Topic: can you help to calibrate the vu meter? (Read 587 times) previous topic - next topic
hi
I have installed vu meter foo_vis_vumeter.dll  and i  guess i have installed the last version
in the settings I have this
I have read even
Preferences > Advanced > Display > VU Meter:
VU meter sensitivity – Default left and right preamp (db): 20 and rise time(s) 0.20s
Mouse wheel (hover over meters)
Adjusts meter sensitivity
with the mouse i have set 0dB
but it's not calibrated ,it does show clipping even it's not clipped
might you please help me how to set it up ?
I listen mp3/aac 44.100 or flac 44.100 , and wasapi exclusive
thanks
Re: can you help to calibrate the vu meter?
hi
I have read even
thanks
Hold CTRL key and use mousewheel on the VU meter to change calibration
Hi
but Hold CTRL key and use mousewheel is just rotate the mouse wheel , it doesn 't calibrate
i can change +db or -db , i have set at 0 , but it does give me wrong results
can i know your settings?
thanks
Hi
thanks
Use CTRL-Mousewheel on the working VU Meter in your skin.
CTRL-Mousewheel does not do a thing hovering on settings.
Hi
thanks
Hi
I know i have to use CTRL-mousewheel over the vu meter skin ,but i really don't understand how calibrate to be 100% exact
you can try to use only the mouse wheel over the vu meter skin , and find out with or without ctrl , it does change the same db
thanks
Hi
thanks
Hi
thanks
Does it matter? The VU Meter is eye candy only.
1. Download the -6dB sine wave file.
2. Load the sine wave file into foobar.
3. Turn down the amplifier volume to ZERO !!! OR switch off your amplifier.
4. Goto foobar Preferences: Advanced page
5. Scroll down to the Display section, VU Meter section.
6. Check "Automatic gain control"
7. Click OK
8. Check that your amplifier volume is ZERO !!!   Final warning!!!
9. Play the -6dB sine wave file.
10. You will see the VU meter needle jump - maybe hit overload levels. Just keep watching, it will slowly move toward 0dB.
11. Once stabilized, you can STOP playing the sine wave.
12. Goto foobar Preferences: Advanced page
13. Scroll down to the Display section, VU Meter section.
14. UnCheck "Automatic gain control"
15. Click OK
~ https://hifive.sg/index.php?threads/foobar-dual-simultaneous-output.2262/page-2#post-23260
I couldn't find the sine wave file mentioned nor am I knowledgeable enough to vouch for this process or produce the -6dB sine wave file but I would be interested in seeing this method critiqued and tested. I suspect different skins may also affect this process.
7. Click OK
15. Click OK
Hi 2tec
well i can't download -6dB sine wave file too , i guess you need to login
can i set foobar2000 volume to 0?
i  have  created with goldware
Tools -> Expression Evaluator -> Presets -> Waves -> Sine
and maximize volume (it's normalize) at -6db
i guess you could do with audacity too
seem to work, it should set the wheel mouse at 6
do you need the  -6dB sine wave file ?
thanks
