Topic: About the bitrates of MP1, MP2, and MP3 (Read 1730 times) previous topic - next topic
Re: About the bitrates of MP1, MP2, and MP3
I'm not saying that bitrate should be shown as bits-per-sample, I'm asking that does defining the available bitrates in a way that they don't change with the sampling rate have advantages (the opposite can decrase the complexity significantly)?
bit per second is probably more useful for transmission. Remember the time people used modem and telephones.
I already said, but apparently I have to say again: Very low bitrates (like 16kbps for example) are completely transparent for some sounds (at high sampling rates too), like pure tones or humming, which can be encountered at for example the the silent parts of a music or a non-music recording.
    1.3: In all layers of MPEG-1 and MPEG-2 Layer 1, bitrates lower than 32kbps isn't supported while they can be enough for some sounds (especially for MPEG-2, but they can in MPEG-1 too, for example at the end of a music).
I don't remember any VBR Layer 1 or Layer 2 encoders. As said earlier, it's old technologies. Layer 3 was specifically standardized for efficiency. Layer 2 and 3 were not the best tools (especially with constant bitrate) for this purpose even if they probably perform well on specific cases. You just wondering why axes or chainsaw are not used to cut a sheet of paper. It's like wondering why axes or chainsaws are not used to cut a sheet of paper. They do work, but if better tools exist, most people will use cutters or scissors and won't question why Stihl doesn't adapt their tools to cut your magazine.
I think your simile is wrong. I'm asking that why they did not make better choices to make the codec more future-proof.
@guruboolez Thanks, that's a very good answer, now I want to ask that is that still relevant on today's technologies?
Probably the same reason you're probably typing on a QWERTY based keyboard. Should I explain?
Does this mean that defining the available bitrates as bits-per-second does not have advantages anymore?
Reply #30
For most people, obviously not.
The frame header structure actually got bits to accommodate future enhancements. Those were used in MPEG version 2 and 2.5. Sure you can argue that if one knew already from day zero what the needs would have been, one could have designed it different.
One additional level of future proofing could be offered by the free format, which could go up to 640 kbit/s and at least as far down as 8 kbit/s (according to https://hydrogenaud.io/index.php/topic,27404.msg242365.html#msg242365 - I don't know if anything less is even technically feasible). Free format comes at an inconvenience, and isn't that much supported.
So to boil it down to the original question: yes there were some choices made, yes there were indeed set aside bits for "future needs", some of those are useful, others not so much. And one got stuck with a bad file format because it worked well enough.
Reply #33
