Topic: delay/silence moving the seekbar with dbpoweramp/ssrc resampler on (Read 690 times) previous topic - next topic
Hi
I have found a strange glitch or behavior with dbpoweramp/ssrc resampler in the dsp , when i move the seek bar forward or backward there is a delay with silence about 1 sec or more
foobar2000 v2.1.5 32bit portable with few components just for testing , windows 7 sp1 64bit pro , windows 10 pro 64bit ,Windows 11 23H2 64bit pro and Windows 10 22H2 pro 64bit , on several laptops with different dacs and cpu with these settings and i have tried to increase/decrease the buffer without luck
I have found out it's the dbpoweramp/ssrc resampler component build in with these components
but if i change the resampler to sox resampler compiled by @Case   here I guess it's the last version is 0.8.7+   the problem does disapear , no lag/delay/silence anymore
I have posted here because i tought it's the build in foobar resampler ,and i got the same glitch or behavior on several laptops and cpu
thanks
Re: delay/silence moving the seekbar with dbpoweramp/ssrc resampler on
Why not just continue to use Case's newly tuned and optimized SoX resampler (0.8.7+) in all your DSP chains then??  No quality compromise there at all.  Make it easy on yourself, francesco.
@francesco: the delay is caused by the resampler component initializing its internal tables. When you seek in a track foobar2000 nukes all DSPs and sets them up again with new data flowing from the new position - this way no DSP can misbehave and not flush its memory. As @sveakul said, using a faster resampler is a good fix.
Hi sveakul
Yes ,I use the SoX resampler (0.8.7+) , i was wondering about delay/glitches/silence pause since it's build in dsp
thanks
Hi Case
well , i got it ,that's why even the foobar2000 built in Equalizer dsp does take time to change the sound
thanks
