Topic: Dolby Headphone Wrapper DSP (Read 337916 times) previous topic - next topic
Re: Dolby Headphone Wrapper DSP
Reply #227
Click the "32-bit" link on the download site:
Reply #228
Is there going to be a version of this plugin for 64-bit foobar2000? I'm planning on switching to 64-bit after v2.0 final comes out. My concern is that this might not be possible since the required Dolby Headphone dll is 32-bit... I don't know much about coding, but is it possible for such a thing to work? Thank you.
Reply #229
If the plugin conversion never happens, you can try a different effect combination out right now to see if that would be a suitable substitute.  For example, the built-in "Upmix to 5.1" DSP into the now-free jb_isone_pro_surround.dll VST (https://plugins4free.com/plugin/2069/).  The latter is 32-bit but the Foobar VST adapter will handle either/or on the Foobar v2 in use.  I have used the Dolby wrapper and found it pretty inflexible compared to this alternative.
Reply #230
I don't really use Dolby Headphone all the time - I have a different crossfeed I like for most music. But sometimes I like the sound of Dolby Headphone specifically, like when I listen to the music from Deus Ex or some other things. Having Dolby Headphone on the 64-bit version would just be really nice, even if there are alternatives that are technically better.
Reply #232
Dolby Headphone is the best 3D DSP for diffuse field calibrated headphones (like Sennheiser HD600, HD650, Etymotic) for neutral sound imo. Dolby Atmos is awful on diffuse field calibrated headphones.
Reply #233
In the event that a 64 bit version of this were made, is there even a 64 bit dolby headphone dll that it could work with?
Reply #234
For 5.1 audio files, the Dolby Headphone Wrapper does not accept SL SR for the surround channels.
The FB2K console prints a message that the plugin cannot process audio beyond 5.1 channels.
AC3/DTS 5.1 will not work with Dolby Headphone Wrapper, unless you remap SL SR to BL BR with matrix mixer.
The VU meter should show only 2 output channels when the plugin is working properly.
