Topic: foo_queuecontents - View and edit queue (Read 158378 times) previous topic - next topic
Re: foo_queuecontents - View and edit queue
Reply #275
So, foo_queuecontents for 32-bit and foo_queue_viewer for 64? That's good.
(But if the former has source available and the author's blessing, would it be possible to just compile it for 64-bit fb2k?)
Reply #276
Seems like that is the case. My only problem with foo_queuecontents is lack of dark mode.
Think millionaire, but with cannons.
Reply #277
64bit should be easy enough with the original code but I was put off touching it because it uses custom list control code which I have no idea how to style for dark mode. I'm only familiar with using the list controls included in the fb2k SDK which make it a doddle. The playback queue update/display was a nothing burger to rewrite. It's only a few lines of code. The only real challenge for me was supporting UI colours/fonts which took me awhile to figure out,
Reply #278
64bit should be easy enough with the original code but I was put off touching it because it uses custom list control code which I have no idea how to style for dark mode. I'm only familiar with using the list controls included in the fb2k SDK which make it a doddle. The playback queue update/display was a nothing burger to rewrite. It's only a few lines of code. The only real challenge for me was supporting custom colours/fonts which took me awhile to figure out,
The contents inside the queue list follow the colors I set in ColumnsUI. Only the scrollbar is a problem for me, although the column labels and options screen also don't use dark mode. Here's a screenshot with my problem in the lower right.
https://hydrogenaud.io/index.php?action=dlattach;topic=123942.0;attach=25186;image
Reply #280
You sure do like repeating yourself. If you've had recent head trauma, you should get it checked out.
My apologies. I do have some cognitive problems from medicine right now. My intent was to affirm that the contents don't seem to be a problem for dark mode, only the interface elements. It looked to me like you were saying the contents colors were a problem, but I may have misunderstood.
I appreciate your work on this.
Reply #283
Was there ever a 64-bit port made of this? I don't even care about the cosmetic problems with dark mode much anymore. Mostly I just want the utility this gives in 64-bit, particularly the way you can view the Playback Queue as its own playlist. It's sadly not possible for me to learn how to code right now.
Reply #284
There is a 64-bit port available.
I was looking for v0.5.2.1, it turned out I forgot I was running my own build.
New name and preferences... in that respect is sort of a new component.
Dark mode is not ready, though.
Queue Editor v1.0
Reply #285
Hi. @da yuyu
I downloaded "foo_queue_editor.fb2k-component" from this page. But I can't install it.
https://github.com/ghDaYuYu/foo_queue_editor/tree/master/Release
Information:
Could not load component "foo_queue_editor.fb2k-component": Unsupported format or corrupted file
It doesn't seem to be an archive.
foobar2000 v2.1 preview 2023-11-09 : 32-bit | 64-bit
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, SONY MDR-1AM2, Bowers & Wilkins P7, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
Reply #286
Queue Editor v1.0
Thank you for sharing the component!
Reply #287
Information:
Hi @Air KEN,
It is working fine here...
Did you use the top-right corner button to download it?
Reply #288
Hi.
Code > Download ZIP > foo_queue_editor-master\Release\foo_queue_editor.fb2k-component
I have already installed it from here.
I asked a question because I was unable to install what I downloaded from this page.
Reply #289
Hello!  :)
The next release, hopefully, will be easier!  :D
Please, click on the second link above, then click the "foo_queue_editor.fb2k-component", a new page is loaded with the top-right download button.
Here is the direct link.
Reply #290
Hi.
Optional requests:
Stop After Queue
Play Next
Keep Queue
Reply #291
My (admittedly abandoned) queue viewer can keep the queue and add items to the front of the queue.
If you like the additonal custom columns this queue editor provides, you can still use the functionality from queue viewer without an instance being present in your layout.
Reply #292
Hi. @marc2k3
hahaha...
Thank you for the useful component (queue viewer).
I thought it would be good for foobar users, not just me, to have a choice.
And I will introduce it to you.
Reply #293
I was thinking of making a proposal for removing the Queue Playlist Feature all together...
Would anybody miss it?
I am sorry, @Air KEN, about the play next.
Is it not what the fb2k playback forward button does?  :-[
Reply #294
Hi. @da yuyu
it's necessary.
This is the function of this component
https://www.foobar2000.org/components/view/foo_play_next
It is convenient for users to have useful functions all in one component.
Reply #295
Hi.
Optional requests:
Stop After Queue
Play Next
Keep Queue
+1 Having the possibility to send things to the queue to the head (without clearing it) or the tail is really useful.
Having the queue in a playlist becomes more useful when you add a playlist manager. For ex. with mine I can directly access to the context menu for the tracks, create clones of the queue as playlist files (for ex. to be used a a now playlist list for streaming) or even Smart Autoplaylists which use the queue as source.
So for me that feature seems pretty useful.
Spoiler (click to show/hide)
Reply #296
@regor
Thank you for your always wonderful script.
Users may want easy and convenient features.
User has been using the queue function for a long time and it also has useful functions.
It would be great if it was all combined into one component.
The same can be said for other components.
User would like foobar2000 v2.x compatible components to be like this.
Reply #297
I like and use Kerpondile's Queue Contents Editor. So I will post my two cents worth:
In regard to the Queue playlist. I find it to be useful too.
As for the Stop after queue feature. I always keep the Stop after queue component activated/selected. I have never needed a toggle or visual indicator to let me know the component's current state. I can't speak for others obviously, but I suspect I am an average/typical user.
As for "keep queue", If I remember there is a component for that but having that built into an editor sounds like a  positive.
Reply #298
@cwb
> As for "keep queue", If I rememberr there is a component for that but having that built into an editor sounds like a  positive.
Already included in "Queue Viewer".
This is convenient.
Queue Viewer
https://hydrogenaud.io/index.php/topic,123942.msg1032506.html#msg1032506
Reply #299
Everybody thinks that.  What's your sample size?
