[font= "Century Gothic"]I have been trying for a bunch of hours to tag with NeroaacTag.exe on EAC 1.0b3 and have so far not succeeded
i need some help here
There are a couple of older posts on the forum but not to do with EAC 1.0b3
i have placed neroAacEnc.exe and neroAacTag.exe in the Flac folder in EAC and am using from the -help on both codecs
Usage:
C:\Program Files (x86)\Exact Audio Copy\Flac\neroAacEnc.exe [options] -if <input-file> -of <output-file>
Usage:
C:\Program Files (x86)\Exact Audio Copy\Flac\neroAacTag.exe <file.mp4> <command> [<command> [<command> ...]]
to get -br 38000 -if %source% -of %dest% && "C:\Program Files (x86)\Exact Audio Copy\Flac\neroAacTag.exe" " %dest%
-meta:year="%year%" -meta:title="%title%"
other tags will come later...
This is what it looks like and what i get when i test encoder
shan
[/font]
In our WIKI we have a hint how it should work under "Example EAC Settings". http://wiki.hydrogenaudio.org/index.php?title=NeroAAC (http://wiki.hydrogenaudio.org/index.php?title=NeroAAC)
I just tried with 1.03b:
/c ""C:\path\neroaacenc.exe" -cbr 320000 -lc -if %source% -of %dest% && "C:\path\Neroaactag.exe" -meta:artist="%artist%" -meta:title="%title%" -meta:year="%year%" %dest%"
It worked. You may fit the settings and tags to your liking.
Edit: important is to link to cmd.exe under "Program, including path, used for compression: C:\Windows\system32\cmd.exe"
Wombat is correct. We have this information available already in a place that does not impose a one-hour time limit on the author being able to make corrections. We are trying to get away from having discussions serve as guides.
This thread will now close.
