Topic: Ogg Vorbis acceleration project (Read 195458 times) previous topic - next topic
Reply #151
Anyone that can give some guidance on how to compile this under Linux (Ubuntu)? Regards.
Reply #152
A few more statistics, transcoding 01:42:28 h of a 5.1 AC3 on a Phenom-II X4 945 using BeSweet with DPL-II downmix and fixed gain (to avoid including the normalization pass):
Generic
06:42 (686)
06:04 (P4)
Lancer
04:30 (SSE)
03:51 (SSE2)
03:50 (SSE3)
The gap between generic and extreme optimization is quite impressive. And even the gap between SSE and SSE2 is still remarkable. But after all, decoding and downmixing takes its time too, so a certain degree of saturation is expectable.
Reply #153
@john33, any interest in also posting the cli encoder binary at Rarewares?
Done.
Thanks but unfortunately, and unlike your previous builds, it's not running anymore on older OSes pre-XP SP2 on which VC2010 runtimes can't be installed
But this might be helpfull: http://mulder.googlecode.com/svn/trunk/Uti...rLib/README.txt
Reply #154
There are reasons why such old OS are deprecated. An excuse would be running them offline.
Reply #155
OK, what optimisation does your CPU support?
Reply #156
It's rather a question of PE-building and linking than of CPU optimizations, john33. Not the CPU is the limit, but the OS and its set of supported Windows API functions.
Reply #158
Done.
Hi, John. But what is the difference between your new compiles and this?
I don't remember where I got it, but it was more than one year ago and actually this is also OggEnc v2.87 LancerMod(SSE3) based on aoTuV b6.03 [20110424]. Could you clarify?
🇺🇦 Glory to Ukraine!
Reply #159
MMX, SSE, SSE2, SSE3, SSSE3 and I'm usually using your P4 optimized builds.
Thank you
Try this: http://www.rarewares.org/files/ogg/oggenc2...cerSSE2_OLD.zip
and perhaps you could let me know if it's OK?
Reply #160
Done.
I couldn't say with any certainty, but probably the only difference from looking at the size of the executables is that I don't think they were compiled with the libsamplerate resampler.
Reply #161
Brilliant! Works like a charm, thanks a lot
G:\Test\>oggenc2 -h
OggEnc v2.87 (LancerMod(SSE2) based on aoTuV b6.03 [20110424])
(c) 2000-2005 Michael Smith <msmith@xiph.org>
& portions by John Edwards <john.edwards33@ntlworld.com>
Reply #162
My versions of oggenc2.exe doesn't include SRC and FLAC libraries and I commented out all relevant options and calls.
@john33: in your compiles these options are disabled too    I think it's not what you want, and 3 source files with re-enabled options are attached to the post.
Reply #163
Some tests (out of interest) on my PC reveal that john33's current binaries are slightly but noticably faster than these in your link, in the very least.
Reply #164
Thanks, but the versions at Rarewares have these enabled.
EDIT: I just realised that the options were disabled in the oggenc2 code!  I had enabled the inclusion of the libs in the compiles and hadn't checked the code!
Reply #165
All of the above oggenc2 compiles have been updated at Rarewares. Sorry for the confusion!
Reply #166
Great work, thanks a lot.
Although the version by lvqcl is still faster on my machine. I use oggenc2 32bit sse3 from [a href='index.php?act=findpost&pid=784966']here[/a] and foobar converts a flac around 49x while your compile is at 42x.
Reply #167
Your machine. Aha.
We all know your machine.
Oh, no, this is your first post, so how could we?
Hint: http://hwinfo.com/
Reply #168
It's a core2duo laptop with a P8600+ 4gb ram on win7.
Reply #169
Try LancerSSE2_OLD build. It is faster than other versions (except x64).
Reply #170
With johns lancer sse2 old i get the same speed like using your sse3 version.
Reply #171
Out of curiosity i tested all 32bit oggenc2 compiles again and here are the results:
John33:
sse  35.69x
sse2 38.40x
sse3 38.60x
sse2old 47.19x
lvqcl:
sse  38.80x
sse2 47.94x
sse3 47.73x
I'm not familiar with compiling, so i wonder why there is such a huge step in speed from sse to sse2 while sse2 and sse3 are on the same level?
Reply #172
This effect doesn't belong to the "Compiling" as such (the C compiler only translates the source routines which are not very CPU optimized; the in-depth CPU instruction set optimization is more efficiently done via manual Assembler code).
The efficiency boost between different instruction sets depends on the algorithm to be optimized and the differences between the instruction sets. So specifically for the Vorbis encoding, SSE2 seems to introduce very useful new instructions (relative to SSE only), but the new instructions in SSE3 (relatively to SSE2 only) are only marginal for the Vorbis algorithms.
Reply #173
Thanks for clarifying.
Is it the reason there is no sse4 compile, because it introduces too little useful instructions compared to sse3 as well?
Reply #174
I was under the impression the reason is more along the lines of SSE4* being an umbrella term for a clustermess of very different instruction sets some of which only work on newish Intel CPUs and others only on newish AMD CPUs and all of which only can be effectively optimized for on pretty new and specific compilers.
