When converting audio (any codec/format) to WavPack hybrid mode, it results in the error "Conversion failed: Object not found". This error only happens when "Create correction file" option is disabled at encode.
When trying to play any WavPack file without a correction file present, it results in the error: "Unable to open item for playback (Object not found):" - and won't show any info about the file; size, duration etc in the playlist. These files open properly in other software.
Any idea what's happened/how to fix it?
Support of wavpack lossy is broken in foobar2000 1.6.6. Use 1.6.5 or 1.6.7 beta
Ah thank you! Don't know how I missed that. I blame the current heatwave 🤦♂️.
