Hi
Foobar2000, v.1.1.11
When splliting a FLAC file, I get this message (different text) for some files: "Source: "D:\..........\T. Pinnock & The English Concert - J. S. Bach, Brandenburgische Konzerte 1-2-3\The English Concert & Trevor Pinnock - Brandenburgische Konzerte 1-2-3.cue" / index: 1
Unable to open file for writing (Object not found) : "D:\Program Files\JDownloader\Downloads\T. Pinnock & The English Concert - J. S. Bach, Brandenburgische Konzerte 1-2-3\The English Concert & Trevor Pinnock - Brandenburgische Konzerte 1-2-3\01. Concerto No. 1, BWV 1046 in F major - 1 ohne Satzbezeichnung (no tempo indica...).flac"
Conversion failed: Object not found"
The cue is:
REM GENRE Classical
REM DATE 1982
REM DISCID 800A2F0A
REM COMMENT "ExactAudioCopy v1.0b2"
CATALOG 0028941050021
PERFORMER "The English Concert & Trevor Pinnock"
TITLE "Brandenburgische Konzerte 1-2-3"
FILE "The English Concert & Trevor Pinnock - Brandenburgische Konzerte 1-2-3.flac" WAVE
TRACK 01 AUDIO
TITLE "Concerto No. 1, BWV 1046 in F major - 1 ohne Satzbezeichnung (no tempo indica...)"
ISRC DEF058200360
INDEX 00 00:00:00
INDEX 01 00:00:32
TRACK 02 AUDIO
TITLE "Concerto No. 1, BWV 1046 in F major - 2 Adagio"
ISRC DEF058200360
INDEX 00 04:07:27
INDEX 01 04:11:27
TRACK 03 AUDIO
TITLE "Concerto No. 1, BWV 1046 in F major - 3 Allegro"
ISRC DEF058200360
INDEX 00 08:24:38
INDEX 01 08:24:60
TRACK 04 AUDIO
TITLE "Concerto No. 1, BWV 1046 in F major - 4 Menuetto - Trio I - Polacca - Trio II"
ISRC DEF058200360
INDEX 00 12:30:45
INDEX 01 12:34:25
TRACK 05 AUDIO
TITLE "Concerto No. 2, BWV 1047 in F major - 1 ohne Satzbezeichnung (no tempo indica...)"
ISRC DEF058200370
INDEX 00 19:59:45
INDEX 01 20:05:17
TRACK 06 AUDIO
TITLE "Concerto No. 2, BWV 1047 in F major - 2 Andante"
ISRC DEF058200370
INDEX 00 25:19:05
INDEX 01 25:23:47
TRACK 07 AUDIO
TITLE "Concerto No. 2, BWV 1047 in F major - 3 Allegro assai"
ISRC DEF058200370
INDEX 00 29:15:68
INDEX 01 29:16:27
TRACK 08 AUDIO
TITLE "Concerto No. 3, BWV 1048 in G major - 1 ohne Satzbezeichnung (no tempo indica...)"
ISRC DEF058200410
INDEX 00 32:19:35
INDEX 01 32:23:47
TRACK 09 AUDIO
TITLE "Concerto No. 3, BWV 1048 in G major - 2 Adagio"
ISRC DEF058200410
INDEX 00 38:08:48
INDEX 01 38:08:50
TRACK 10 AUDIO
TITLE "Concerto No. 3, BWV 1048 in G major - 3 Allegro"
ISRC DEF058200410
INDEX 00 38:41:28
INDEX 01 38:42:20
What's wrong?
Thanks for any help
Regards
cmg
Does not compute.
Try rename or change so it goes to correct file.
is 276 characters long. Many programs cannot read/write such files (with path+name longer than 256 chars).
To regain access to the files whose paths are too long, you could do any of the following:
- shorten one (or more) of the folder names
- temporarily copy everything to e.g. C:\ or C:\temp
- use the 'subst' command or the Visual Subst (http://www.ntwind.com/software/utilities/visual-subst.html) front-end to map a drive letter to C:\Program Files\JDownloader\Downloads
