06 57 8B CE FF 50 18 85 C0
012EBE22h: 76 F0 8B 06 6A 00 57 8B CE FF 50 1C 5F C2 04 00
012EBE32h: 0F 57 C0 83 20 00 83 60 04 00 F3 0F 11 40 08 F3
012EBE42h: 0F 11 40 0C C3 8B 81 9C 01 00 00 03 81 94 01 00
012EBE52h: 00 C3 8B 44 24 04 83 C1 04 83 F8 0A 73 07 6B C0
012EBE62h: 28 03 C1 EB 0C 83 C0 F6 6B C0 28 03 81 94 01 00
Stack (0012F974h):
0012F954h: BBF901E0 BF83FAA9 0000000C 00000060
0012F964h: 00000000 B9E49B30 BF83FABC FFFFFFFF
0012F974h: 012E5941 FA4FF307 00000000 00000000
0012F984h: 00A3C4B8 7C910040 00A30000 7C91003D
0012F994h: 1000B532 003C0000 0012FA00 012FEAA9
0012F9A4h: FFFFFFFF 0012FA0C 0043DBEF 00000000
0012F9B4h: 0012F9C8 0012F9F4 00000000 00A3C468
0012F9C4h: 00000000 004EA0D4 00000000 00000000
0012F9D4h: 00000000 00000000 00000000 0012FA40
0012F9E4h: 00A3BB58 00000000 00000000 00000002
0012F9F4h: 00000000 00000000 0043DBA6 0012FA74
0012FA04h: 004C5FF7 00000000 0012FA2C 0043DA73
0012FA14h: 05350751 0012FB28 0012FA2B 00A3C468
0012FA24h: 00000000 0112FA14 0012FA80 0043D914
0012FA34h: 05350751 0012FB28 00000001 00A3C418
0012FA44h: 00000002 00000000 00000008 23FB5422
0012FA54h: 441DB11C 841F79BD 873D07B4 00000002
0012FA64h: 00000000 00000000 00000001 05350751
0012FA74h: 0012FAE8 004C6A89 00000000 0012FAA0
0012FA84h: 0043DA73 047F07A5 0012FB28 0012FA9F
Registers:
EAX: 0012F988, EBX: 00A3C4B8, ECX: 0131245C, EDX: 0012F9C8
ESI: 0131245C, EDI: 00000000, EBP: 0012F9A8, ESP: 0012F974
Crash location: "foo_menu_addons", loaded at 012E0000h - 0131C000h
Loaded modules:
foobar2000 loaded at 00400000h - 0053B000h
ntdll loaded at 7C900000h - 7C9AF000h
kernel32 loaded at 7C800000h - 7C8F6000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F02000h
Secur32 loaded at 77FE0000h - 77FF1000h
GDI32 loaded at 77F10000h - 77F59000h
USER32 loaded at 7E410000h - 7E4A1000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7D561000h
ole32 loaded at 774E0000h - 7761D000h
shared loaded at 10000000h - 1002A000h
UxTheme loaded at 5AD70000h - 5ADA8000h
COMDLG32 loaded at 763B0000h - 763F9000h
IMM32 loaded at 76390000h - 763AD000h
guard32 loaded at 003D0000h - 003F7000h
VERSION loaded at 77C00000h - 77C08000h
fltlib loaded at 4FFE0000h - 4FFE8000h
MSCTF loaded at 74720000h - 7476C000h
msctfime loaded at 755C0000h - 755EE000h
foo_rgscan loaded at 00AA0000h - 00AFB000h
foo_converter loaded at 00B50000h - 00BBC000h
foo_run loaded at 00BD0000h - 00BFD000h
foo_ui_columns loaded at 00C20000h - 00D5B000h
gdiplus loaded at 4EC50000h - 4EDF6000h
foo_albumlist loaded at 00D90000h - 00DFB000h
foo_uie_vis_channel_spectrum loaded at 00E20000h - 00E5D000h
MSIMG32 loaded at 76380000h - 76385000h
WINMM loaded at 76B40000h - 76B6D000h
foo_lastfm_radio loaded at 00F00000h - 00F48000h
foo_dsp_std loaded at 00F70000h - 00FB8000h
foo_runcmd loaded at 00FE0000h - 01014000h
OLEAUT32 loaded at 77120000h - 771AB000h
foo_uie_elplaylist loaded at 01040000h - 010A9000h
foo_uie_panel_splitter loaded at 010D0000h - 0111F000h
foo_ui_std loaded at 01140000h - 01214000h
foo_playcount loaded at 01240000h - 0126A000h
foo_uie_tabs loaded at 01290000h - 012B8000h
foo_menu_addons loaded at 012E0000h - 0131C000h
foo_cdda loaded at 01340000h - 01380000h
foo_uie_wsh_panel loaded at 013A0000h - 013CF000h
CLBCATQ loaded at 76FD0000h - 7704F000h
COMRes loaded at 77050000h - 77115000h
foo_exvar loaded at 01530000h - 01558000h
foo_skip loaded at 01680000h - 0169D000h
foo_input_std loaded at 016C0000h - 01800000h
foo_uie_trackinfo_mod loaded at 01820000h - 01876000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_playback_custom loaded at 018A0000h - 018E5000h
WINSPOOL loaded at 73000000h - 73026000h
foo_uie_graphical_browser loaded at 01930000h - 019C4000h
foo_utils loaded at 019E0000h - 01A24000h
foo_vis_shpeck loaded at 01A50000h - 01A8E000h
foo_uie_lyrics loaded at 01AB0000h - 01B0D000h
WININET loaded at 78050000h - 78120000h
Normaliz loaded at 01B20000h - 01B29000h
iertutil loaded at 78000000h - 78045000h
foo_chronflow loaded at 01D50000h - 01DB1000h
OPENGL32 loaded at 5ED00000h - 5EDCC000h
GLU32 loaded at 68B20000h - 68B40000h
DDRAW loaded at 73760000h - 737AB000h
DCIMAN32 loaded at 73BC0000h - 73BC6000h
foo_uie_quicksearch loaded at 02610000h - 02656000h
foo_uie_albumlist loaded at 02680000h - 026BD000h
xpsp2res loaded at 02940000h - 02C05000h
imagehlp loaded at 76C90000h - 76CB8000h
DBGHELP loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 012E5941h, location: "foo_menu_addons", loaded at 012E0000h - 0131C000h
Address: 7C910040h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C91003Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 1000B532h, location: "shared", loaded at 10000000h - 1002A000h
Address: 012FEAA9h, location: "foo_menu_addons", loaded at 012E0000h - 0131C000h
Address: 0043DBEFh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004EA0D4h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0043DBA6h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004C5FF7h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0043DA73h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0043D914h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004C6A89h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0040B3E7h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0041F4E8h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 013C0793h, location: "foo_uie_wsh_panel", loaded at 013A0000h - 013CF000h
Address: 7E42929Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SendMessageW" (+00000000h)
Address: 0043E2DEh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00CA4D09h, location: "foo_ui_columns", loaded at 00C20000h - 00D5B000h
Address: 7E42B317h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "MoveWindow" (+00000079h)
Address: 7E42B326h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "MoveWindow" (+00000088h)
Address: 7E44048Fh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E42B330h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "MoveWindow" (+00000092h)
Address: 00CFFBA0h, location: "foo_ui_columns", loaded at 00C20000h - 00D5B000h
Address: 00CA4776h, location: "foo_ui_columns", loaded at 00C20000h - 00D5B000h
Address: 00CCABF0h, location: "foo_ui_columns", loaded at 00C20000h - 00D5B000h
Address: 7E4188D1h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E4188DAh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 00CFFBD8h, location: "foo_ui_columns", loaded at 00C20000h - 00D5B000h
Address: 00CCAD86h, location: "foo_ui_columns", loaded at 00C20000h - 00D5B000h
Address: 00C7F1BEh, location: "foo_ui_columns", loaded at 00C20000h - 00D5B000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000169h)
Address: 7E4189CDh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 7E42B19Ch, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DestroyWindow" (+00000000h)
Address: 026390ABh, location: "foo_uie_quicksearch", loaded at 02610000h - 02656000h
Address: 7E4189F0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 7E418A10h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0043A70Dh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 1000258Fh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000C8h)
Address: 0043B1E4h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004D9DF4h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 7C9101C0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004EA0B8h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 003D21ADh, location: "guard32", loaded at 003D0000h - 003F7000h
Address: 7C9100A4h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 004AF3E1h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004B3396h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004E075Ch, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004CB0C1h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0043B426h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004AF9C1h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004AF9BBh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004D1BC0h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004CFD20h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004B1650h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004AF9CFh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004CB24Dh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004B151Ah, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 7C817067h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AC0h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C817070h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 004B1585h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00530057h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 003D006Eh, location: "guard32", loaded at 003D0000h - 003F7000h
Address: 003D0065h, location: "guard32", loaded at 003D0000h - 003F7000h
Address: 00530022h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00500069h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 0053B000h
Version info:
foobar2000 v0.9.6.3
UNICODE
Windows 5.1
Additional info:
Columns UI 0.3.6.5 (foo_ui_columns)
Playback Statistics Custom 1.4.3 (foo_playback_custom)
Menu Addons 0.4.1 (SSE) (foo_menu_addons)
Last.fm Radio 0.5.5 (foo_lastfm_radio)
Tabbed Panel Modified 0.2.7 (foo_uie_tabs)
Chronial's Coverflow 0.3.0 (foo_chronflow)
Run Command 1.0 beta 3 (foo_runcmd)
Extended Variables 0.3.1 (foo_exvar)
WSH Panel (uie) 0.7.2 (foo_uie_wsh_panel)
Quick Search Toolbar 2.8l (foo_uie_quicksearch)
Playlist Tools 0.6.2 beta 6 (foo_utils)
foobar2000 core 0.9.6.3 (Core)
ELPlaylist 0.6.4(beta) (foo_uie_elplaylist)
Track info panel mod 0.8.0 beta [Jan 5 2007 - 13:36:12] (foo_uie_trackinfo_mod)
Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01] (foo_uie_lyrics)
ReplayGain Scanner 2.0.8 (foo_rgscan)
CD Audio Decoder 2.1.4 (foo_cdda)
Shpeck - Winamp vis plugins wrapper 0.3.0 (foo_vis_shpeck)
Default User Interface 0.9.5 (foo_ui_std)
Standard Input Array 1.0 (foo_input_std)
Skip Track 0.4 (foo_skip)
Standard DSP Array 1.0 (foo_dsp_std)
Album list panel 0.2.2 (foo_uie_albumlist)
Graphical Browser rev015 (foo_uie_graphical_browser)
Album List 4.3 (foo_albumlist)
Playback Statistics 2.1.6 (foo_playcount)
Converter 1.2 (foo_converter)
Run services 0.3.5 (foo_run)
Channel Spectrum panel 0.17.2 (foo_uie_vis_channel_spectrum)
Panel Stack Splitter 0.3.6.3(alpha) (foo_uie_panel_splitter)
can someone tell me whats wrong?
What version of foo_menu_addons are you running?
latest, i think 0.4
i'm using the one in the kameleon archive
i did a fresh install of foobar2000 0.9.6.3
extracted kameleon archive
and when i open foobar and click on playback or other menus it crashes
just a question : is libmmd.dll in you foobar2000 folder ?
C000001Dh == Invalid instruction, e.g. running a component compiled with SSE2 instructions on older CPU.
how come i'm missing the "Play Counter" setting.
http://br3tt.online.fr/html/K/index.htm (http://br3tt.online.fr/html/K/index.htm)
D/ Components settings
thanks
How can I change this the cover as a background is not used?
I love holidays - you are back and a new cool version is released.
Thank you Br3tt.
Thank you Br3tt.
You're welcome bubi
thanks
View (on kameleon skin) > toogle toolbars (in case it's hidden) > Library (on foobar toolbar) > Playback statistics > Monitor playing tracks (uncheck).
thanks
i mean this.
(http://img124.imageshack.us/img124/9840/foob.png)
what plugin is it.
tried on foobar v 0.9.6.2, 0.9.6.3, 0.9.6.4 b2
Tools -> "Play Counter" entry is the official statistic plugin : foo_playcount.dll
I have the dll in my components folder but I don't have the item in my tools list in the preferences.
(http://img152.imageshack.us/img152/1251/screenshot2503200914133.th.png) (http://img152.imageshack.us/my.php?image=screenshot2503200914133.png)
Any ideas? I'm running Windows 7 beta incase it makes any difference.
same as you, also running windows 7. tried foo_playcount.dll v2.1.6 and 2.1.8
(http://img136.imageshack.us/img136/9017/foobp.png)
@Falstaff
Sorry, but Tools --> Play Counter is not the entry of the official statistics plugin foo_playcount.dll
Its one and only setting is available through Advanced --> Tools --> Playback Statistics.
The above entry must come from a 3rd party plugin (maybe the obsolete foo_custominfo, but i don't know. I never used it)
@Falstaff
Damned !! you're right
Weird, i have no other stats plugin in my components folder (except Playback custom Stats which is another entry in ->Tools)
surely the panel from foo_playcount_mod but i've removed it a long time ago now, and screen settings still there
Is there a way to remove overlay from artists pictures in GB? I tried removing photo-ov3.png from *\images\kameleon\cover\ but with no effect...
I have next troubles:
(http://img243.imageshack.us/img243/4116/kamfoo2000h.jpg)
How can I fix this?
point 1 and point 4 - Hide
point2 and point 3 - Show
in the top toolbar menu: 'View' entry, Show status bar, Show toolbar, or just in the View menu inside Kamaeleon (just above the playlist) -> Toggle Toolbar, Toggle Status bar !
and install the font digital.ttf included in the font package on my site
i copy fonts in my windows/fonts folder and in fonts folder foobar2k and point 2 and 3 dont work.
ask to Bill, must work (reboot done?)
Open Control panel, --> Fonts
Drag and drop .ttf file into fonts folder
Thanks. Anymore bugs, I'll report.
How do I set it so that if no artist art is found (but cover is), display default background? And if an artist has and invalid character in it's album name, what's the symbol for replacement in it's image path?
I am sorry for my English. Many thanks to the author for the done work. I would like to add for myself two buttons, the console and UPNP Browser. What exactly it is necessary to correct in scripts not to do much harm? Thanks.
I also have foo_playcount.dll component but no "Play Counter" option in Preferences > Tools. Did anyone figure this one out? I do have foo_playback_custom.dll > Playback Statistics Custom, but no Play Counter... how can we get this to show up?
mistake from me in my doc, just read on the previous page the post #519 : http://www.hydrogenaudio.org/forums/index....st&p=623719 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=623719)
also looking on how to add upnp browser.
Hammurabi presents a hack 'n slash adventure in replacing panels
1. Right click splitter > Add Panel > %your_panel% (e.g UPNP Browser)
Now your panel should replace the whole splitter
2. Right click till you get the splitter menu again > Splitter Settings
You should see %your_panel% there, click it > Select Force Layout
3. Pick a existing panel you want to replace, e.g -> SPE, -> AL.
Rename it. Call %your_panel% it's previous name.
4. Click Apply
It may not be pretty but it works
My spectrum visualizations (i.e. bars going up and down and/or left to right) flicker rapidly after a while during playback... They continue to flicker until I click on the visualization. I am synched to scanline, and I use full (new) FFT modes on all three. This is a random bug, and I do not know how to replicate it. Windows Vista SP1 32-Bit, with latest foobar and foobar components.
i am having some problem with the new version
seems like i am missing some image as i highlighted in the red box
(http://img398.imageshack.us/img398/8433/missing.jpg)
have you installed the new images/kameleon folder too ??? (EDIT: it seems yes because i see the Wikipedia button ... )
and have you the last version of Panel Stack Splitter ? (http://foo2k.chottu.net/)
Falstaff i got the same problem , and i got everything . Thank you
yup..i am using the latest version of the panel stack
still no luck for me
maybe i will try reinstalling the whole thing
I'd like to say I really love Kameleon. This is the first one I've tried and your instructions were clear and easily understood, I had no problems getting it all up and running. That's not to say I won't run into problems along the way but for now I'm loving it!
Thanks Falstaff!
Let Me Know Squall To See If Reinstalling It Solved The Problem , Maybe Ill Try It Me Self . THANK YOU...
it does work
after i reinstall the whole foobar
First of all my heartly thanks for giving the most fancy looking player i have ever seen.
secondly , all my music files are embedded with cover art. is these a way so that Kameleon will show embedded covert art as default ?
thanks
I have few suggestions (not requests!) which could make this config even better. I've been using foobar for quite a while now (still have old installation with Scaled 0.7) and this is the best config I've seen so far.
1.Replace playlist switcher with library tree. IMHO library tree offers much more than playlist switcher. I've done this on my config and I'm very satisfied with the result
2.It would be great if Biography view could be implemented in left panel. I'm aware this component is new and it might need some improvements.
3.IMHO overlay on artist pictures makes them look artificial, and they would be better without it.
4.Maybe some kind of large cover HTPC view would be nice
That's it Just some suggestions to think about if this config is going to be improved.
Cheers
Hello. I have noticed that when I play music, the player changes the files. I don’t know if it’s because of this skin or foobar in general. Does it update a play count tag or something? I need the integrity of the files intact after they are played.
I dunno if this is how it's supposed to be but, whatever settings I make to the config, like removing the right side album covers list or enabling the scrollbar, its all removed upon closing and then reopening foobar. There a fix or an option for this?
@Zodler:
http://br3tt.free.fr/html/K/index.htm (http://br3tt.free.fr/html/K/index.htm) check chapter D/
@snively:
http://br3tt.free.fr/html/K/index.htm (http://br3tt.free.fr/html/K/index.htm) check chapter B/
Hi Falstaff,
Could You add Biography view (http://www.hydrogenaudio.org/forums/index.php?showtopic=70955&st=0) in the new version kameleon?
great config..really.
I'm very happy to see that the alphabetical listing (letters at the bottom) also now show Japanese characters. Well done Brett! Now I can use that part of the config ^^
Thanks again for the hard work.
Squall THANK YOU . It Did Work ,Now It Looks Nice Very Nice InDeed . THANKS...
Hammurabi presents a hack 'n slash adventure in replacing panels...
Here is a pic with UPnP Brower and Biography view. Just replace a panel you don't use.
Also, thx for all the hard work, Br3tt
(http://i44.tinypic.com/307yej6.jpg)
@snively:
Thanks, I appreciate it!
Is there a way to turn the headers off for specific playlists? I'd like to remove them for single file playlists as having to scroll through all of those files would be much easier without the headers.
Thanks...tried your hack 'n slash and it did the trick on the bio panel.
Is there a chance to rewrite info about playcount from database to files tags? I'm searching for a program that can do it automatically to all my files
would it be possible to hide the lyrics panel if there are no lyrics found for the track?
Br3tt (or anyone),
If I hide GB Albums and GB Artists (right panel) on startup, what should I un-hide on startup in order for the ELPlaylist panel to extend to full width?
Oooh! Just figured it out: additionally hide Right Panel. Nice!!
Damn, this is a great config. Thanks again, Br3tt!!!
just hide "-> Left Panel" & "-> Right Panel"
How can u open the Playlist switcher minimized by default?
like all other panels and as explained in the doc on my site . . .
right-click on the left panel header then enter Splitter Settings : in the panel list, select panel "-> PL" and uncheck the option "hide on startup" to make it visible on startup, minimized like other panels in the left area.
Is there a way to add a panel to the left side that displays like the artist bio from last.fm or something?
yes there is ...
(http://xs138.xs.to/xs138/09154/bio620.jpg.xs.jpg) (http://xs138.xs.to/xs138/09154/bio620.jpg)
just add a panel in the INFO 'left' panel to add the Biography plugin in (you may have to delete scripts from '-> INF' panel to make bg clean ...)
no i mean that it is opened like a small panel when u click on the PL button not that it is opened small at startup!
yes there is ...
[a href="http://xs138.xs.to/xs138/09154/bio620.jpg" target="_blank"]
I think should be able to manage
-edit-
I got it working by replacing INFO, but if it's not too much work, could you provide scripts for adding BIO as an option, and a new panel for it? I've been trying for a bit, but it's a little overwhelming.
Sorry for the trouble =x
-edit2-
updated to the newest version, but I can't figure out how to make all of the albums in ELplaylist collapsed by default, other than the one you're playing. Also, how can I set it up like in curacao where the basic info, e.g. bitrate and format is also displayed in the compressed view? Can I also make it display the playback stats of songs other than the one i'm listening to?
Again, sorry for the hassle.
@snively:
ok, so answer is no.
i've made the choice to open it maximized by default since v1.2.x, it's coding, no parameter to change that easily for now.
This is an outstanding plugin. It does everything I want. I can tailor pretty much anything I want to fit the specifics, but I am really having a hard time getting my album art to show up anywhere except in Chonflow.
My chronflow code is as follows:
Since I cannot use the $replace function in the Extended Variables, I will have to get creative based on what I have read.
Attached is my current settings, and I cannot get the artwork to show at all.
[a href="http://img19.imageshack.us/my.php?image=settingsc.jpg" target="_blank"]
Thanks but this doesn't tell me how to resolve the issue... Does anyone know how to get "
Play Counter" to show up under
Preferences > Tools?
Regarding playback stats - my Kameleon "STAT" panel is blank. I am saving playback statistics (using Playback Statistics Custom) to the
foo_custominfo database... I thought this was OK to do, but my STAT window remains black/empty.
Playback Statistics Custom settings - yes, these tracks are in my Media Library - I have tried unchecking this setting too with no effect:
(http://i385.photobucket.com/albums/oo292/lonkny/th_PlaybackStats3.png) (http://s385.photobucket.com/albums/oo292/lonkny/?action=view¤t=PlaybackStats3.png)
Extended Variables:
(http://i385.photobucket.com/albums/oo292/lonkny/th_PlaybackStats4.png) (http://s385.photobucket.com/albums/oo292/lonkny/?action=view¤t=PlaybackStats4.png)
STAT panel:
(http://i385.photobucket.com/albums/oo292/lonkny/th_PlaybackStats5.png) (http://s385.photobucket.com/albums/oo292/lonkny/?action=view¤t=PlaybackStats5.png)
Not sure if "kameleon_rate_to_db" has anything to do with this, but right now I have this set to NOT put ratings in a database because it wasn't working well (the database must save the path to the file, because once I move a file that I have rated I lose the rating for that file... is this correct? Is the only way to save the rating with a file that moves to another folder to tag it?).
Does anyone have any ideas about this? More importantly does anyone know how to get Play Counter to show up in Preferences?? Thanks!
Interesting idea. Well, I tried something myself (in the left-panel splitter)
$iflonger(%lyrics%,1,
$showpanel_c(P2,1)$showpanel_c(-> LYR,1),
$showpanel_c(P2,0)$showpanel_c(-> LYR,0))
The problem is, it's missing a refresh-command. F.i. if the LYR panel is shown, for the first song without lyrics nothing happens, for the next few the panel is hidden. If someone knows how to do it that it works immediately, please tell me
Anyone? I am sure it is a small syntax issue, but I cannot figure it out...
Hi..I need a little help in ELP.
I have some tracks with a title, but has too a subtitle tag (<PART>) or/and a remix tag(<VERSION>).
For example:
In the tag I have got this:
TITLE : Beyond The Eyelids
PART : Part One: Fearless
VERSION: Live
And foobar only shows - Beyond The Eyelids
I would like something like: Beyond The Eyelids - Part One: Fearless (Live)
Thanks a lot!
When I replaced the INFO panel with Biography panel, I can't scroll through long text in the Bio
(the change log of the plugin says scroll function is already available)
Any ways to fix it?
I realise the "easy" way to do this is just switch the extended variables but I believe that would alter more than it should, so..
Can anyone tell me the best way to switch around the artist pic and the album cover (in the background only) so that the album cover is always the wallpaper but the artist pic appears in the small window on the top left.
Also - if possible - is there a way to sort the playlist by rating?
cheers :]
Hello,
How to change font "digital.ttf "for another one already install ( ex. arial )?
I am at work and i have no permissions to install new fonts.
tanks
(http://img19.imageshack.us/img19/2290/foowork.th.jpg) (http://img19.imageshack.us/my.php?image=foowork.jpg)
Any ways to fix it?
I figured it out myself
It's my Touchpad setting, I should set it to "Scroll item under pointer", not "Scroll selected item"
Great theme, enjoying it very much.
One question, though.
I have a pretty massive library, although it's few artists and many albums of every artist. Is there a way to set ELPlaylist up so that only the artist names will be displayed in a list, than when clicked it will display all his albums with thumbnails? It will be a lot easier to for me to scroll the library this way.
Thanks,
Eyal
I'm dying here, guys. Anyone want to just take a shot at it? I am baffled here...
I still have the problem with the album art.
It was working with Curacao but now I'm still trying with no luck.
//////////Group Header//////////
$if($findfile(%__ART_PATH__%),
$puts(art_path,%__ART_PATH__%)
$puts(art_path,$get(foo_path)'images/'$get(config_name)'/cover/nocover.png')
$if($findfile($substr(%path%,1,$strrchr($replace(%path%,\%filename_ext%,),\))Cover.jpg),
$puts(art_path,$substr(%path%,1,$strrchr($replace(%path%,\%filename_ext%,),\))Cover.jpg)
Btw "Play Counter" isn't showing up in Preferences.
Is there anything i can do to make the playlist scroll faster and smoother? It seems that my external firewire drive may slow it down, but i have also over 1000 albums in there, so when i want to scroll through all of them, its a little slow...will an eSata connection fix the problem?
hello,
ive recently swtiched from ibiza to kameleon, all is woking fine except some fonts are not displeyed properly...
it looks like individual problem, but i would like to ask what might be causing it
here's a pic: (http://img206.imageshack.us/img206/6559/kameleon.th.png) (http://img206.imageshack.us/my.php?image=kameleon.png)
(i have had same issue with those fonts in ibiza on vista, was working fine on xp)
currently, im running Vista 64 @ 1920x1080 (native res)
thanks, Viggen.
it's because the default dpi of fonts on your Vista system has been modified by yourself to a greater value !
skins are designed for a default dpi size, so you are right, it's a personnal problem, easy to fix.
oh, didnt think about it...
by saying "easy to fix" you mean setting windows dpi back to 96 px?
i think ill go back to my modded ibiza, but problem still remains.
anyway thx for answer.
No no, stick with Kameleon, it will get better and better....
Agree!
Even though I like Curacao look more, Kameleon is so flexible & has many more features & easy to configure.
Can't think of going back to any other config
Hi..I need some help with ELPlaylist.
For example:
VERSION: Live
ELPlaylist only shows - Beyond The Eyelids
I would like something as: Beyond The Eyelids - Part One: Fearless (Live)
When you change window settings like add the sidebar, close the CSP and what not, how do you save these settings so you don't have to do them every time to open up foobar?
Also, I can't for the life of me tell why my collection is sorted this way: I am using artist/album:
(http://img10.imageshack.us/img10/4382/foobarv.th.jpg) (http://img10.imageshack.us/my.php?image=foobarv.jpg)
As you can see, that Pretenders album is split up for some reason, I do not see any difference in the tags; Anyone know why it's spited up in the playlist?
One part of your Pretenders album has the disc number in tag, the other doesn't have, so they are splited.
I think the default sorting is %album artist% - %date% - %album% - %discnumber% - %tracknumber% - %title%
After changing settings, go to Preference/Colums UI/Export, export your settings to an .fcl file, then Import it
I have been playing around with Extended Variables, and I am not getting anywhere. Here is the structure of my music collection:
F:\Music\"Artist Name"\"Album Name"\"Artist Name - Album Name - Cover.jpg"
For Example:
F:\Music\Opeth\1998 - My Arms, Your Hearse\Opeth - My Arms, Your Hearse - Cover.jpg
Here is what I thought would work using Extended Variables:
kameleon_coverart_path F:/Music/%artist%/%album%/
It does not load any of the covers. I have tried so many variations, and nothing works. I can get Chronflow to work easy, but this has me baffled.
Fallstaff: do you have any ideas? Is there any way to edit the scripting so that instead of using your default, the default would be something like my file structure?
For Example:
it works perfectly, just tested like the way you want :
(http://xs538.xs.to/xs538/09172/_ext_var841.jpg)
be sure that your TAG and folder names are the same to make that working.
you can try for the path to simply set it like this :
kameleon_coverart_path default
For Example:
Okay, I figured out what the problem is: All of the folders that contain each album have the date of the album release before the name of the album.
For example: 2000 - Mer De Noms
If I delete the date, everything works. Unfortunately, I really need to have the date before each album so I can sort the albums chronologically instead of alphabetically. Here is the code I am using, but it is not working:
kameleon_coverart_path F:/Music/%artist%/%date% - %album%/
Does the %date% function work in extended variables? That is the only reason why my covers are not showing. The date on the folder of each album is throwing it all off...
I am almost there. Any hints?
I have some tracks with a title, but has too a subtitle tag (<VERSION>).
I did a little change to show this information, but I don't know why that information is not capitalized. Take a look plz:
http://farm4.static.flickr.com/3529/346498...1004b7534_o.jpg (http://farm4.static.flickr.com/3529/3464989372_f1004b7534_o.jpg)
Try this:
$puts(title,%title%i$f(%version%,' ('%version%')'))
It is capitalized judging by your screenshot?
anyone know how to prevent playback statistics custom from bringing foobar to the front when updating tags? Occasionally, not all the time, foobar will come to the front when updating the playcount.
%date% is not handled in Kameleon for foo_exvar like said in the doc :
"IMPORTANT: foo-exvar do not handle variables like %var%, except %artist%, %album%, %album artist%, %band%, %performer% and %discogs_artist_id% because i have tweaked the code in K to handle them."
i can add it, i'll try to post a new version tonight.
I should have known that. Thank you for hopefully adding it. This is a great program! Thanks a billion
fcl file updated, now %date% handled for path or filename in foo_exvar
http://br3tt.free.fr/files/K/kameleon_1.2.2.fcl (http://br3tt.free.fr/files/K/kameleon_1.2.2.fcl)
enjoy!
Is there a way to add something in foo_exvar so it can look for album art one level up in the directory structure?
Something similar to this:
So I figured out this only happens when foobar is behind some windows, not when it's minimized. For example, I will have foobar playing (not minimized) and be surfing in firefox. When playback statistics custom updates the count (doesn't matter which setting, i.e. after 60 seconds, 50% etc) foobar will come to the front and I won't be able to click on anything until I click on foobar. If foobar is minimized, this does not happen. What other methods are there to update the little numbers by the songs besides psc?Edit: It had something to do with the tags themselves, I resaved them in mp3tag and the problem went away
enjoy!
I still cannot get it to work using:
Am I doing the date part wrong?
I can get F:/Music/%artist%/%album%/ to work if I take off the date but as soon as I add back the date to the folder and use the code above, the covers will not load. I appreciate the help though...
it works perfectly ! just re-tested with the same syntax as yours
be sure you have imported the new fcl, and that the TAG %date% has the same value that you use for the album folder...
Okay, now I feel like an idiot. I forgot to import the flc. I just copied over the old file with the new one. Everything works perfectly like you said. Everything is as it should now. Thank you so much for this, it is perfect now
you're welcome!
Try this:
It work perfectly! Thanks a lot man!
Now I did this!
http://farm4.static.flickr.com/3591/346927...9abcee272_o.jpg (http://farm4.static.flickr.com/3591/3469271652_e9abcee272_o.jpg)
Try mouse right click in group header --> sort --> present default
In Info painel I added some TAGs information:
http://farm4.static.flickr.com/3616/346932...632878f10_o.png (http://farm4.static.flickr.com/3616/3469323138_a632878f10_o.png)
How can I put a scrollbar there? I will be useful!
Is there someway to not appear the "..."?
Hey Br3tt where i can tweak the code to add some extra variables?
Try this: Right click in group header --> sort --> present default
Thanks for your help everyone, disc numbers!
I still can't save settings through.
Afaik there is no possibility to add a scrollbar to Trackinfo Mod.
read the doc
How can I make a bigger size of Cover art... I want a 400x400px cover.
For cover-art in the left panel: make the whole panel bigger with kameleon_left_panel_width (ExVar).
Well, it could be only a mouse wheel scroll
And about the "...", any solution?
increase the size of the left panel (read the doc, a foo_exvar variable is to set)
Just finished installing your mod Br3tt, and i must say that it is awesome.
Been sticking with Ibiza for about a year now, but Kameleon made me change.
Keep up the great work.
cool new project br3tt!!!
what i would like most would be if ELP would be more smooth and that the visualisations won't lag when you scroll through it (hope it is possible for you)
I tested and I like very much the skin but I can´t see the covers when the album is inside of rar archives(no problem using NGplaylist)..
is it possible to do this with Kameleon?
thanks a lot
thanks a lot
no.
what about >500, possible?
First - i think this is a great layout for foobar. Thanks for this great work!:)
Second - i found a "little" problem (i think so).
The Problem ist the following:
When you press "File -> Open" then foobar opened the "CD-Device-Menu" and not the "HDD-Device-Menu". I think this is wrong or!?
[a href="http://s10.directupload.net/file/d/1778/yy7j4dg6_png.htm" target="_blank"]
...Excuse for my bad english...
hi.nice skin.I want to see all my album covers and don´t know how to.The problem is I put in foo_exvar the coverart filename but I´ve noticed in my library that the covers are with different names like: front.jpg,Front.jpg,front.jpeg and cover.jpg
I only see one of them,how to put all these names in the variables to see all of them?
thanks a lot
Hello Kameleon community,
I am using Kameleon for some while now and I like it a lot. Thanks a lot to Br3tt for this really amazing skin. I just have one thing I cannot get to work for me, that is the way Kameleon presents compilations. I would like to have a number of songs displayed as belonging to one album Like
ALBUMNAME
Song 1 - Artist 1
Song 2 - Artist 2
Therefore I am using the "ALBUM ARTIST" tag. Here is what I get when doing so:
(http://home.arcor.de/christian.lugauer/foo_prob.jpg)
I guess my tagging of the files is correct but I am not experienced enough to find out what I have to tweak iside Kameleon to get the desired result. Could anybody point me in the right direction ?
Thanks a lot !!
This is all I got mine set too and it works
(http://img510.imageshack.us/img510/8559/53753803.png) (http://img510.imageshack.us/my.php?image=53753803.png)
as you can see from this image.
(http://img201.imageshack.us/img201/3049/67376373.png) (http://img201.imageshack.us/my.php?image=67376373.png)
Hi all.
I really need help with the Info Painel.
I have some extra information in my music tags that I would like to visualize in foobar, so I added some extra lines to the info panel.
(See picture (http://farm4.static.flickr.com/3580/3485080950_08d8a1b367_o.jpg))
Problem 1: In some screens I would need a way to scroll around the INFO panel cause they are to small. And even when the info painel is minimized, there are no way to see all information. Is there someway to get a mouse wheel scroll or even a scrollbar?
Problem 2: Some information is too long to the panel, so it shows a "...". Is there someway to show all information, using, for example, a new line below.
I'll be very very very grateful.
Thanks a lot!
Yup, it happens usually.
If the tags are correct, just do this:
Mouse right click in ELP painel --> sort --> present default
And all list will be reorganized!
Thanks for the great UI. I haven't visit HA for a while and this is my second plugin from you ever since Curacao.
I do have a problem here. How to rescale the background image to, say 110% zoom in instead of the current one which zoom in by large scale. I would like to see the entire album though. Maybe 110-130%.
BTW, is it possible to add a banner for .m4a?
please I need help to see all my covers..it´s possible to assign multiples values for coverart filename in foo_exvar?or another way?if not I´d have to rename about 1200 image files!
I´d like to solve this problem because I love this skin!!
thanks
thanks
I set it like this and it works like a charm
(http://www.imagesforme.com/out.php/i471605_59.jpg)
thanks but not working for me..my covers are not in a separated directory.they are with the music files ,with diferent names (front,cover and .jpg or .jpeg ext).It worked for me in columns ui NGPlaylist perfectly but not in Kameleon..
any solutions?..
thanks
any solutions?..
thanks
I just went through renaming all of my album art, and it is a pain in the butt, but I have not seen another way to do it.
all cover art filenames must be the same, as folder.jpg, OR cover.jpg ....
not really a pain to do if you make or get a vbs script (or another tool) that will perform a batch rename quickly
Yeah, I named them all %artist% - %album% - cover.jpg. If there is a script for that, that would be great, although I am not sure there is one.
ok.I´ve solved with a rename script.thanks
any solutions?..
thanks
I just have it set to *.jpg in extended variables.
It works well enough =S
Only problematic when the folder has multiple images, it just chooses the first one I think.
Would be nice if I could script it to look for cover/folder.jpg/png first, and then move onto *.jpg/.png
any solutions?..
thanks
Ugh, now you tell me
Thanks, I changed my tags slightly, resorted the playlist and now it works. GREAT
yes there is ...
[a href="http://xs138.xs.to/xs138/09154/bio620.jpg" target="_blank"] ? i really want bio-thing in my foobar but i don't know how :-/
thanks
I'm still using Curacao (I know it, I know it, but I still haven't found time) but there's an easy way to replace an existing "tab" in the left panel.
With rightclick-->settings in the left panel you can change the name to eg. "BIO" in the script and modify the commands (have a look at it, you will see what I mean).
With Preferences-->Columns UI-->Layout you can replace the existing Plugin (Track Info Mod I think) with the Bio-Plug. Have a look at the parent Panel Stack Splitter Settings also ('-> INF' panel).
A good way for learning a little bit modifying is to backup your fb2k configuration, reading the scripts in the settings, reading threads for examples and trying it for yourself. First, with Ibiza I wasn't able to modify anything (Br3tt knows what I mean ), and now I can add some simple additional buttons and panels.
Edit: typo
Hello,
I've tried this excellent mod, but i've a few requests:
(http://www.freeimagehosting.net/uploads/th.34c76a3151.jpg) (http://www.freeimagehosting.net/image.php?34c76a3151.jpg)
Can someone explain me how and where i can choose :
- To have only these two panels on start up
- To disable the big cover in background on start up
- To display the "artist - album" under the cover on the right planel
- to adjust the transparancy of the plastic cover aspect
- To adjust the size of the command button (play stop forward ...)
Thank you very much
Re hello,
Another question:
Is it possible for foobar to display "various artist" with a syntax, when it detect many artists from a compilation ?
By default foobar display the artist of the first track of the comilation
the albumlist plugin for winamp does it perfectly, i hope foobar needn't a tag (albumartist) for that !
Thx
I've a problem with the chronflow.
I've organized my coverart like this:
d:/%artist%/cd cover/%album%.jpg
I've set the extended variables in order to display the cover in the right panel and in the jewel case on the left.
I've copied from the Br3tt's guide this setting for chronflow:
but in the chronflow I still see the nocover.jpg, instead of the cd/s coverart.
Where's my fault?
hi.one question,it´s possible to see the graphical browser(the little cd boxes) in transparent mode?
thanks.love this skin!
no, graphical browser do not support transparency. a shame.
I´d like to make a button in art pannel to burn the audio CD.I´ve tried with COMMAND:Convert Write audio cd.. with no results.With CONTEXT only burn the now playing track..what code should I put in the script?
thanks!
Thanks Falstaff for this wonderful foobar configuration
I’s really perfect for managing a large library of music ! I like it very much !
I have some clarification in this regard :
What setting is changed in Foo_Exvar by the variable : kameleon_disable_path_info
In the left panel "STAT", the statistics wasn't displayed, but they are present in the "INFO" panel. Is it good ?
In the "ELPlaylist" : the popup linked with %comment% does not appear when I move the mouse over it ? Yet my tags are correct !
In the right Graphical Browsers the popup appear perfectly
Thank you for taking your valuable time to help me to solve its small annoyances.
Sorry for my very bad English
Un très grand merci pour ce travail de titan...
Quick question:
Is it possible to display tracks by rating?
Quick question:
of course, just sort by rating !!!
(use sort menu from toolbars or create a sort preset in ELP settings panel (misc. tab)
Hi
at the moment the alphabet below the album art selecter only displays letter of artists in my now playing list.
i normally just use the album selector to pick an album and listen to that so my playlist will often only have one artist in and therefore only display one letter bellow.
if this is the normal way for it to work, i was wondering if its possible to make it so the whole alphabet is displayed, (abc...xyz) and then i could just click on the letter and it would move the album selector to that letter in the library.
i hope this sums up what i mean if not just say and ill try and explain it better. Also i tried to find this in preferences but couldn't see it anywhere.
thankyou
Collins5
In the left panel "STAT", the statistics are not displayed, but they are present in the "INFO" panel. Is it good ?
In the "ELPlaylist" : the popup linked with %comment% does not appear when I move the mouse over it ? Yet my tags are correct ! SOLVED
To display Popups in ELPlaylist on Track mouseover if %comment% exists (display the comment in the popup) :
Right click in the "ELPlaylist", then choose "Settings ..." and select "enable hover" in the tab "behaviour"...see below...
In the left panel "STAT", the statistics are still not displayed, but unlike the tutorial I did not the window "Play Counter" and the window "Playback Statistics Custom" in foobar - Preferences ! Somebody knows why?
somebody already asked, but nobody replied..
Is there a way to make this great, great config to show embedded covers?!? I suppose it's ut to components used, because otherwise it doesn't make sense that not to be inculded. but im really not so well educated in foobar, so if anyone can help, that would be great.
once again, i love everything else about this config, great job!
Great configuration, many thanks
keep updating,please
i like kameleon more than xchange
i haven't enough time to keep up to date all my old configs, but if you paid for that, i could reconsider this point
hey guys,
i have some kinda weird problem after updating to 1.2.2
http://chidoofi.ch.ohost.de/img2/playback_oO.jpg (http://chidoofi.ch.ohost.de/img2/playback_oO.jpg)
what is that? o_O
Thanks for this great layout...
But i got a little but annoying problem. It seems, like I cant get the Library Viewer Playlist to work with Album List Panel, same for Quicksearch. Both always create new playlists instead of overwriting the old ones so that e.g. for every click in the Album List Panel you have to delete a playlist.
I tried everything in the panels' options but can't figure it out.
Any help would be really apreciated
Hi folks,
yesterday i must reinstall my foobar. I added all my components to the components-folder also the "foo_playcount.dll". I restarted foobar, but in the tool-section i can't find the playcounter.
Here's a picture:
[a href="http://s1b.directupload.net/file/d/1816/3xmkhefj_png.htm" target="_blank"]
What can i do, to resolve the problem?
Please help...thx
I dont think that its supposed to show up in the tools section.
At least it doesnt in my install either and its working fine for me.
It's in the Advanced Section: Advanced > Tools > Playback Statistics
Ok, i found it. Thanks bubi.
hi
i have a problem during the instalation of kameleon 1.1a, thing is, although i followed instructions from brett's site, after the importing .fcl none of the icons, such as basic - play, stop... in lower left corner or the volume button in lower right...are not shown. this is the problem that occured every time after i re-formatted my pc. i tried several times - result was always the same. i copied the all the kameleon components into the main components folder, fonts in the c/windows/fonts...still no result. before the format everything worked perfectly....please, tell me what is the problem and how i will fix it. tnx in adv.
p.s. o.s. is xp, sp3
Hello!
My first message!!
Excuse me for my bad english
I have the problem....
http://img31.imageshack.us/img31/8486/clipboard01nfa.jpg (http://img31.imageshack.us/img31/8486/clipboard01nfa.jpg)
the descrition not entire.
Help me with the image, please
Bye!!
@andreatop76
You don't have all the required fonts. Look here http://br3tt.online.fr/html/K/index.htm (http://br3tt.online.fr/html/K/index.htm)
Near the top you will see:
Download just the required fonts used in Kameleon in a single archive (included in the main archive above)
Download it, that should fix your problem.
@andreatop76
Perfect!!!
Thanks!!!
Try this:
Now I did this!
I want to do this using comment tag, and I did. However, how can I have the comment contents be displayed in the same style as the artist contents (the grayed out color, not the dependence on a difference between another tag)
Actually I'd also like to display it in subscript too.
How i can get that box away?
(http://img38.imageshack.us/img38/4527/foobarh.th.jpg) (http://img38.imageshack.us/i/foobarh.jpg/)
You can hide the panel.
Right-Click on the right side -> Splitter Settings... -> go to "Quick Search" and mark "hide panel on startup".
Excuse me (for my bad english)
for fast change wallpaper? (when withuot "artist.jpg" in folder)
is there a way to group all albums from same artist together so there is only one entry per artist and upon expanding shows the full list of albums.until then it will remain for me kameleons' one weakness.i love it to death but scrolling through ever album to get to the next artist gets old.kameleon is very cool indeed and i will continue to use it.very very nice work
Yeah i know that but i want that hole box away not only quick search
just a question about the scobbler itself,each track must be played all the way through before its summited?both personal or radio?i think last time i used it you would see a progress bar accross the top for the "scobble" but now im not seeing that.i use Kameleon 1.22 with foobar 9.6.8.
Excuse me (for my bad english, ever ),
for to disabilitation (momentary) change wallpaper with picture "artist.jpg"?
Best config ever!
Thanks Br3tt.
I have this problem:
(http://i28.tinypic.com/1zvc3lc.jpg)
Dunno how to fix it.
And I get this error:
Windows Script Control not installed. Download it from <http://www.microsoft.com/downloads/details.aspx?FamilyId=D7E31492-2595-49E6-8C02-1426FEC693AC>.
I donwload it and install, but still the same. I'm on 322bit windows 7 btw.
When I click on any of the menu options in the Kameleon Skin - File, Playlist, View, Library or Info the menu expands but I am unable to close (collapse). Anyone know how?
Thanks, Martin
I don't use them, but have you tried treating these as toggles and click again.
terry
terry
That did not work - so I have re-installed everything and now it works. Thanks
This seems to have been asked a few times in the past, but I too am curious:
Is there anyway of getting embedded artwork to show?
If not, what's the quickest way to source the art through Foobar that works?
Where would I be able to change the size of the background art that changes with each album?
check post #364 : http://www.hydrogenaudio.org/forums/index....st&p=618377 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=618377)
Thanks Falstaff.
I congratulate you on a very nice skin. In fact I would say you're trailblazing the way media players will work/look in the future. But damn, it's about as user friendly as a rocket science textbook written in Chinese.
Even just using a meaningful naming scheme for all the modules would be a huge help.
For display image of file audio (tag), instead image of folder?
Only left panel...
Excuse me for my bad english.
Hi, new here, so thanks in advance for any reply.
First, great theme, the focus on album art and the "CD collection" feel is exactly what i've always wanted!
Second, I have the same problem as Andreatop:
Hello!
My first message!!
Bye!!
but the fix that was suggested (installing the font pack) did not work for me.
P.S. using win7 if that makes a difference...
First Id like to say, THIS ROCKS! It destroys Ibiza. Second I have some questions.
1) I have the Playback Statistics Custom tab under tools, but not the Playback Counter. I dont want it to change files because FLAC it would mess up since tags affect some cue files. So I have everything else working, but not that? Thanks
2) For the icon next to the google searches that is a pie, how would I switch it to search artist on a torrent site such as what.cd? Also what would I need to do to make an icon that size that would fit and blend in perfectly? Thanks
Hello,
when I load a collection divided into 2 cd I have this problem:
(http://img32.imageshack.us/img32/3464/fbbe.th.jpg) (http://img32.imageshack.us/i/fbbe.jpg/)
the songs from the first CD and second CD is mixed
If I choose the album to listen right from the right toolbar (the one that I renamed 1) foobar puts the songs in order .... but if I select an album to listen to the chronflow (renamed 2) foobar puts the songs in disarray .
(http://img25.imageshack.us/img25/7149/fdgum.th.jpg) (http://img25.imageshack.us/i/fdgum.jpg/)
I´m using kameleon and i cannot see the covers.
The covers path is
C:\Program Files\foobar2000\Covers
The cover have artist and album like
I´ve tryed everything in extended variables and i can´t see the covers
Can anyone help
The covers path is
Can anyone help
all is explained here : http://br3tt.free.fr/html/K/index.htm (http://br3tt.free.fr/html/K/index.htm)
check chapter C/
great config , but it's possible to replace the lyric show panel with the newer bugfixed version (foo_uie_lyrics2 (http://www.hydrogenaudio.org/forums/index.php?showtopic=76968))?
Still my favourite!!
Can anyone tell me, where I can find the code to modify the top menu (picture)?
I searched around, but couldn't find the code.
(http://img705.imageshack.us/img705/1237/footopmenu.jpg)
The code that positions the menus (_M1 to _M5) can be found by right clicking in your indicated area and selecting Splitter settings. The code is in the PerTrack section. Select the individual panels (_M1 to _M5) therein to configure them.
Ah there it is. Thanks a lot.
Could someone upload the installation manual for Kameleon? I lost it and it's no longer on Br3tt's website.
I like Kameleon better then Xchange for many reasons (nice playlist switch button, path show, no hangs etc. Therefore I would like to install it back.
Thanks in advance!
Thanks in advance!
All installations files and manual (file: Kameleon_1.2.2_manual.pdf) you can find under this url: Kameleon by br3tt (http://br3tt.online.fr/files/K/)
hi firstly id like to say a big thank you to Br3tt for kameleon
ive moddified mine a fair bit now but was wondering how to add more buttons to the top right corner (google artist, google album etc)
is it just a case of changing the code in settings?
also i seem to be missing the font in options and come up with a lot of squares where i think there should be letters
and does anyone know which component it is that manges these buttons?
thank
Collins
Hi I recently found this thread and I'm new to foobar2000.
I've seen how the UI looks in this Kameleon from the screenshots and I really do like how it looks.
I think Br3tt has done a very excellent job in creating this and I can't wait to try it out.
I was reading the documentation and it mentions that it is for earlier versions of the foobar2000.
My question is this, will this still work as described without breaking anything on the latest stable foobar2000?
I thought I would ask before I went for installation. More than likely I will just try it and see what happens, but if someone could also answer this I would appreciate that. Thanks in Advance and job very well done Br3tt.
--- GRebel
--- GRebel
Mine works fine on the latest update off foobar, i cant remeber exactly what i had to do but i think it was just a case of updating the components.
I need some help in setting the artist image directory. I completely forgot how to do that. I have been using this forever now and did not change it in recent year or so. With the new computer, I have to redo the setting and I just can't remember what I had to do. Can someone help please?
Fixed that issue. But, with new foobar foobar2000 v1.0.2.1 I can't get Lyrics show panel to work anymore. I also tried uie_lyrics2 but in vain. Can anyone please help?
Kameleon is not made for v1.0, you should switch to a configuration that's adapted to work well with v1.0. I could suggest the latest version of Xchange3 by Br3tt, it's a bit similar to Kameleon.
sorry i still havent manged to find out how to add button additional buttons in kameleon
im trying to add a button to here
(http://i10.photobucket.com/albums/a109/Collins5/kameleonbuttons.jpg)
which im fairly sure is possible as the number of buttons went from 3 to 5 in an earlier update of kameleon.
now i have a feeling these buttons are manged by wsh pannel mod
but can not find out how to edit them unless its done through
(http://i10.photobucket.com/albums/a109/Collins5/buttonscode.jpg)
but i dont know how to edit this to add aditional buttons
if anyone could point me in the right direction it would be greatly appreciated
Collins
Try right clicking on one of the buttons to take you to the correct place. They appear to be in a TrackInfo Mod panel. If right clicking fails, try to locate the panel in the columns ui layout tab. To add a button try copying a preexisting $button line, paste it in the //PerTrack section and change the x value (the first number in the line) and the image paths to the new images. You may need to ensure that the panel is being drawn wide enough to accommodate an additonal button.
Hi there,
I've installed foobar 1.1 beta 1 and now the volume button in Kameleon has disappeared, presumably because of the changed components folder. How would I have to change this code to make it work again?
// Knob button by Br3tt
// Modified by T.P Wang
// foobar path, SHOULD be replaced
var g_btn_img1 = gdi.Image(fb.ComponentPath.replace("components","images") + "kameleon/bg/volbutton31e.png");
try
var g_btn_img1 = gdi.Image(fb.FoobarPath + "images\\kameleon\\bg\\volbutton31e.png");
try
Thank you for your help, marc2003! Unfortunately, that doesn't seem to work, either.
I've also tried
var g_btn_img1 = gdi.Image(fb.FoobarPath + "\\images\\kameleon\\bg\\volbutton31e.png");
but to no avail.
Maybe the problem is not only the path, but also that interface.api and jscript.api maybe "orphaned" in the main component directory after moving all user components. In WSH Panel Mod settings they are set as
api.vbscript = $(dir.component)interface.api
api.jscript = $(dir.component)jscript.api;$(dir.component)interface.api
On a side note, the image code uses GDI+, which under Windows 7 is not natively supported anymore (http://www.windows7taskforce.com/view/3607) and thus slow. Maybe it could be replaced with something that uses Direct2D or WPF?
I use Kameleon and have for quite a while now. I Kameleon and I don't want to switch so:
Will Kameleon work with the new 1.x versions?
I hope so!!!
Thanks,
rocket
Would be best to ask author via his website or via deviant art.
terry
For me Kameleon works fine with foobar v1.1.
hello ecery one, i just install fubar2k and Kameleon here is screen shot please help me solve some issue
1- i only see one album on rightside of colum
2- there is question mark in front of track number
please help
See post #702
This is the correct thread, however I do believe, based on author's comments, you will get better response directly from his site.
Hey,
I solved the Problem with the diespeared Volume Button in this way:
var g_path = fb.TitleFormat("%foobar_path").eval();
var g_btn_img1 = gdi.Image(g_path + "skins/kameleon/images/bg/volbutton31e.png");
var g_btn_img2 = gdi.Image(g_path + "skins/kameleon/images/bt/voldot.png");
var g_btn_img3 = gdi.Image(g_path + "skins/kameleon/images/bt/voldot.png");
var g_btn_img4 = gdi.Image(g_path + "skins/kameleon/images/bt/voldot.png");
var g_btn_img5 = gdi.Image(g_path + "skins/kameleon/images/bt/voldot.png");
Hope this helps others.
I still use Kameleon most of the time, besides testing some other skins.
Show the rating is broken for me. I can set the rating and it´s shown on the properties, but not shown on the panel.
Anyone an idea how to fix it?
I solved that by replacing %rating% with $meta(rating).
Is there any chance to make front and back covers to appear in full size scale, or @least to be anlarged..?
Ive tried many trics but in vain..
Hi!
I ha ve the problem for statistics . Don't it dawns.
(http://img214.imageshack.us/img214/1861/clipboard01gro.jpg) (http://imageshack.us/photo/my-images/214/clipboard01gro.jpg/)
Why?
Excuse me for my bad English
I use and love this for many years now, thx for this nice peace of work.
But now I have a little problem. I just want to replace the lyrics show panel with the newer v3 one (foo_uie_lyrics3). Unfortunately I didn´t know how.
It´s a lot of time gone, since I customized "my" Kameleon with my wishes. Too much time I´m afraid.
I forgot almost all about how it goes.
I hope this isn't to difficult and someone could help.
I´ve got it. It was easier than I thought.
Hello... The link to instructions and faq no longer works... Can someone point me in the right direction... Thanks.
Here is the latest one I got:
http://s000.tinyupload.com/index.php?file_id=09023245214864236930
But it was made for an older version of foobar2000, v0.9, so I'm not sure it still works with current version.
Here is the source but it hasn't been updated in a while
http://br3tt.deviantart.com/art/Kameleon-v1-2-2-112901532
I have been using Kameleon for TEN YEARS. I don't need to say that I love it. Kameleon honours its name. Kameleon + good sharp HD art looks gorgeous. For this reason, I have kept using it all these years. I don't think about finding other 'skin'/config., I think about finding HD art for my music collection. Many thanks br3tt, for sharing your excellent work.
