DivX Codec version Version 5.0.5 Out!
2003-04-25 20:54:01
DivX Version 5.0.5 www.divx.com Changelog: Fixed: A bug that would cause the codec to encode every frame as an I-Frame when used with certain applications (e.g., AVIUtil, DVD2AVI, and some video capture applications). Version 5.0.4 New: Includes the first version of the Electrokompressiongraph™ (EKG) application, a new gadget from the R&D labs of DARC. The EKG application gives advanced video compressionists the ability to reallocate data to specific scenes within a video clip. Changed: The new RC doesn't use Q=1 frames anymore No stuffing used, bitrate can be too low in some extreme cases. Strategy planning for rate control is much faster now Better tracking of the planned RC strategy creating more consistent quality. Fixed: K6-2 CPU related crash resolved. Not able to change Bitrate Modulation through CLI field. Cosmetic bug when cropping more than 1000 pixels. Cosmetic bug when resize settings are invalid. During 1 pass quality-based, Quantizer can now be set to 1 with CLI Multiple error windows no longer open upon entering wrong bitrate modulation option. 'Max Keyframe Interval' no longer accepts negative values Multiple error windows no longer open upon entering wrong CLI option. In the Quick Config CLI field, 'Enable Resize' was taking invalid options Remove -b in the Quick Config CLI field, 'Use Bidirectional Encoding' option was not getting deselected. Fixed CLI inconsistencies when "Restore codec's default" is pressed. Max bitrate and encoding bit rate(average) was displayed same. Fixed hitting tab in the CLI field to enable 'Use Bidirectional Encoding' Fixed 'Pre Processing Source' Cosmetic bug Fixed: remove -w in the Quick Config CLI field, 'Update Log file' option is not getting deselected. When 'Psychovisual Enhancements' value is set to 4, in the Quick Config CLI field, mismatch in slider and label options. 1 Pass and Nth Pass™ undersized file should be fixed Certain dark sequences would produce a long period of frames using a Quantizer of 31. Psychovisual Enhancement field sometimes displayed "Custom" instead of Light when unselected "Do not prompt with errors and warnings" would select itself when random characters were entered in the CLI after the "-key" option When "-d 3" option was entered in the CLI field, "Source interlace" became blank. Max bitrate would not update at times. DirectShow decoder postprocessing slider became disabled with ATI radeon 9700 Graphics card DirectShow decoder would "fast forward" when seeking backwards. This could cause synch issues when re-encoding DivX Files using the DivX Decoder Filter. Various cosmetic fixes in the Encoder GUI Do not prompt Error unchecked as default fixed. Light Psychovisual enabled itself automatically when exiting the CLI field. Max bitrate reset itself to x10 the average when going in the "profile" tab MPEG-4 "type Indicator" correctly set according to selected encoding parameters No more green first frame at very high bitrates. Decoder updates the display to the appropriate frame when seeking Decoder remembers the postprocessing settings Fixed some memory leaks related to Psychovisual and Nth Pass™ mode Nth Pass™ RC is tweaked to minimize the usage of high quantizer Nth Pass™ doesn't create an empty frames at the beginning of the clip Brightness/Saturation sliders now working correctly.
