lossyWAV 1.2.0 Development Thread
Reply #278 – 2009-02-24 13:08:19
Following the reinstatement of the old spreading function in beta 1.1.3, I have been looking at a hybrid variant which adds the core of the new method with the process of the old. This slightly lowers bits-to-remove for some but not all of the files in my 55 problem sample set resulting in a fraction of 1kbps small increase in FLAC resultant bitrate. There is no real speed penalty associated with the variant spreading function when compared to either the new or old versions. I will post beta 1.1.3c this evening which will incorporate -V or --varspread parmeter to allow the variant spreading function to be tested. Following some discussion earlier in this thread, I will also take a stab at rewording the text describing the lossyWAV method itself. [edit]lossyWAV beta v1.1.3c indicative bitrates. |-----|----------|----------|----------|----------|----------|----------|----------| | SPR |--insane |--extreme |--standard|--portable| --zero | --nasty | --awful | |-----|----------|----------|----------|----------|----------|----------|----------| | NEW | 651 kbps | 581 kbps | 505 kbps | 417 kbps | 313 kbps | 252 kbps | 205 kbps | | OLD | 654 kbps | 584 kbps | 508 kbps | 425 kbps | 322 kbps | 257 kbps | 208 kbps | | VAR | 659 kbps | 590 kbps | 514 kbps | 432 kbps | 327 kbps | 260 kbps | 210 kbps | |-----|----------|----------|----------|----------|----------|----------|----------| Table indicates resultant FLAC -b 512 -5 bitrates from processing of my 55 problem sample set.[/edit]
