Topic: Theme export should honor dark mode setting (Read 758 times) previous topic - next topic
i have been working on a theme for default UI using design sensibilities to match dark mode as there is really no good default set up option to go with dark Mode
anyway after exporting and re importing  my custom settings  i discovered  that everything was set correctly in settings but i still had to switch on dark mode in display settings for it to look correct So I think this selection should be saved when creating the file as is everything else?
