Topic: foobar2000 v1.0.1 beta 1 (Read 12585 times) previous topic - next topic
foobar2000 v1.0.1 beta 1 has been released.
This is a maintenance update addressing various issues found in the 1.0 release as well as adding minor new features.
Download...
List of changes:
  • Undecodable tracks now get substituted with 1s of silence to prevent deadlocks with dodgy third-party components.
  • Worked-around bug in Windows 7 with status bar repaint glitches.
  • Windows Media streaming compatibility improvements.
  • Fixed notification area icon being incorrectly shown in certain conditions.
  • Audio format support updates: added support for decoding Wave64 and RF64 formats, added built-in support for writing Wave64 format.
  • Added folder name wildcard matching for album art search.
  • Added a workaround for horribly broken Asus Xonar drivers.
Read full change log...
Thanks for the update!  I was a little worried that after the 1.0 milestone was reached, development would slow down.  I'm relieved to see that this is not the case.
What's wrong with xonars? The playback problem when GX is enabled (i think i've read it somewhere) or something else?
Thank you for the update Peter.
Is it possible to present a buffering progress bar reading a streaming media and a prompt message when the streaming media is dead? Thank you.
I can breath again
Many thanks for this minor but precious modification!
Amazing, amazing  software I just started using. Installed the new beta and it seemed to require a lot more memory than 1.0. Or is it just my machine?
Describe "a lot more memory".
What OS?
Vista and Win7 don't idiotically swap out a programs memory to the page file when minimizing like XP does.
elevatorladylevitateme
What OS?
Yep, XP Home sp3 is what I am running. I will try it on the laptop to see what happens there, but it is running XP also (Professional).
Installed 1.01 beta on a laptop running XP Professional. As I expected, same result. It seems that the beta version uses the same ~16 meg of ram whether minimized or not. I have the spectrum visualization running, so I believe the memory usage should drop when fb2k is minimized. It does with 1.0. Not that familiar with the program yet though.
I am experiencing memory problems as well. After checking and unchecking various options and temporarily disabling almost all of my components, it seems, that beta1 foo_ui_std.dll is not releasing memory when minimized to the notification area on Win XP SP3. Copying over the 1.0 final foo_ui_std.dll fixes the problem.
It's just the working set. Changing working set means that real "memory usage" stays the same, only some parts of it are paged out to disk.
Forcefully trimming the working set is unnecessary, the system will page out memory which hasn't been touched for a long time itself anyway, but even better, only when needed.
So I can see the difference between 1.0 and 1.0.1 here, but I don't see anything wrong with it performance wise.
Me neither, so 'problem' might has been the wrong expression. Just pointed it out, since it was not mentioned in the changelog but has changed from the previous version.
edit: Just out of curiosity. Is it not incosistent, if the behaviour for minimize and minimize to notification area is different?
Yeah, that's just because "standard minimize" is system behavior, while "minimize to SNA" is a hack, intercepting the original minimize command and hiding the window instead. Also there is no difference there on Vista & Windows 7 at all.
Goes to show you how often relative paths are used...
My relative paths work fine. I just don't care about playback statistics.
I just re-read this. I did not realize there was much difference between standard minimize and minimizing to the notification area. I had FB2k set to minimize to the notification area for 1.0 and 1.01 beta when I checked the memory usage previously.
That's like saying you have a memory leak problem that causes a BSOD, but because you aren't doing anything, you say there's no problem...
No, that's not like it at all. It's saying that there is a problem that can lead to data loss, but it does not affect a certain (large?) group of users. So if you don't use both features in combination, you don't have to worry about it. If you do, you'll have to hope that Peter includes a fix in the next version (and not later).
Works great on Xonar now! Thanks ever so much!
