Topic: Some radio streams fail to play in 2.1 preview (Read 569 times) previous topic - next topic
Hi, I noticed that some radio streams fail to play with an object not found error in 2.1, even though they play correctly in a browser. Example stream (this one worked in 2.0): https://stream.revma.ihrhls.com/zc1145. I'm using preview 2023-11-07 (32-bit).
Re: Some radio streams fail to play in 2.1 preview
This plays for me: https://n30a-e2.revma.ihrhls.com/zc1145?rj-ttl=5&rj-tok=AAABi69HuDAAeuJ6hEYBf3Pjyg
Some streams require a "token" to play, and that token might change oevr time.
(I only have 2.1 right now, the short URL plays in other players)
My URL no longer works, the tokens expire, you need to play the stream in the browser and copy the new token. Maybe a bug/regression will be fixed eventually.
This regressed from attempt to fix another issue (spaces vs HTTP redirects). Will be fixed shortly, thanks for reporting.
Fixed in foobar2000 v2.1 preview 2023-11-09. Thank You.
