Topic: Foobar mobile 1.4.2 preview : replaygain scanner issue (Read 869 times) previous topic - next topic
Hello.
I usually use foobar to add replaygain info in music files tags.
It allows me to use replaygain with other media players. But it seems there is a little issue in the latest preview update:
- replaygain scanner works
- replaygain value are saved in foobar library
- BUT replaygain value can not be saved anymore in media files tags
Different ways to see that value are not saved :
- other media players do not see these value
- tag reading apps ( mediainfo for me ) do not see these value
- if you use the "save to tag" option and after you use the "reload fron tags" option, foobar will tell you that your file needs to be scanned.
Thanks to look at this issue...
Re: Foobar mobile 1.4.2 preview : replaygain scanner issue
Just return to 1.4.1 and the issue is also here...
How do you source the files? Perhaps it's going to be even faster to tag them on a desktop computer.
a fan of AutoEq + Meier Crossfeed
