Topic: Windows Context Menu  (Read 854 times) previous topic - next topic
Prior to posting, I performed a search and a lot of results were returned, I didn't look thru all of them so I apologize if this has been mentioned before. Be nice if while browsing windows explorer you could right-click a file and from the Windows Context Menu select Foobar - Add to Playback Queue. Similar to the way you can perform a number of WinZip functions from the Windows Context Menu. From File Explorer, I can right-click a file and select Play in Foobar2000 but that stops the currently playing MP3.
Jim Nasium
Re: Windows Context Menu
For Foobar you can configure the behavior for file associations under Preferences -> Shell Integration.
- Set Enqueue as the default action
- Always send new files to playlist -> To prevent the current playlist from being changed in case you constructed it intentionally and need it.
