Topic: FooNight FooDay (Read 161203 times) previous topic - next topic
FooNight FooDay
2) Couple of things to change:
$puts(bottom.h,40) -> increase the toolbar height at the bottom
$puts(play.button.top,$sub(%_height%,36)) -> adjust top position of playback buttons
$puts(play.button2.top,$sub(%_height%,33)) -> adjust top position of play list switcher
$imagebutton($sub(%_width%,32),$sub(%_height%,40),22,35,$get_ps_global(image.path)'/icons/logo_off1.png',$get_ps_global(image.path)'/icons/logo_on1.png',WINDOWSIZE:$if2(%foonight_default_width%,820):$if2(%foonight_default_height%,620);REFRESH,,) -> change $sub(%_height%,40) and adjust top position of resize button
finally:
$movepanel_c(Seekbar,10,$sub(%_height%,8),$sub(%_width%,150),5)
$movepanel_c(Volume,$sub(%_width%,130),$sub(%_height%,8),120,5)
where $sub(%_height%,8) is the top position and 5 is the height of the bars
pardon my ignorance, but I can't figure out where to put this.  I tried placing in script > track list and script > per second but it had no effect (I took out your comments, of course).
edit: sorry, never mind, I found it.  right on empty spot in panel and select splitter settings.
3) Well we certainly had the same idea, I already implemented it
fantastic!  please add it to your package when you have a chance.
FooNight FooDay
@tgpo
Yes, no problem, maybe I'll also add a small playlist
@Hatredcopter
Install foo_exvar and enter the variables, as seen in the screenshot.
Remember to restart foobar
It's purely optional, foo_exvar has to be installed, entering variables is up to you.
@barty
These are the default variables you have to change, if you want to increase the height of the seek- volume bars. For example, change $puts(bottom.h,40) to perhaps $puts(bottom.h,55), to increase the bottom toolbar size. Now the position of the buttons is incorrect, so you'll adjust $puts(play.button.top,$sub(%_height%,36)) etc.
FooNight FooDay
New Version:
v1.1
- added compact mode
- added 2nd playlist
- added optional Playlist Tabs (turned off by default)
- bug fixes
- dropped FooDay
FooNight FooDay
ugh I use fooday, anyway to implement the compact mode into it?
FooNight FooDay
Reply #30
Easier to change the foonight colors.
FooNight FooDay
@Hatredcopter
[a href="http://img8.imageshack.us/my.php?image=clipboard01dyo.jpg" target="_blank"]
So far this is how the theme looks like
I got an error on the Ratings thingy :|
Sorry for the bother hope you could help me
FooNight FooDay
Re-download the archive, I forgot to include the rating stars to the pack.
Do not import foorun_nightday.xml, or you will lose your Run Service settings. Open it with notepad and copy/paste the settings manually to Preferences -> Run Services.
For album art:
Right click on the left panel menu to open PSS -> Script -> per Track, and search for:
replace it with:
The same applies for ELPlaylist: Right click on the Playlist -> Settings -> field definition -> __ART.COVER__
FooNight FooDay
Reply #33
Done dude, is that all i need to do?
Thanks for your help.
By the way is there any chance to change the title bar?
FooNight FooDay
Reply #34
I seen the script error on the ratings was gonna post but ya beat me to it.
FooNight FooDay
Reply #36
Am I missing a component to make the ratings work?  I'm getting the same script error using a fresh download.
FooNight FooDay
Reply #37
"Re-download the archive, I forgot to include the rating stars to the pack."
Do it again. It works.
FooNight FooDay
Reply #38
What version of WSH Mod are you using? Should be 1.1.7.
FooNight FooDay
Reply #39
Just wanted to say thanks alot for this, looks great!
FooNight FooDay
Reply #40
Since implementing the new 1.1b I have only two choices in the 'Filter' panel. Just Albums/Artist or Year/Artist.
How do I get the 3th one back? So I can see Artist/Album/Year?
:edit:
I found how to solve my 'problem'.
Preferences|Columns UI|Add vertical Splitter|Filter.
FooNight FooDay
Reply #41
any thoughts as to why I am getting this?
FooNight FooDay
Reply #42
You changed the font. If it doesn't work with the default font either, turn on unicode in windows.
FooNight FooDay
Reply #43
thanks, helped a bunch when I have the language pack installed.
FooNight FooDay
Reply #44
@pee_wee
What language pack?    Windows? - Foobar? - Fonts?
Tell us more where to find and what to do. What font did help?
Erich
FooNight FooDay
Reply #45
I had to get mine off my windows xp disk. google enable unicode.
FooNight FooDay
Reply #46
Thanks for this great layout
FooNight FooDay
Reply #47
Just did a fresh install of Foobar to latest stable, and a fresh install of this theme.  The ratings show up now, but now the cover artwork doesn't refresh when the song changes.  If I click on an item at the top (Info/Bio/etc) and click back to the artwork it shows the proper cover.
If I click next to navigate through songs, the cover is always one behind. It's always showing the cover for the song I last played.
FooNight FooDay
Reply #48
I only noticed this right after importing the config, once foobar is restarted, it works fine. I think WSH Mod is the culprit here.
FooNight FooDay
Reply #49
I re-re-installed the theme, and all is well now.  No idea what the problem was since my installation is exactly the same, using exactly the same files, but it's working now. Weird.
