Topic: Playlist Organizer (aka foo_plorg) replacement on Jscript Panel 3 (Read 54148 times) previous topic - next topic
Re: Playlist Organizer (aka foo_plorg) replacement on Jscript Panel 3
Reply #376
Hi @etip,
I've seen you have solved my request No. 2 from my post #350.  Thank you!!
Best  Saitenschwinger
Reply #377
Hello. Great job Sir. This is a must-have plugin for me. Especially since you worked out more levels of folders.
Is there a way to configure what happen when track is dragged and dropped to a playlist on tree? For me my active playlist is changing to the destination playlist (the one I copied track to), while I would want have been on a source playlist (the one I copied file from). I couldn't find a setting to define this behavious, although in JScript Panel I saw a on_drag_drop function - so I assume it could be already developed. Is that so? If not, please consider this as an idea for the future.
Reply #379
yes, i'll post an update later, the .ToSelect property is indeed set to true.
Reply #380
or you can set this property to true in line 511. Next version will be modified as well.
Reply #381
Does v2.0.8 not need "panel_pl_organizer.js"? Because I don't see it in the zip file.
Reply #382
@white_magic
What does it mean?
When you unzip pl_organizer2.0.8.zip, it is there properly.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #383
I have been lurking on this forum for ages and gleaned tonnes of useful information from it - but finally registered to say THANK YOU @etip for this excellent plugin. I have a few comments but will leave them a couple of days to let me fully explore/test as it's the first time I've used JScript. Thanks once again.
Reply #384
In order to stop changing the Playlist View, should it be changed to false on line 502 as well? Seems to work but I'm not sure if that is going to break something else at the same time...
Reply #385
Hi @ed.j ,
Line 502 is about when you create a playlist from a drag&drop (you drop into an empty area). It was an earlier request. You can set to 'false' if you dont want the plugin to switch to that newly created playlist (it will not impact anything else).
Reply #386
Hi @ed.j ,
Awesome thank you.
Reply #387
Hi. Thanks for help with my last question - I successfully configured drag and drop.
Although I have notice some bug. For big playlist there is a wrong number of tracks shown in tree in a weird way.
Playlist with 6022 elements appears in tree as 61022, playlist with 19717 is shown as 191717. Also folder of playlist with sum of 1243 tracks is shown as folder of 11243 tracks.
Reply #388
See Bardware's post at the below link and etip's reply.
https://hydrogenaud.io/index.php/topic,123820.msg1034615.html#msg1034615
Does etip's reply help?
Reply #389
Yes indeed. Problem solved. Thanks.
Reply #390
Is it just me or has anyone else noticed the vertical centering of text in the selection bar is off?
The first image is from the playlist jscript panel
The second image is from the default playlist view
So it looks like the playlist view (and Windows) vertically centers text based on the uppercase height of a font, where the baseline is always the bottom of an uppercase font. However, it looks like the plorg Jscript takes into account the top height of the font and tail of a lowercase font, which makes it look off center.
Is it possible to fix this to be like the second image?
Reply #391
hi! after installing windows 11 (sigh...) i am now faced with the following error when i try to play a song:
JScript Panel 3.3.29 (Playlist Organizer v2.0.8 date 11/11/2023 by Seb + inspiration and abstracts from marc2003 + great help from metal_termite.)
JavaScript runtime error
Invalid procedure call or argument
File: G:\foobar2000 x64\profile\pl_organizer\pl_organizer.js
Line: 153, Col: 29
any idea what might be causing this?
EDIT: i looked at the line in question and tried some stuff and seem to have fixed it: i think maybe the actively playing color setting/icon had become un-set?
Reply #392
I've looked through this thread but I can't find simple installation instructions anywhere.
Can someone tell me where to put the 4 js files?  In which folders specifically within AppData\Roaming\foobar2000-v2?
(and yes, I do already have JSP3 installed)
Reply #393
^ Make a new folder "pl_organizer" and extract files there. Add JSP3 panel to layout and click to open editor, Tools > Import button, find "pl_organizer" folder, (possibly need to change filter to "All files (*.*)" to see .js files) and import "main.js".
Reply #394
i install version  2.0.8 . and error :
'_pl_organizer' is undefined
File: <main>
Line: 14, Col: 1
PS: i open the main.js in JP3 .
Reply #395
File: <main>
Line: 14, Col: 1
The zip contains 3 files :
main.js file which is the main panel script
pl_organizer.js which is the main code
The last 2 files are to be copied in the fb.ProfilePath + "\pl_organizer" folder
X
You need to create a JScript 3 panel, its code has to be the main.js file (copy/paste).
Jscript Panel 3 link : https://jscript-panel.github.io/docs/
Reply #396
Thank you!!
Reply #397
I was getting the same error, but just realized the mistake I made was leaving the folder titled pl_organizer2.0.8, instead of changing it to just pl_organizer.
File: <main>
Line: 14, Col: 1
Reply #398
File: <main>
Line: 14, Col: 1
Thanks you work ....
Reply #399
Feature request:
Would love to see a "revive dead items in playlist" function.  Really valuable when moving files around to different directories/drives.  And there doesn't seem to be option for this in yet in x64 Foobar v2.
(If I'm wrong and it exists, let me know.)
