Topic: can foobar play the rm audio? (Read 6613 times) previous topic - next topic
i want foobar play the rm audio,but i can't find the plugin,  .
i know the rm isn't good at play the audio. but there are some rm audio music.
can somebody make a plugin for rm audio music ?
not likely, since you would have to pay Real a lot of money for the codecs.
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
Actually, this would probably be pretty easy.  Media Player Classic supports Real Media and even Quicktime, through the use of the respective ActiveX controls.  You have to install Real Player in order to get the control, though.
i know mpc . it is not bad.
i hope foobar can play real audio like mpc
i suppose you want it to support DRMed .wmas too?
[span style=\'font-size:8pt;line-height:100%\']"We will restore chaos"-Bush on Iraq[/span]
the wma foobar is already can play.
if it can play the rm audio that would be so good!
I suppose that with proper codecs installed, it would be possible to make a plugin for that (since MPC can do it).
But I am not sure that someone is interested in making it.
Are there similar plugins for Foobar2000 like Tara RealAudio plugin for Winamp? If not, it would be great if someone could write one. I personally loathe anything related to RA but am driven by necessity to access RA material since many archived newsclips and documentaries are in RA format.
Comments?
is such plugin hard to make?
i think many people must be waiting for it for a long time.
Tara is one plugin for Winamp.  Innover's is another.  Both require RealPlayer be installed as it uses Real's engine, but not the GUI.  The only one I know of that does not require Real is the RealAlternative plugin for Media Player Classic.  Of course, Real has threatened legal action against them, although I am not sure if they have followed through.
Rick.
