Topic: foobar2000 v2.1 preview 2023-05-17 and FLAC premature EOF (Read 1868 times) previous topic - next topic
The new preview add "FLAC decoder: log premature EOF, mark partially encoded files as bad even if they don't appear corrupted otherwise".
Mostly all of FLAs that I played triggers a popup error, but passed the integrity test and seems to play fine so at first doesn't seem too critical, but I wonder what I can do to correct it and the real severity.
Re: foobar2000 v2.1 preview 2023-05-17 and FLAC premature EOF
I have the same problem. To avoid the popup window, deactivate "Show error messages popups" in Advanced Preferences. Most of my FLAC's are affected, the few not affected show a temporary popup window with progress bar. Can't identify the popup window, because its very short living (more a flicker).
https://hydrogenaud.io/index.php/topic,124137.msg1027421.html#msg1027421
Yes, in 2.1 preview 2023-05-17 on playback this feature gives out false alarm.
BTW, FLACs with premature EOF was always perfectly detected on verification with Integrity Verifier as "Reported length is inaccurate".
Here is example of file with real premature EOF - https://www.dropbox.com/s/n9awti95o8kt88v/TRUNCATED%20%40%203m%2031s.flac?dl=1
That's a relief. None of the files that trigger the pop-up gives that error.
My experience was that Integrity Verifier caught it, but bitcompare didn't. It could sometimes return that files decoded fine, because the decoder didn't check (only the integrity verifier would).
If the change has made decoder more zealous than Integrity Verifier is, then ... hm, Peter needs to scratch his head over something.
This is happening to me as well. It tends to occur when I have clicked to a different place in a song and then played to the end.
Think millionaire, but with cannons.
Thanks for reporting, fixed version will be out tomorrow.
In meanwhile, this is a clear bug in libFLAC, or at least bad documentation.
The documentation doesn't say that I should be expecting a writeCallback from INSIDE FLAC__stream_decoder_seek_absolute(), only mentions different behavior of next writeCallback. My code assumed writeCallback to happen from inside next FLAC__stream_decoder_process_single(), not from FLAC__stream_decoder_seek_absolute() directly.
I think this should be specifically documented.
Something for @ktf
As far as I am aware, this is not a recent change. It seems to me libFLAC has had this behaviour for years. That means I can't change it (or I will break other implementations), so I'll update the documentation.
Probably change this to something like this?
Flush the input, seek to an absolute sample and return the (partial) block in which the requested sample lies through the write callback, starting at the requested sample. In effect, this works like FLAC__stream_decoder_process_single, but at the block in which the requested sample lies, and with all preceding samples removed from the output buffer. The client must support seeking the input or this function will fail and return false. Furthermore, if the decoder state is FLAC__STREAM_DECODER_SEEK_ERROR, then the decoder must be flushed with FLAC__stream_decoder_flush() or reset with FLAC__stream_decoder_reset() before decoding can continue.
Thanks for looking at it.
The behavior must be old, it just caught me off-guard - everything seemed OK in my code, yet setting decode position counter *after* successful seek was doing the wrong thing.
the 2023-05-22 preview released today is with this fix? thanks
