Test & Copy Image & Create CUE Sheet Uncompressed uses the Test extraction, not the Copy extraction for AccurateRip.
Included are to logs from the same CD where the first test run got a Sync Error. The ripped wav file is identical.
Exact Audio Copy V0.99 prebeta 1 from 25. May 2007
EAC extraction logfile from 19. July 2007, 19:07
Seigmen / Monument
Used drive : PLEXTOR CD-R PREMIUM Adapter: 3 ID: 1
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : No
Make use of C2 pointers : Yes
Read offset correction : 30
Overread into Lead-In and Lead-Out : Yes
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Used interface : Native Win32 interface for Win NT & 2000
Used output format : Internal WAV Routines
Sample format : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 4:16.50 | 0 | 19249
2 | 4:16.50 | 3:34.67 | 19250 | 35366
3 | 7:51.42 | 4:26.50 | 35367 | 55366
4 | 12:18.17 | 4:26.73 | 55367 | 75389
5 | 16:45.15 | 4:25.62 | 75390 | 95326
6 | 21:11.02 | 5:28.48 | 95327 | 119974
7 | 26:39.50 | 3:59.02 | 119975 | 137901
8 | 30:38.52 | 5:34.65 | 137902 | 163016
9 | 36:13.42 | 5:42.23 | 163017 | 188689
10 | 41:55.65 | 4:44.07 | 188690 | 209996
11 | 46:39.72 | 6:36.48 | 209997 | 239744
12 | 53:16.45 | 9:00.67 | 239745 | 280311
13 | 62:17.37 | 7:00.25 | 280312 | 311836
14 | 69:17.62 | 6:09.63 | 311837 | 339574
Range status and errors
Selected range
Filename F:\Media\Temp\Seigmen - Monument.wav
Peak level 99.9 %
Range quality 99.8 %
Test CRC 307F4305
Copy CRC 0F82058A
Copy OK
AccurateRip summary
Track 1 accurately ripped (confidence 1) [EC820852]
Track 2 accurately ripped (confidence 1) [E4880E0B]
Track 3 accurately ripped (confidence 1) [97A61D5B]
Track 4 accurately ripped (confidence 1) [106BB67F]
Track 5 accurately ripped (confidence 1) [77461CD2]
Track 6 accurately ripped (confidence 1) [E7999A18]
Track 7 accurately ripped (confidence 1) [75866531]
Track 8 accurately ripped (confidence 1) [976BB084]
Track 9 accurately ripped (confidence 1) [C9347995]
Track 10 accurately ripped (confidence 1) [8AE938D5]
Track 11 accurately ripped (confidence 1) [E9C754C2]
Track 12 accurately ripped (confidence 1) [661812CE]
Track 13 accurately ripped (confidence 1) [C68C292D]
Track 14 not ripped accurately (confidence 1) [B55ABB3C], but should be [1FEB47BD]
Not all tracks ripped accurately
End of status report
EAC extraction logfile from 19. July 2007, 19:36
Seigmen / Monument
Read mode : Secure
Selected range
Peak level 99.9 %
Range quality 100.0 %
Test CRC 0F82058A
Copy CRC 0F82058A
Copy OK
AccurateRip summary
Track 14 accurately ripped (confidence 1) [1FEB47BD]
No errors occurred
Anders
